Question about HP DeskJet 5550 InkJet Printer
Double sided (duplex) printing not possible
Does not print duplex printing after I changed to Vista from win XP pro. Doublesided printing was no problem in XP.
  • HP Master
  • 4,338 Answers
I researched the error and there is no mention of incompatibility with Vista. Un-install the drivers and re-install them from HP's web site.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 11, 2008
HP7130 Incompatible settings
Please , you have to download the driver for win8 ,by samply serching on google.com for example "
HP Officejet 7130 All-In-One driver for win 8
Mar 21, 2013 | HP Officejet 7130 All-In-One InkJet...
How do you make a double sided copy?
If you don't have a duplexer, the larger cover on the back, the only way to copy this way is to re-feed the print, print side up and copy to the back. The duplexer sticks out of the back about 3 inches, the plain cover is just a flat rear door.
Feb 25, 2010 | HP Officejet Pro L7680 InkJet Printer
Duplex still has problems printing double sided.
Hi, Please find the work around steps to resolve duplex printing issue in Windows Vista. Please the send the *.gpd files to the cu via mail before doing the steps. Duplexer Printing for Windows Vista Troubleshooting steps 1.start-all programs- accessories ? cmd -right click-run as administrator 2.Stop the Spooler service - Type net stop spooler 3.Change current directory Type cd windows\system32\spool\drivers\w32x86\3 4.Backup the old gpd files - Type copy hp*.gpd *.bak 5.sent the zipped file to customers email address through astro and then download the file to customers desktop 6.extracted the files from the zipped folder and then pasted those files to windows\system32\spool\drivers\w32x86\3 7.Remove old BUD file Type - del HP*.bud file 8.Restart to spooler service - Type net start spooler 9.checked under printing preferences if the both sided printing is selected as automatic and then tried printing a two page document 10.checked whether its printing or not. 11.) Start-Control Panel- Printer & Faxes- Right Click On the printer -Properties-Device settings-Disable the manual Duplex printing-Click on Installed Two sided printing-click on apply & ok. 12) Then Go to Right Click on the Printer-Printing preferences-Paper quality-Select Two Sided Printing from the top drop down list where its showing What do you want to do? 13) From Print on both sides-Select Automatically from the drop down list. 14) Try to print on both side check whether its working or not.
Sep 18, 2009 | HP PSC 1510 All-In-One InkJet Printer
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
Psc 1315 often hangs up and fails to print page 2 when I select double sided printing. Then cannot delete the file from the printer queue. It says printing page 4 of 2, when there were only 2 pages to...
I am unsure of the OS that you are using however I am providing the general steps with respect to Vista, If you use WIn XP then change accordingly.
Go to the printers folder, right click on the 1315, Run as administrator, Properties, (continue), Device Settings make sure "Duplex Unit (for 2 sided printing)" is set to "Installed" under installable options, OK. When printing go to the Finishing tab and select "Print on both sides".
Try printing.
Jul 18, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP P2015 will not print on both sides (automatic mode)
Properties --> Device Settings --> Duplex Unit (for 2-Sided Printing): Not Installed ------ This need change to 'Installed'
Jun 16, 2009 | HP LaserJet 1320 Printer
Not printing double sided
check the driver
does not print from bypass tray (manual feed)
does not print on thick paper (check paper type)
Apr 01, 2009 | Ricoh Aficio SP C410DN Laser Printer
Duplex not recognised
You need to set the duplexer to installed. For Vista this would be done as follows: go to the Printers folder, Right Click on the 5550, Run as Administrator, Properties, (continue), Device Settings, Installable Options, Duplex unit (set to Installed), Apply, OK.
Once you have done this in Vista the duplexer will work but the back side may print upside down regardless of the settings. This can be corrected with a patch available here.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Mar 13, 2009 | HP DeskJet 5550 InkJet Printer
Printer prints double sided only even though set for single
This is cause duplex printing option is enabled in the driver. If you have win XP, go to control panel and then printers & faxes.
Right click on your LJ P2015 printer driver and click on properties.
Click on the tab 'Advanced' and then click Printing Defaults.
Remove the check mark for 'Print on both sides' under the 'Finishing' tab.
Click Ok and Ok again.
Nov 21, 2008 | HP LaserJet P2015dn Printer
HP DeskJet 5550 InkJet Printer Logo
123 people viewed this question
Ben Johnson
