Question about Symphonic SC319C 19 in. TV/VCR Combo
Tape stuck in vcr
Tape was stuck in vcr but is now removed. TV stills displays "eject" and goes off. Am also unable to put in another tape.
  • 979 Answers
Carriage has been set out of alignment due to improper extraction- need to repair or replace the carriage loader...accordianman
Posted on Aug 01, 2008
How to eject stuck tape
might have to remove bottom of vcr and manually move the drive motor by the belt or the pully. if the bottom doesn't come off, you'll have to remove the top. usually screws on the side bottoms and one in the back. you can reach the motor from there.
Feb 27, 2014 | Mitsubishi Televison & Video
Stuck VHS Tape in Samsung TV/VCR Combo
Only easy way is to unplug tv / vcr from AC outlet and plug it again, now try to eject.
Oct 09, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
Tape Stuck
I've checked the entire user manual which notes problems like this need to be referred to authorized service personnel. Myself, I would unplug the entire unit, put it on a kitchen table using a phillips (cross-tip) screwdriver to remove the top metal shell. Remove at least 2 screws each side and 2-5 rear screws securing the top. Nothing like peering inside to see what is causing the VCR to get stuck and help remove it. No release pinhole or tape freeing ejector will work if the unit's tape is tightly wound around some internal object or the tape is stuck because something foreign is inside the unit. Best of success. ZT3000 "Beta tester of "0"s and "1's"
Aug 17, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
How to repair my vcr I have a faulty tape in the machine and unable to remove it
I hope your vcr is not built in with TV. It is separate from TV. If it is not then you have to call a technician to open the vcr and remove the faulty tape. If it is separate then open the top cover by unscrewing the screws on the side. These can be located very easily. Remove the top cover gently. Look for the gear toothed wheels which load/eject the tape. You can do so by switching the power button on and off. Switch of the power to vcr. Move the toothed wheels by hand to bring the tape up if you do not want the tape to get damaged. When the tape comes up then give it a gentle push so that it can eject itself. If not, repeat the process again. If you see the magnetic tape is stuck or entangled with moving wheel the cut it,remove it gently. Make sure that you do not touch or damage the video head. Once removed, you can fix the top cover.
Apr 04, 2011 | Televison & Video
I also have a 19" Symphonic tv vcr combo which
The problem is with the vcr section, it is stuck in eject mode thinking there is a tape. This a mechanical problem that might be repairable. The tv and vcr share some of the same circuits, you can try resetting the tray in the out position as if it fully ejected the tape. Now if this does not work it means you have a gear timing problem or bad sensor.
Dec 23, 2010 | Symphonic SC319C 19 in. TV/VCR Combo
Trys to eject movie, fails, then shuts off...
the tv must unscrew the cover turn the power felds around for vcr cage for sensor the tape will pop out.push the eject button doing this.
Aug 13, 2009 | Funai F3819D Combo
Stuck VHS tape in Samsung TV/VCR Combo
I told you in premium post that Unplug your Combo for 5 - 10 minutes from AC outlet and replug it. Now push eject button and take out cassette.
VCR repeatedly tries to play and eject when tape deck is empty
the tape carriage is probably stuck, or something stuck inside blocking the tape sensor.
feed a tape in and see if it does it "with" the tape too
hope this helps
Jan 08, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Error message E4 and stuck tape
Yes with care. Simply remove the cover and with care unwrap the tape. If you must break the tape - but make sure all residual tape is cleanly removed. Re assemble and put a tape head cleaner through- following the instructions.
Jun 22, 2007 | Mitsubishi HS-U445 VHS VCR
Tape stuck and tv turns off
With the set unplugged remove the back and extract the main board. You'll find a metal cover over the tape housing area that is easily removed by removing some screws holding it to the board area and manipulating some wired over it... You should then be able to see the tape and what's hanging it up. If you need to unwrap tape from the pinch roller or around the guides do so carefully. When it all looks free you can either manually crank the load motor assembly to eject the tape or put it back together enough to plug it in and press eject. If you do the later be VERY careful... Good Luck! Bill
Jun 01, 2007 | Sylvania 6313CB 13 in. TV/VCR Combo
Symphonic SC319C 19 in. TV/VCR Combo Logo
236 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
