Question about HP VGA Webcam
It won't show my picture. I can see them but they get a black screen.
When I go to MY Computer and try it there it tells me that something else is using it?
  • Diacial Jan 14, 2009
    I have the same problem but i do not know what to do to be honest.
    i have tried fixing through Windows Live Messenger
    but the intergrated HP Webcam does not respond.
    It says that the Webcam is being used or not plugged in.
    So i guessed it was being used but for what?
    i searched all my programs / Devices and cannot find the solution
    please help
    President:
  • 8,637 Answers
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video shoud work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 13, 2009
Why won't my notebook display any picture on the screen or anything
I assume your screen is completely black and maybe doesn't show the flashing cursor? It could ether be the graphics/video chip at fault, or a hard drive or motherboard fault. It could even be the screen itself.
Does it sound as if your laptop is actually booting up, even though you can see nothing on the screen?
If you can, connect your laptop to a computer monitor (a cable will be required). If your display works on the computer monitor it's probably your video/graphic chip at fault.
If the screen is still black after connecting to an external monitor the chances are that it is a hard drive or motherboard fault.
Don't rush off and buy a replacement hard drive and motherboard. It makes more sense to take your laptop to a shop, pay for an inspection and they will tell you exactly what the fault is.
Jun 09, 2013 | Acer Aspire 3000 Notebook
My camera shows black screen and I cannot see if I was able to take pictures or what. The screen just do not show anything. It's all black. What I can do for this? Any help??? Thanks!
You're right in saying that if you get ANY onscreen message with the computer connected, the LCD and its driver circuits are likely OK. I don't have that exact cybershot, but I have had a few, and most have a menu item to turn off various screen content, including the entire display. Its likely a battery saving feature, but if you turn it on and hit the MENU button and still see nothing, there must be some actual defect. If all else fails, before contacting SONY, take the battery out and wait at least 5 minutes and then replace.
May 07, 2017 | Sony Cybershot W330 Digital Camera
Turn on the camera, the start screen shows up and slowly turns to black. I don't see a thing. I tried to take a picture and check it using card reader, I saw picture I took was very clear on my co
Hello, On the C743 this will require that the LCD unit be replaced. This will get very costly real quick unless you can do it yourself. Not much more I can tell you.
Best Regards, Russell
Dec 22, 2012 | Kodak EasyShare C743 Digital Camera
I have the same problem this guy had: I have a Sony Cybershot 8.1 megapixels. Every once in a while the screen will turn black when I turn the camera on. The display will come up (shaky hand, flash, etc.)...
The camera either has a stuck aperture inside the lens or a bad CCD sensor.
The aperture is the opening that allows light to enter the lens. If it's stuck closed no light goes in, so no display on the LCD and solid black pictures. The way to fix it is to replace the lens. You can try tapping or banging the camera on it's side on your hand or even gently on a table. This might unstick the aperture for a short time, but it will just stick again later.
If the CCD is bad the sensor won't show anything other than solid black, or sometimes purple/pink smeared lines. Again the solution is to replace the lens assembly, or look for a used CCD online and just switch that out instead.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 12, 2011 | Sony Cyber-shot DSC-W100 Digital Camera
My computer recently got a virus, and although it has been fixed, it no longer recognizes my camera being plugged in. I downloaded the new software directly from the kodak site thinking that would solve...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Sep 24, 2010 | Kodak EasyShare M1033 - black Digital...
I have a Sony, 54" Projection Screen HDTV that I bought in 2002. I believe it is a 1080i. When I am waatching TV, I notice that when the screen is mostly black, for instance a night scene, the black areas...
Confirm the actual model number as the one indicated in the title is not HD.
Some of these sets had bad picture tubes that on a black screen or blank video input may in your case show faint curved lines and or some color (red,green or blue) present in the background.
If this is the case there is a fairly simple way to attempt to adjust something for this--not in the customer menu but fairly easy to get at and try.
Most of these sets were KP51ws500, 57500 etc.
SD TECH
May 11, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
MY COMPUTER WON"T TURN ON YET INDICATOR LIGHT WHERE CHARGER GOES INTO IT SHOWS LIGHT> Plugged in but will not powerup screen black. THIS IS A G60 HP Laptop
Take out the battery and try running it on the power adaptor alone. If this works, you have a dead battery. If not there's something more serious wrong in the machine.
Apr 16, 2010 | HP G60-235DX Notebook
Camera Problems
MINE IS DOING SOMETHING SIMILAR!
Mar 17, 2008 | Polaroid i733LP Digital Camera
Kodak CX7330. turns on but LCD screen is black and won't take a pic
It sounds like a bad connection on the ribbon cable of the LCD screen to the camera's motherboard. The fact that when you physically move the camera around and you can get the screen to then work, tells me something is loose inside.
- Jim
Jan 14, 2008 | Kodak EasyShare CX7330 Digital Camera
HP VGA Webcam Logo
19 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
