Question about Canon PIXMA MP130 All-In-One InkJet Printer
Printer mp130 Any ideas?? Printer keeps saying cartridge jammed. I have tried taking cartridges in and out and the cradle that the ink cartridges sit in and doing a nozzle check, and doing a copy but nothing seems to work!! My daughter needs to print out homework tonight!! Typical.
Take the ink cradle out and take the cartridges out. clean the print head on cradle with alcohol, and you might wanna try blowing the ink residue out of the head becuase the black ink cartridge leaks
Posted on Jul 15, 2008
Error message that paper jam in paper cradle
Try this:
  • open the lid of the printer (from where you can see the ink cartridges);
  • remove the ink cartridges;
  • use warm water and cotton swabs to clean both the ink cartridges and the print head (where the cartridges sit on) off of any ink residue;
  • place the ink cartridges back into the printer and test if this works by printing something.
If you're still having issues, there may be a mechanical problem; in which case you need to get it repaired by someone.
Oct 18, 2012 | HP Photosmart 8250 InkJet Printer
My printer keeps saying print cartridge cradle is stuck clear jam then press ok, but there is no paper jam
Because it's NOT a paper jam, but a cartridge cradle jam, I suppose it's an ink jet printer??? if so, check for debrie arround the cradle shaft that could prevent the printing cradle to move from left to wright... you could also lubricate the shaft by rubbing a little bit of grease on it with the tip of your finger (verry thin layer), as ink sometimes gets on it and tends to become sticky with time...
Aug 10, 2011 | HP Office Equipment & Supplies
My Canon Pixma MP130 keeps giving me the 5100 error. Can't even complete the nozzle print test. The ink cartridges do not appear to be jammed as they move. What is the problem? Please help.
Turn off printer.
Remove both the cartridges from the printer. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches.
Return the cartridges and turn on the printer.
Error 5100 means that the cartridge can not be detected by the printer.
Hope it helps!
May 22, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Canon mp130 ink cartridge jammed
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Sep 03, 2009 | Canon PIXMA MP130 All-In-One InkJet...
I have a canon pixma mp130 and it keeps saying cart. jammed
Press menu to maintenance.....go to cleaning roller....repeat cleaning 3 times....return to copying...hope this helps
Aug 04, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Ink cartridge jammed
Canon FaxphoneB95 gives message"Cartridge Jammed". How can I solve this problem. Need Answer Urgently Please.
Dec 14, 2008 | Canon PIXMA MP130 All-In-One InkJet...
HP8250 printer
Try this: Remove both ink cartridges. Unplug the printer for a few minutes. Plug it back in and re-install the cartridges.
Jun 26, 2008 | Office Equipment & Supplies
Having problem with cartridge cradle
Try lifting up the cover and taking the cartridge out. Put it back in and it should be fine.
Jun 01, 2008 | HP PhotoSmart 7660 InkJet Printer
What is the cartridge cradle
The cartridge cradle is where the ink cartridges are installed. It slided back and forth on a silver rail. If the rail gets dirty, the cradle can stick and not move freely. Try cleaning the rail with a soft clean dry cloth.
I've also see the cradle become disconnected from the belt that moves it back and forth. If that has occurred, and it is out of warranty, it will need replacement.
My printer says "cartridge jammed" and wont print! HELP!
Have you removed and replaced the cart with a new one? If that hasn't fixed it, you may be looking at goo in the cartridge area. You can often use a swab (Q Tip) soaked in alcohol to clean this up.
Jan 05, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
152 people viewed this question
old marine
old marine
