Wireless Adapters
Problem for Wireless Adapters
Generic problem for all Wireless Adapters
Cisco aironet 350 - media disconnected
By bazildog on Jul 10, 2008
6.2 client utility loaded and the firmware that came with that download installed on the laptop, i can see the card in device manger no ! or x symbols, but ipconfig says media disconnected and no wireless networks are detected.
Run tcp/ip reset (but wired ethernet connection conects to the net fine)
winsock reset
dns flushed
tried with auto ip and a forced ip
tried in safe mode with networking
tried with two routers (both bt voyager 2500v) - yes wireless turned on!
tried with different wireless channels
tried in both card slots on the laptop
tried with speed set to auto and speed set to 1meg (on router and on card)
tried with wireless mode set to auto and set to b (on router and card)
it was working with a bt voyager wireless card i no longer have
HELP ME BEFORE MY HEAD EXPLODES PLEASE!
Comments:
Jul 11, 2008
- any body!
Jul 15, 2008
- hello?
Jul 18, 2008
- any ideas
Jul 20, 2008
- Latoof
Tried that no luck, the cisco card is not getting an ip address, even when i force one it still will not pick up a network.
xp sp2, Acer laptop travelmate 2500
Jul 21, 2008
- tried - still no ip address
Jul 22, 2008
- got another card - that one works fine
thanks for your help
Same Problem
Mar 10, 2009
-   how to enable security in linksey router?
-   kegarun
Best Solution
posted on Jul 20, 2008
Helpful)
Latoof
Rank: Guru
Rating: 89%, 291 votes
does your laptop have a switch on the side or Fn key (blue icons on the F keys) to turn on/off the wifi.
Sometimes Fn + F2 will toggle the wifi on/off.
Post your make/nodel laptop and OS for more specific advice
I avoid using client utilities with wifi. In the conection "allow windows to manage connection" and see if you can connect
Comments:
Jul 20, 2008
- I suggest you go back to basics.
uninstall the cisco util and the card driver reboot and then install only the card driver...
check that the OS recognises the card and it powers up ok and it gets an IP etc.
Jul 21, 2008
- OK try this, start, settings, network connections, right click the wifi conection and select properties,in the wireless network tab, ensure that "use windows to configure wifi" is ticked,
press the "view wireless networks" button
does you router come up?
If not connect to your router via ethernet cable and go into the wifi settings and ensure that the wifi settings are set to "broadcast SSID" and try above again.
Another possible option is to try the wifi settings with the WEP or WPA set to none/disabled to see if it is a security issue preventing the card from connecting and gettingan IP.
also check in device manager, right click the wifi adaptor and in general ensure that device is enabled, also my wifi has an "ON" button in the advanced tab...
Post back results
Jul 22, 2008
- glad its sorted
Was this helpful?
Yes
No
Popular Solutions for Wireless Adapters
Questions and Unsolved Problems for Wireless Adapters
Answer
Connection not holding. It's dropping out and coming back in. In and out constantly
Answer
Hey, i've a Windows Vista (laptop) with wireless (ADHOC) system and i want to connect to another... (More)
Answer
my wireless trend net usb adapter goes off and on. One minute it works the next it turns off and is... (More)
Answer
I live in a house that has a community computer and believe that it has wireless hookup because one... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Wireless... Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
