Keeps making loud noise not showing any fault code.when ever we start the the hot water sound diminishes but this is a constant problem the noise can be very loud and scarry there is no blockage in the pipe but htis problem seems to be unresolved.i also rang ferroli for manual of the clock which did not come with the user manual.ferroli optimax he plus 38c.my postal address is house no 195, maine road,manchester m147tr if you also could sent the clock manual
Common Car Noises and Their Likely Causes
Noise
More Details
Likely Cause
Fixing It
Clicking noise while turning
Starts faint, gradually becomes more noticeable until very loud
Failed outer CV joint (constant velocity joint) due to torn boot (most likely) or old age
Replace either the whole axle assembly (recommended) or the outer CV joint
Water pump noises
Difficult to diagnose because of water pump's location
Noise usually caused by damage to the bearings in failed water pump
Only cure is replacing it. If possible do it at the same time as a timing belt replacement to cut down on labor costs
Squeak or squeal from an engine belt
Loud, high-pitched squeak or squeal
Belts either need adjustment or replacing
If belts only squeak when damp, they probably just need adjustment. If they squeak constantly, they probably need to be replaced
Exhaust heat shield noises
Rattle that you hear when car is idling
Damaged heat shield
Replace heat shield
You need a scan tool hooked up and the fault codes read that are recorded when these warning lights came on. That is the starting point to understand what has failed here.
Can't address other issues, but WATER pressure should be 40 to 80(I'd say 70)lbs. tester at home D for $10-15. Goes on hose Bibb outside, or at washing machine cold valve.
it sounds like to me the water pump on the bottom of the dishwasher sounds like its getting tired the bearings are going an as the water gets stronger its lubricating the beering making it dimishe
it sounds like it is in the pads and rotors they might be in servicable condition but if they have ever gotten hot they can start making noises and make stopping a little bit harder.
