Question about HP PSC 2410 All-In-One InkJet Printer
Faxing I have an Hp2410 Photosmart all in one and am having trouble receiving faxes. The carrier for my phone is vonage. Is there anything special I need to do for a configuration? I have spoken to them several times and have come up empty.
  • igluma Jul 17, 2008
    Same thing in my case. I also have a vonage as my carrier. It seems to be connecting at first, but then It comes with "Failed", error code 232. But I'm able to send my fax anywhere I need to w/o any issues. Please advice.
    Thank you,
I was able to get my psc2410 to receive faxes by changing the baud rate to 9600. I still have an issue transmitting. Here are the instructions to do so:
1. Press * and # at the same time, and then release both keys.
2. Press 1, 2, and then 3, releasing each key before pressing the next.
3. The display window should read "Service" with a revision number.
4. Press the right arrow button once.
The display should read System Configuration or r/w parameters. Press Enter.
*** If it shows r/w parameters at step 4, go to Step 6 or follow next step.
5. Press the right arrow button until r/w parameter appears in the display. Press Enter.
6. The display should read parameter 0.
7. Press 153 on the keypad to go to parameter 153. Press Enter. Change the value to 2 and Press Enter again.
*** The display should again read parameter 0
8. Press 159 on the keypad to go to parameter 159. Press Enter. Change the value to 2 and Press Enter again.
*** The display should again read parameter 0.
9. Press Cancel until you reach the date and time screen on the Panel again.
This should reduce the fax transmission speed.
Posted on Nov 08, 2008
When trying to fax i am receiving the message no dial tone. i pick up the receiver to my phone and i hear the dial tone. is there a pne number to call for tech support.
Without knowing the exact model, I am unable to direct you to tech support....A common problem that causes this is either the phone cord is plugged into the out instead of the in jack on the back of the printer. Another possible situation is that you have VoIP phone service (comcast, or vonage) which doesn't provide a true dial tone for faxing, in which case you would need a dedicated phone line for the fax.
Sep 29, 2010 | Office Equipment & Supplies
Will not send a fax
There is two things i can think of that can cause this. The number one is if you are using a voip carrier (like vonage or att voip or comcast digital voice) they are usually not compatable with fax machines. You will need either a dedicated fax line or you will need to whats called a fax line from vonage or comcast, or from your voip service. If you are using a phone line test to make sure you have it connected correctly buy simply dialing your cell phone or a friends cell phone (let him know you are going to test) once you do this you will hear a ring and an annoying fax machine tone buzzing in your ear. if this is the case and you do have everthing connected correcly i would put a trouble ticket in with your phone company, to test the line condition of your line (to make sure its not shorting or anything like that)
i hope this helps if there was more information i could do better but hopefully this will help out a bit.
Apr 29, 2010 | HP PSC 2210 All-In-One InkJet Printer
My Lexmark X4270 All in One will not fax, I have tried everything but it still won't work. I have Vonage as my Phone service and my computer runs through a Linksys router. Can anyone help me?
Faxing over VOIP is tricky and unreliable at best. Your phone system support people at Vonage should be contacted. This is not a problem with your Lexmark all-in-one product.
Jan 13, 2010 | Lexmark X4270 All-In-One InkJet Printer
Turn off Error Correction. Most VoIP cannot handle it.
Sep 19, 2008 | Brother MFC-5460CN All-In-One InkJet...
Problems faxing with VoiP
Not exaclty, Becaure VOIP Is a Service provider which supports Digital, and the All-In-One we have is a Unit which detects analog signals the best.
And that is the main reason you are not able to send and receive faxes through VOIP Servies.
First i would recommend you to call Vonage and ask why you are not able to sena a fax through thrie VOIP Services.
They should have a fix for the same, because you pay for their services.
And if in case you call HP and check the same issue, they will also dierct you to call your service provider and clarify the same with them.
One step that you can try is by decreasing the fax speed.
Go to Setup/Menu in the All-In-One, Gop to advance fax setup and reduce the speed to slow and then try.
Good Luck
Aug 28, 2008 | HP Photosmart 2610 All-In-One InkJet...
Faxing using voip
I can tell you after trying Vonage a few years ago and them telling us to change all sorts of settings on the machine, that faxing never worked and now I have no idea what the factory default settings should be.  So, if you decide to try it, WRITE DOWN THE DEFAULT SETTINGS so you can switch them back if you need to!
Jul 22, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Trouble faxing and receiving fax from "Brother 575".Can you help me with my fax machine? I have vonage, and I still can't receive any faxes. The machine makes copies, and receives calls,send faxes, but not...
Try changing the "Bandwidth Saver" settings on your Vonage account from the Vonage website. Perform the following:
1. Login to your Vonage account online and click the "Features" tab.
2. Scroll down to the "Bandwidth Saver" link and click on the "Configure" button.
3. You will see a scrollbar with 3 settings: 30kbps, 50kbps and 90kbps
NOTE: My "Saver" was set to 90kbps (Highest Sound Quality) by default.
4. Click on 30kbps (Normal) and click "Submit".
5. Wait about an hour before testing as it could take that long for the change to take effect.
6. Send a test fax to the HP fax test service at 1-888-hpfaxme (1-888-473-2963).
NOTE: This is a GREAT service provided by HP. If your fax goes through correctly, you will receive a return fax within five minutes.
We upgraded to Verizon FiOS and never thought the increased upload speed (4mbps) would present an issue sending faxes. WRONG. We never had fax issues with DSL, Comcast or even Broadstripe VOIP service but for some reason Vonage + FiOS = no fax. That is until we set our Vonage VOIP sound quality to "Normal". Our phone voice quality has been much more reliable since throttling back. This sentiment has also been shared by other Vonage users who have experienced echoing and noise when utilizing the higher quality settings.
Your phone coversations may not have FM quality sound but they will have AM quality and usually that is just fine.
Hopefully this will work for you.
Dave Grannas
Jun 01, 2008 | Brother FAX-575 Plain Paper Thermal
Faxing errors on comcast digital voice
I am afraid to inform you that Comcast does not support faxing.
Please click on the web link given below to get the answer.
Have a great day!
Feb 09, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Outgoing fax never goes
Do you have the same problem with different numbers that you fax to? Are you usinga voip phone service? I use Vonage and have a lot of trouble with faxing. Call the number you are faxing to with a different phone and listen for a fax tone.
Aug 16, 2007 | Brother IntelliFAX 2800 Laser Fax
HP PSC 2410 All-In-One InkJet Printer Logo
116 people viewed this question
Ben Johnson
