Question about Refrigerators
Amana abb1922fe any issue with this refrigerator?
Several. The icemaker broke twice, the freezer stopped working, and the compressor just broke. This is on a five-year old model, so if you buy this turkey, for god sakes get the extended warranty.
Posted on Nov 07, 2010
I have an Amana side by side refrigerator model ASD2522WRB06. I replaced the filter that is located in the grill at the bottom of the fridge. Now water does not flow at all.
It should work with the filter removed because of a automatic bypass built into Amana refrigerators but sometimes even new filters or copy cat filters will not work at all because they have a defective area where they connect to your water system.
http://appliance911seabreeze.com/
Nov 14, 2015 | Amana Refrigerators
Amana side by side not cooling
What is the complete model number of your unit?
Dec 04, 2012 | Amana Refrigerators
Bottom freezer unit in amana refrigerator will not keep ice cream or popsicles solid, even when set on 7 - i cleaned the condenser grill and vacuumed the back, but no change.
This is an indication that there is more than likely a sealed system issue, low freon, etc that you'll need to contact an epa certified tech to resolve
Jun 15, 2012 | Amana ABB1927DE Bottom Freezer...
Amana SZD22MB2L is freezing in refrigerator compartment
I would start with checking that hte air damper that controls air coming from the freezer over to the fridge is working properly. Thats more than likely the issue. Just in case also check that the temperature control is working as designed
May 29, 2012 | Amana Refrigerators
Amana Refrigerator with lower freezer Back wall builds up frost and Ice
we8e88e
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
dsd
Dec 22, 2010 | Amana ABB1927DE Bottom Freezer...
My Amana fridge #ARB2215CB seems to be cooling the
Your refrigerator probably has an issue with its "damper control assembly", which regulates cold air coming from the freezer compartment. Contact an appliance service company.
Apr 13, 2010 | Amana ARB2217C Bottom Freezer Refrigerator
Amana ARB9059cs: compressor makes loud noise (come and go). Refrigerator not working but bottom freezer is working. All lights on. Please advise.
they had problems with some compressors siezing up due to lubrication issues.refrig not cooling probably air flow problem.either fan in freezer section not working,coils iced up,or return air vent blocked
Jan 25, 2010 | Amana ARB9059CS Bottom Freezer...
Amana Side-by-Side Refrigerator Not Cold
can be a few things, if you open the freezer door do you hear afan running?? perhaps the fan is no good?? is there a large amount of frost on the lower plate of back wall of freezer??? very common issue to have a bad defrost thermostat.
Feb 19, 2009 | Amana ARSE66MB Side by Side Refrigerator
Returned home to find freezer of my ABB1922FE competely iced over. How do I defrost it?
Sounds like the freezer door was left open. In which case empty your contents of your refriderator inot collers unplug the unit and wait for the ice to melt. Also chech that the drain hole is clear of debries and food.. this unit is a self defrosting unit. Morinformation can be found here  http://www.amana.com/refrigeration/bottom_freezer_refrigerators/19_cu__ft__bottom_mount_refrigerator_abb1922few.pro?keyword=ABB1922FE
Please rate my answer
Dec 01, 2008 | Refrigerators
Fridge/freezer not very cold and cylinder is very hot? amana arb220zcw
souns as if youre having an issue with your compressor("cylinder?") black football sized motor behind unit???5 yr manufactures warr if so, cross your fingers, out of warr that repair could cost 4-6 hundred dollars
Nov 20, 2008 | Amana ARB220RCW Bottom Freezer...
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
