Question about DeLonghi PAC C100 Air Conditioner
A120E portable air conditioner FT
I can't find manual and I can't figure out how to empty this tank.... please help, I'm hot!
  • Anonymous May 08, 2009
    Need instruction manual for Model DGI PAC A120E
  • 182 Answers
SOURCE: ft light still flashing after emptied tank
float switch stuck?
Posted on Jul 04, 2008
SOURCE: Full Tank
I had the same error and the tank was not even full. I took the cover off of the unit which consisted of removing 10 screws. The water tank is on the bottom left side. I then removed the float which was a small sensor with a styrofoam float. I removed the float (2 more screws) and moved it up and down. It did not appear to move very smooth but after moving it back and forth a few time it seemed better. I put the float back in ensuring it was at the low point, screwed it back in and then tested the unit. It came on and appears to work fine now. I unplugged again putt the cover back on it has now ran 30 minutes no problems.
Posted on Sep 07, 2008
SOURCE: DeLonghi PAC A120E Pinguino 12,000-BTU Portable Air Conditioner - Water Leakage Problem
I had the same problem and found a fairly simple solution. UNPLUG THE UNIT FIRST. All left and right reference below is as view from the BACK of the unit (NOT from the front). Open the right side panel (right as view from the back), by removing six screws (remove screw covers first) and pull down on the panel to remove. Towards the UPPER-back of the unit, there is a cold air evaporator(?)(bunch of tubes and fins) you can only see the edge of it after removing the right panel. Below it is a white plastic drip tray with a hole at the end allowing water to pass down to the lower warm air radiator(?) (another bunch of tubes and fins) to evaporate. If this hole is obstructed, water will over flow and leak. I cleaned out the hole with a vacuum attached to a drinking straw, you might have a better way. After cleaning, I poured a little water through to make sure it drains. There is a lower drip tray at the bottom of the unit which catches the water and you can drain it out the bottom drain hole by unplugging the rubber stopper at the back bottom of the unit. The lower drip tray has a float switch (you can only see it by removing the back panel, which you don't have to do for this procedure) which turns off the unit when the lower tray is full. So, theoretically, even if the evaporation is not working properly, as long as the upper drain hole is not obstructed, there should not be any leakage, because the water will drain into the lower drip tray and turn the unit off when it is full. The upper drain hole obstruction might be causing most of the leakage problem. Also make sure the unit is level left to right. If the left side (left as viewed from the back) is lower than the right side (as view from the back) the water in the upper drip tray might not flow to the drain hole properly and might overflow. You should also vacuum and clean the upper plastis filter screen (pull it out from the top back of the unit). Before closing the right side panel, you might want to vacuum and clean the lower warm air radiator, be careful not to damage the fins. Again before you start any of this, UNPLUG THE UNIT FIRST. This might be easier than packing and sending the over 90 pounds unit to an out of town service center. I understand some service centers might charge $100 for a simple cleaning. Consult a trained technician if you don't have the skill to do this. Do this procedure at your own risk because I am not sure if it might void you warranty. Again UNPLUG THE UNIT FIRST before you start.
Posted on Feb 23, 2009
  • 92 Answers
SOURCE: Display says emergency tank full, air conditioner doesn't work
there is a tab on the tank,make sure it depresses it when yur reinstall tank
Posted on Jun 25, 2009
james3751
  • 614 Answers
SOURCE: MY PORTABLE AIR CONDITIONER NOT WORKING!
There is a switch inside the bottom of unit that shuts it off when it is full of water. Has to go in just right to be able to work. Russ
Posted on Jul 24, 2009
Tip
Air Conditioner User Manuals
Air Conditioners:
Pelonis units are manufactured by Midea Group. You will need to contact them for the manual they can be found at the following link:Download
or Via their contact page (depending on your country):Download
De' Longhi
De' Longhi PAC A120E Portable Air Conditioner Download
De' Longhi PAC C120E Portable Air Conditioner Download
De' Longhi PAC T110P Portable Air Conditioner Download
De' Longhi PAC WE125 Portable Air Conditioner Download
on Jun 08, 2011 | Heating & Cooling
Local arcticpro repair
The blue snowflake is for the AC. The 3 fan icons are for low, medium, and high settings. The icon with the cup with over flowing water means empty the water tank. The cup next to the snow flake is the dehumidifier. The cup next to that means tank is empty and the clock is the timer. If the front part is only blowing out hot or warm air I say you got a broken one unfortunately. The back part blows out hot air which is why there is an exhost hose attachment.
You can get the owner's manual here: Arctic Pro 9 000 BTU Portable Air Conditioner FEA4320A Scroll down the page to see the link for the owner's manual.
Jun 20, 2014 | Arcticpro Ypc-07c Faac7 Portable Air...
Delonghi PAC a120e ,why is it leaking and also is ther a filter
Don't know if this is the type issue you are having. I had my unit leak all over the place last year and found there was ice buildup on the inside of the unit. You would have to remove the cover completely in order to check this out. Also make sure the drain is clear.
Jun 16, 2014 | DeLonghi PAC A120E 12000 BTU Portable Air...
Looking for a user manual for a Delonghi Pinguino PAC A110 portable air conditioner. Where could I find one?
here ya go.... http://www.sylvane.com/images/prodphoto/de1050/PAC-A120E-usermanual.pdf
Oct 09, 2010 | Heating & Cooling
I have ft error on delonghi air conditioner and I've emptied the tank and the filter is clean. nothing to empty as the the unit is brand new .ft won't go away. how do i fix this
Theres a little floatation type device in the removable tank that triggers a switch just above the tank on the unit itself. Just check that that isn't stuck in the "Full Tank" position. I had the same problem and jiggled the switch to make sure it could move and my A/C was back. Hallelujah!!! Hope it works for you...
Jul 10, 2010 | DeLonghi CF210 Portable Air Conditioner
What does it mean when it doesn't work & it says "fe"?
FE may actually be "FT" which means full tank. Refer to http://web1.dlservice.org/dlservice/dataload/istruzio/GB-5751015400.pdf page 14.
Empty the internal safety tank, through the drain hoses. Refer to Page 16 on how to do that.
May 25, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Blinking ft what do i do?
According to the manual, blinking Ft and some people think it is blinking FE, Means the internal tank is full. Empty through the drain hoses. Open the cover on the rear of the AC (it is located near the bottom of the unit) Pull out the two drain hoses, remove the caps and let the water flow out. Put caps back on and place hoses back inside.
Jul 06, 2009 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi PAC C100 Air Conditioner Logo
112 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
