Question about HP LaserJet P2015dn Printer
Printing envelopes on a hp laser jet p215dn
This is a new printer for our office and we are unable to figure out how to print envelopes.  could you please advise
    Sniper:
  • 87 Answers
Please load envelops from tray 1.
When printing from application, just Ctrl + P and OK.
- Nikhil
Posted on Nov 07, 2008
I don't have word. I have a Mac and an Hp printer. I can print the address on paper but can't figure out how to get it on an envelope.
Verify printing options..try this.
  1. On the Mailings tab, in the Create group, click Envelopes.
  2. Click Options, and then click the Envelope Options tab.
  3. In the Envelope size box, click the choice that matches the size of your envelope. ...
  4. Click the Printing Options tab. ...
  5. Load the envelope as indicated in the dialog box.
  6. Click OK.
More items...
Create and print a single envelope - Word - Office Support
https://support.office.com/.../Create-and-print-a-single-envelope-b766aa84-5b97-4f63-b... https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=how%20to%20print%20envelopes%20on%20a%20printer
Dec 05, 2016 | HP Office Equipment & Supplies
How to print envelop on HP 3390
you would be better using sticker sheets.
see for an example
http://www.officeworks.com.au/shop/officeworks/c/office-supplies/labels/address-labels
your local office supply shop would have something similar
Some labels have downloadable templates to make it easy to line up the addresses to the laser label sheets
Trying to print on the envelope could cause jams inside the printer
Aug 13, 2016 | HP LaserJet 3390 Printer
Can HP color laser jet CP1215 print envolpes
You should be able to put single envelopes through the printer. Just be sure to select paper type as envelope as this will slow down the printing process and ensure that the toner bonds to the paper.
Jun 28, 2016 | HP Office Equipment & Supplies
We have a Laser Jet Pro CM1415. It wrinkles linen envelopes when printing. Is there a quick fix (adjustment etc.)? It prints slick envelopes OK.
that printer is really not designed to print on those envelopes but the wrinkling is usually caused by to much moisture in the envelope or paper stock. When the printer heats the print stock to bond the toner to the paper in the fuser unit the moisture evaporates and causes the paper to wrinkle. Don't know of a fix for it other than use different print stock.
BuddyMc
16 Years HP tech
Aug 10, 2011 | HP Office Equipment & Supplies
My hp J4680 won't feed envelopes, the envelopes goes part of the way in and then fails to print
Hi
The envelopes are standard in size hence do not use any odd sizes. And also do remember that you make the required alignment and also the feeding directions and positions. If you print in Landscape then the paper is too short for the printer to pick. Hence use Portrait so your printer can sense the presence of the envelope
Jul 16, 2011 | HP J4680 Office Jet All-In-One Printer
HP Laser Jet P2035 is not printing the "from address" on envelops and even the "to address" is not being printed on the right spot. The envelope size, tray and feed mechanism are...
The easy way to diagnose this is to put a regular piece of paper in and print the envelope on that to see where it is actually printing. This is likely a wrong envelop size selected in your software not a problem with the printer. It is only reproducing what it is told to. Also make sure that the paper options in the print driver reflect the correct settings for size of paper.
Mar 17, 2011 | HP LaserJet 1320 Printer
HP Color LaserJet CM2320nf MFP Envelope wrinkles
On alot of printers when you print envelopes theres a back door on the printer to prevent the curling or wrinkles. Just open the back door when doing envelopes.
Best of luck and have a happy and safe 4th of July weekend!
Jul 02, 2010 | HP Office Equipment & Supplies
Printer name :hp Laser jet 1300 the print
this printer prints a multipage document on 1 page everytime
Oct 21, 2009 | HP LaserJet 1300 Printer
Print en enveolppe with hp color laser jet 2600n
Envelopes can be printed from tray 1 or 2. Select the type of envelope you are using from the PRINT dialog box or the driver. In your program, set the margins. Typical margins for a commercial #10 or DL envelope would be: Return Address Top margin 15mm(0.6 Inch) Left margin 15mm(0.6 Inch), Delivery Address Top margin 51mm(2 Inches) Left margin 89mm(3.5 Inches). For the best print quality, position margins no closer than 15mm (0.6 Inch) from the edges of the envelope. Avoid printing on the seams of the envelope. Envelopes with a peel-off adhesive strip or more than one flap that folds over to seal must use adhesives that are compatible with the heat and pressure of the printer fuser. the extra flaps and seals can cause wrinkling, creasing and feed jams, could even damage the fuser.
Apr 15, 2009 | HP Color LaserJet 2600n Printer
HP LaserJet P2015dn Printer Logo
308 people viewed this question
Seeker5211
Seeker5211
