Question about RCA HD50LPW175 50" HDTV
ATC336 Power Supply
Awesome. Thanks so much for your help and fast response! So have you actually seen a bad power supply mistaken for a bad DM3x?? I thought I may have read that somewhere, but I'm just not sure. Thanks again!
Ben
  • 1 more comment
  • Ben_Eve Jul 10, 2008
    Thanks a ton. You've been a huge help even if unfortunently it's not my power supply. I'll keep my fingers crossed though (except for when I'm soldering). Thanks again. I appreciate it.
    Ben
    Are you familiar with the HD61THW263 model at all?
  • Ben_Eve Jul 11, 2008
    Well, with the HD61THW263, I'm pretty sure it's the bulb, but I'm not for certain. When first plugged in it gives me the 10 blink error code, then it tries to fire. If it doesn't start, it just gives me the 5 blinks over and over for probably 10 minutes or so until LED just stays lit. Now about 10% of the time it will start up. That has gotten progressively worse over time. A few months ago it was probably 50% of the time. I tried to do the chipper check to find out the 10 blink error, but I couldn't get it sync up for some reason. Here's the thing, sometimes when it doesn't start up - it doesn't do anything. No color, no fans, no ballast trying to strike the lamp, nothing. It just cycles the 5 blinks over and over again. However I still get volume. I'm just really hoping it's not the DM3 on this unit. I'm on my second bulb that has roughly 500 hours on it or so. Any thoughts would be awesome. Thanks again.
    Ben
  • BenjaminAEve May 11, 2010
    Do you know much about the DM3x module on the HD50LPW175? I fixed 3 of the ACIN power boards with the capacitor fix, and tested them all with a known good DM3x - every one of them worked perfect! But in testing the good power boards with 2 other of my 3 DM3x boards, they are **** in what I think is the "boot-up" sequence. When plugged in, the front LED comes on, blinks 5 times, then just stays lit like it's stuck - the only way to power the TV off is to unplug it. I thought I've read of a DM3x fix before, but I'm not sure. Anything I could replace in there? Thanks a bunch for your help.
  • RCA Master
  • 8,617 Answers
Yes the symptoms of bad capacitors on the Power supply can mimic the symptoms of a failed DM3. Its alot better to try the capacitor change first, as they are a common source of failure and the price of the DM3 is very exspensive.
Posted on Jul 10, 2008
  • Sonny Berry
    Sonny Berry Jul 11, 2008
    I would be surprised if changing out those capacitors didnt fix your problem. Yes I am famillar with all RCA TVs. What seems to be the problem with the HD61THW263?
Servo stabilizer
A high quality fast response Servo Stabilizer will solve the problem but mark my words highlighted
Mar 12, 2015 | Marantz Audio Players & Recorders
Tip
Power supply repair for ATC 336 chassis HD50LPW175
I have seen quite a few of the ATC336 have dead capacitors in the power supply preventing start up . The capacitors in question are CP647, CP624, CP639 and CP641 all were bad. Replaced these capacitors and the sets powerd up and operated
on Feb 23, 2008 | RCA HD50LPW175 50" HDTV
When the computer is plugged there is a fast blinking green light and will not turn on
A fast blinking green light means the power supply is bad and will have to be replaced. Make sure you replace it with a least the same wattage supply that is in it now.
Hope this helps.
Feb 10, 2011 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
The TV shutts off
Friend this is a very common problem with LCD and also DLP within the power supply the capacitors
Start to fail and the way you can tell is to check them visually for swelling or expanding of the top.
It will be easy to see the bad caps will not be as flat on the top as the good ones, this is the problem,
Exchange them and you will be OK, Well good luck friend. And if it doesn't work make sure the power supply is sending 24v to the inverters when you turn the set on your meter should climb but won't reach 24v because unit will shut down and if so we ruled out the inverters or backlight I seen this problem also caused by the signal board it has a power on command missing and it looks like the power supply is bad but actually it's the signal board, it may be labeled on the board a active high or low 5v which sends the command to the power supply.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 01, 2010 | Akai LCT3201TD 32 in. LCD Television
The power won't turn on
Hi, if your pc wont turn on at all. it means the power supply is bad. Depending on your model it could be an AT or an ATX power supply. You will have to take it to a repair shop so they can find the right one for you. I hope this helps. Don't forget to rate and provide positive feedback for our fast-free response today. Thank you :D
Apr 29, 2010 | HP Computers & Internet
NO PICTYURE OR SOUND LIGHGTS ON FRONT COME ON BLINK FIVE TIMES THEN GO OUT
Thats a common problem with the RCA ATC336 Power supply when the capacitors fail on the AC in power board. You can get the repair kit at the following link which will usually repair that symptom.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-atc336-dlp-power-board-repair-kit/cName/repair-kits
May 23, 2009 | RCA HD61LPW175 61" Rear Projection HDTV
Brand new router works sometimes
the wall plug type power supply (made in China) may be likely bad.
This actually is a switch mode power supply very unlike the old and usual linear power supplies.
It is common the capacitors used in this supply are under rated and do not last very long.
The problem usually seen with dim LED lights on the unit, limited range and intermittent operation.
Try to find a replacement power supply with perhaps higher current rating.
Good luck
Jan 10, 2009 | Linksys Wireless-G WRT54G Router
ATC336 Power Supply Issue?
You can get the capacitors at the following link just leave them a email indicating that you need the capacitors for the ATC336 power supply and they will get back to you quickly, they have the high temp capacitors in stock.
Here is the link
Jul 10, 2008 | RCA HD50LPW175 50" HDTV
Hplpw175x7
I would try the power supply first as the ATC336 has a history of the bad power supply boards.If the power supply doesnt fix it then I would think it may possibly be the ballast
May 30, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Power light blinks fast red
Hello All,
The problem with the fast blinking power light is caused by 4 capacitors in the power supply unit going bad. We have been repairing this model for 4 or 5 years and this is a very common problem. We have a kit with all of the parts and directions available for $15.00 plus $2.00 shipping. Let me know if anyone needs the kit. cclla@suddenlink.net We can also do the repair for youif you are not confortaqble with disassembly of the ac power unit.
Dec 27, 2006 | Compaq TFT5000 15" LCD Monitor
RCA HD50LPW175 50" HDTV Logo
236 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
