Question about Whirlpool Microwave Ovens
I have have a 10 year old Kenmore Hood/Microwave combo built by Whirpool. I'm getting an F6 error code. What is the error code trying to tell me?
  • WB3AAC Jul 10, 2008
    I attempted to execute the diagnostic routine with no success. The F6 error code
    does not 'flash', it is on solid, so in effect the keypad is locked out and therefore
    I cannot activate the 'cancel' button.
    If the suspect faulty relay is on the control board, is that a candidate for your repair
    service?
    Rich Eckenrode
    Paris Landing, TN
  • WB3AAC Jul 11, 2008
    OK ! "F6' indicates a 'microwave relay problem'. Is the microwave relay part of the
    control board? I see a number of encapsulated devices on the back of the control
    board, they are not numbered e.g. R1, R2, etc...but I'll assume the relay is on
    the board as with the exception of the door interlocks and a capacitor there does
    not seem to be any other visible discrete components.
    With a slight nod from you folks, I'll move to the pages where you talk about sending
    in the defective board.
    Thanks
    Rich Eckenrode
    Paris Landing, TN
    Genius:
  • 1,447 Answers
Hi-
Thats a microwave relay error that you are getting, pls refer to this link, this might Help you with your issue just click HERE
Keep us posted.. Thanks for using Fixya!!
Posted on Jul 10, 2008
  • 6,487 Answers
F6 —Microwave Relay Failure: Check the microwave relay.
The F6 error code which is flashing on your microwave refers to a faulty relay. However, I would suggest that you first try to run a diagnostic (which you may not be able to, but it is beneficial if it works). Here is how:
The microwave oven may be provided with a self diagnostic routine that can be operated through the touch pad keyboard. To enter the self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door.
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "—" is displayed.
If you want to try to fix it your self, Always remember Electricity is dangerous and should be treated with respect.
Microwaves are very dangerous, they can still shock you even unplugged!!
Use a metal ( not the shiny chrome type ) screw driver with a insulated handle to short across ( touch both at the same time ) the terminals of the high voltage capacitor to discharge it. With the microwave unplugged.
Hope that helps.........
  • Mark Gil
    Mark Gil Jul 10, 2008
    Seems it really a problem with faulty relay so better take it to nearest repair center..
  • Mark Gil
    Mark Gil Jul 11, 2008
    Yes that can really be a problem with board relay that need a replacement already.....
    Good luck....
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Have a TE code showing on my kenmore elite microwave hood combo
At some place I saw that the TE error refers to the touch panel.
If you go to http://www.searspartsdirect.com/ and enter your full model number you can get parts list and buy parts and even get repair advice.
Link below shows how to replace a control panel on some model of microwave oven. In the video you will see a ribbon cable being removed. You might want to wipe the contacts of the ribbon with alcohol and put it back in to see if it helps with your problem.
F3 error Microwave oven control panel replacement
Sep 11, 2014 | Kenmore Microwave Ovens
Getting an "F6" error on
HELLO.
An F6 error code typically indicates a controlpanel problem. Disconnect power and wait several minutes before plugging itback in. If the F6 error code comes back within a minute of restoring power,the control switch pulse return line is not connected properly. This willgenerally require professional repair.
Thanks.
Sep 21, 2011 | Kenmore Microwave Ovens
Error message
The F6 error code on your microwave oven is a relay failure.
Check wiring to relay 4903 for short circuits. If wiring is OK - replace the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 14, 2009 | Kenmore 61701 Microwave Oven
Kenmore Microwave hood combo Model # 66569689992 F6 error code?
i fixed by unplugging the microwave with the door open. I plugged it back in and the F6 was gone. I was then able to set the clock and turn the light on/off . When I closed the microwave door, the F6 came back on and the microwave was making a humming noise. I slapped the side of the microwave near the keypad, and the F6 cleared from the readout and the humming stopped. The microwave is working fine now. Don't know why, except maybe slap on the side reset a relay or something. Anyway, I will never by a Sears Kenmore appliance for the rest of my life. The door rattles when you open a close it (like a part inside the door is broken) and this is the second time a fault code has appeared during use. I had GE Profile appliances at my last house, which are more $$ initial cost, but who wants to screw around buying a new microwave every four or five years. I'll happily spend a couple hundred more for the peace of mind and knowing that it will work during Thanksgiving dinner with the family over.
Dec 08, 2007 | Microwave Ovens
Microwave repair
my kenmore 665 69682992 2000 model was running fine until it stoped while i was defrosting and the display appeared f6 and continues to run, what should i do.
Mike hammoud
8465 berwyn 48127
dearborn heights Mi
313 2829272
Jul 04, 2007 | Kenmore 63792 Microwave Oven
Microwave Ovens Logo
368 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
