Question about Nikon Coolpix 5700 Digital Camera
Coolpix macro problem
All of a sudded I can't get the "macro" symbol to flash yellow and auto-focus when doing close-ups. Any suggestions out there?
I called customer suppot.
Follwed these steps:
1. Make sure camera and subject are perfectly still
2. Push flower button till white flower is on screen
3. slowly press zoom in and out till flower turns yellow
4. wait 10 secondes or so
5. camera will focus on object
6. if not, press zoom in/out again, then wait again
Posted on Aug 24, 2008
Turn macro mode icon
Try this,
Touch "Menu", then Auto(Macro) and select desire mode.
Auto(Macro) -> camera will adjust focus automatically from distant subject to close-up.
Close Focus on -> Close distant shoot.
Nov 05, 2013 | Sony Cyber-shot DSC-TX1 Digital Camera
I have a Nikon Coolpix s70 and the clarity of my pictures are horrible. I get on average maybe one good picture out of 5 taken. They are all very blurry. How do I reset my settings and which...
Check the LCD display. Is there a symbol of a flower in a pot? If so you have accidentally left the camera set to "macro" (close focus) mode. if this is not the case then add a comment and I'll provide the next most likely cause.
Usually the macro setting is activated by pressing on one of the thumb-pads around the select button, it will also be marked with a flower symbol. If I'm wrong about how to deactivate macro, then add a comment and I'll research a more accurate answer for you.
Jun 26, 2011 | Nikon COOLPIX S70 Digital Camera
The distance focus ring, is it supposed to turn all the way to the macro symbol when you are focusing on a subject that is very close?
If you're right "on top" of the subject - then, yes - it should indicate "macro". Macro focusing is for "very up close" photography and is exactly as you describe. You simply physically move the camera a little closer to or further from the subject to focus.
Not all lenses are capable of macro focusing. The vast majority of these non-macro lenses are required to be at least a couple (or more) feet away to focus. Macro lenses on the other hand can usually get just inches away - which is a great capability.
Enjoy your macro lens!
Oct 12, 2010 | Canon EF 28-80mm f/3.5 -5.6 USM Lens
Focus problems
There are two likely reasons for the blurry pictures. One possibility is, as you surmised, a slow shutter speed. Try mounting the camera on a tripod or other stable support. You might also try turning on the flash.
The other reason is focus, or lack thereof. You didn't specify what cameras you have, but if they're Coolpixes, they most likely have a close-up or macro mode that will allow the lens to focus closer. If you're using a DSLR, you will need some other way to focus closer. Macro lenses, extension tubes, and close-up filters are three ways of achieving this.
Jan 20, 2010 | Cameras
How do you take macro photos
Your lens is the limiting factor to take macro photos, the kit lens provided with you camera won't focus very closely, nor it will have decent magnification. There are special purpose macro lenses which can stretch up to and over $1000 for a decent quality one. Tamron's 90mm f2.8 is probably the best value one.
A tripod will be of benefit too, as it slows down the process, so you think about your composition, use manual focus and a small aperture for better depth of focus (field).
Nov 08, 2009 | Nikon D80 Digital Camera with 18-135mm...
When zooming in for a close shot it will not focus
When using the tele, the closest you can be to a object is probably more that one meter. If you need to get closer you should switch to macro mode.
Oct 01, 2009 | Canon PowerShot SD850 IS Digital Camera
My Olympus 1050sw focus and auto-focus won't work. All photos are blurred.
You probably have macro mode on (a flower symbol is visible in the config menu). That means the focus has been modified to take close ups. Disable the macro mode and your focus comes back.
Oct 01, 2009 | Olympus Stylus / mju 1050 SW Digital...
DMC-FZ7 problems
Have you tried switching the mode dial to a flower icon?
The mode with the flower icon is the macro mode, you can shoot up to 5 cm from the subject.
Also, if you are very close to the subject, then the auto-focus may not function properly if the targeting area is not centered on the subject.
When I shoot macro with my FZ7K, I use manual focus, the auto-focus generally has trouble focusing up close.
I would suggest trying manual focus.
Jul 04, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Cybershot H7 focus problem
Things to check before you assume it is a mechanical issue-you can get vibration message if flash is disabled, be sure also that the macro mode is not enabled-this is very common on sony cameras to turn on by accident-flower button on camera will put in close up mode and you will get blur make sure no flower is present on lcd screen-if in macro press button on camera w/flower to turn off-also in menu you have continuous and monitor auto focus settings try changing one or the other and see what happens
Mar 18, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Focus problems
Just turn off macro mode - that's it...
Feb 06, 2008 | Cameras
Nikon Coolpix 5700 Digital Camera Logo
89 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
