Question about Hi-Val DVD Kit (DVD6X-00R1) Internal DVD Drive
Dvd drive cannot read files
I have a toshiba satelite laptop and I'm having a problem with the DVD-ROM drive. Some times it works, and other times it does not. I am trying to lay a game and yesterday it recognized my CD, but today is says there is none present when it's in the drive. I have tried to upgrade and nothing happnes. When I check out my device drivers it says the driver is working properly. What am I to do next?
Thanks,
    Sergeant:
  • 264 Answers
I have mentioned few steps from Microsoft. kindly follow them and the issue should be resolved.
Manually delete the registry entries loadTOCNode(2, 'resolution');Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base: 322756 (http://support.microsoft.com/kb/322756/) How to back up and restore the registry in WindowsLog on to Windows by using an account that has administrator rights and permissions. Then, follow these steps. Step 1: Start Registry Editor loadTOCNode(3, 'resolution');Click Start, click Run, type regedit, and then click OK. Registry Editor starts. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry:Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor. Step 4: Restart the computer
Hope this helps. Kindly update me on the same.
Regards
Sammy
Posted on Jul 10, 2008
In compaq presario, when i put dvd/cdrom in my dvd drive of it read as a blank cd why?
U could install another cd/dvd rom like a toshiba rom. It works!
Mar 30, 2012 | Computers & Internet
I want to format my c660 toshiba and load xp the boot has been changed to dvd rom but does not want to boot say failure
Check if you have another bootable disk and try with that. Check the same disc on a different computer and check if that works. Else if you have a exterl DVD drive check with that
Nov 25, 2011 | Toshiba satellite c660
My DVD Rom of Toshiba Satelite 1800 laptop needed to be changed because the DVD tray cable was torn. When I replaced the new DVD ROM the laptop is not detecting it and it even takes a long time to boot....
I think dear speed of proccessor and the speed of you DVD ROM is deferent that is, you proccessor is faster than your cd rom or vice-versa is also possible, I would rather suggest you to know the speed your old DVD ROM and get another of same speed like old one, or just try changing cable of your old DVD rom and use it.
Mar 08, 2011 | Toshiba Satellite 1800-S253 Notebook
Toshiba Satellite A200-1M4 When I start my laptop i can hear a long peep sound and my DVD ROM auto opening. My DVD ROM PC detect but It can not read the CD always showing inset the CD. Please help me in...
dvd burners or rom drive have 2 lens inside, one for DVD read, the other for cd read. I see it often where one fails out in the drive but the other works. With one working fine and the other not, I would replace the drive. If still under warranty send it to manufacturer. If not do a search on Ebay for a replacement drive, or get a local laptop repair shop to do it for you.
May 11, 2009 | Toshiba Satellite A200-16J01D Notebook
Toshiba Satellite P205D-S7479 Drivers for DVD-ROM
Download new driver files of pioneer dvd drive fron internet.
Apr 17, 2009 | Toshiba Satellite P205D-S7479 Notebook
Detects CD but not DVD
Hi Chopadepve,
Please try this method but be more careful during working out on it:
Since your DVD drive reads cd's, but not dvd's It shows that the hardware works fine. Now we need to Edit the Registry to fix this problem.
1) click the start menu
2) click on "run"
3) type "regedit" and click ok
4) go to string key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
5) delete "upper filters" and "lower filters" in the right side window.
6) right click my computer in the start menu.
7) click properties
8) go to the hardware tab
9) click device manager
10) expand the dvd/cdrom drives
11) right click the dvd rom and click uninstall
12) Reboot PC
Windows should automatically install a clean ROM drive after the reboot otherwise Open the device manager window and click "scan for hardware changes". DVDs just read fine if you have the correct DVD decoders.
If no luck then might be DVD read head wiped out.
Regards
ELLIN
Sep 12, 2008 | Computers & Internet
Replacing a dvd-rom drive
go to http://www.irisvista.com you will find lots of information about replacing the parts of Toshiba Notebooks
Good Luck
Apr 14, 2008 | Toshiba Satelite 2410 Notebook
DVD drive some time works, some time does not
first try uninstalling the dvd drive go to start/control panel/system/hardware/device manager look for dvd/cd-rom drives right click dvd - uninstall reboot afterwards so winxp will re-install drivers if this does not work, go to toshiba.com look for downloads for your dvd/cd drives just make sure you have the right model so the file you download will be exact and correct
Jan 21, 2007 | Toshiba Satellite Satellite 5200 Series 15...
Hi-Val DVD Kit (DVD6X-00R1) Internal DVD Drive Logo
504 people viewed this question
Top Hi-Val Computers & Internet Experts
David Payne
David Payne
Are you a Hi-Val Computer and Internet Expert? Answer questions, earn points and help others
