Question about Brother Sewing Machines
Stitch selector No matter what lenght or width i select for sewing, the machine only will sew a long and the width of every design is wide and long. I can put the width on to 1.4 or 3.5 the lenght will be the same. Thank you for your hepl I can't sew may garments I started because of the stitch selection is not assessable. I have a Brother 1000 Computerized Machine Thank you very much!!!!!!!
  • 323 Answers
It needs to see a technician.
sewman7
Posted on Jul 12, 2008
I have a Elna air electronic 68, I am not able to use different function. Like thr preprogrammed.
Your AE 68 will have three dials across the front, from L-R, stitch selector, stitch width and stitch length. To sew any stitch with a sidewise needle movement, you will need to turn the stitch selector to that stitch on the selector, then turn the stitch width to between 3 and 4 and the stitch length to a similar setting, adjusting to get the stitch formation you need. To sew with the discs, set all the dials to zero, then insert a cam into the Elnagraph on top of the machine. Then turn the selector to the disc icon, and the stitch length around to the "S" and stitch width to 4.
Don't use reverse if using the elnagraph stitches.
Jul 01, 2017 | Elna Sewing Machines
How can i change the stitch type
On a sewing machine, it would be the stitch design selector in conjunction with the stitch length and stitch width selections. For a zig-zag stitch, a stitch width selection higher than zero will give a wide stitch.
Apr 17, 2017 | Sewing Machines
Setting for straight sewing
the information should be In your manual, if you do not have a manual, send a comment with the name and model number of the sewing machine or serger, and someone can help you with the question
May 10, 2016 | White Sewing Sewing Machines
I dont have the instruction manual and i cant figure out how to do a zig zag stitch? Help
You don't say the make and model of sewing machine. But generally zig zag is achieved by selecting the zig zig stitch on the stitch selector, then setting stitch length to 2 and stitch,width to between 3 and 4, depending on the fabric. If its a very light weight fabric 4 the thread will pull in and tunnel the fabric so turn down to narrow the width of the stitch.
Mar 03, 2015 | Sewing Machines
How do I set the dials on husqvarna viking 6000 sewing machine
The "dial" in the back is for decorative stitches which require a "programmer" to be inserted with the stitch formation you want to form. For a straight stitch no cam is required in the back of the machine. The three dials on the front:
Upper Left: Stitch selector
Upper Right: Stitch lenght
Lower: Stitch width
Using the upper left dial select the straight stitch picture
Using the upper right, choose your stitch lenght
Using the lower, choose your needle position, left/center/right
Dec 13, 2014 | Husqvarna Sewing Machines
Width
it sounds like both of the machine need to be check to see what
is wrong with the zig zag stitch controls or if it's the cam inside the
machine. a sewing technican can tell for sure
Jun 08, 2012 | Janome Sewing Machines
My machine will not zigzag. Width setting on on1 length setting on widest
You need to take the width setting up to 4 and length down to 2 or less if you want a close zig zag. You may not want it that wide but usually 4 is the maximum width.
There is probably also a stitch selector if your machine has several stitch patterns it can do. I've looked at an image at http://www.stevekraftrepair.com/uploads/resized-P9200750.JPG and it looks to me like the left hand knob on the front of the machine is the stitch selector and is colour coded in with the images on the front panel. I just can't make out which number is the zig zag, it could be the red number 4??? So you would put this dial onto the zig zag, then turn the other dial up to a wider stitch width and I am guessing that the little blue box lower down the case has the reversing button and the stitch length setting.
Usually it pays to turn the width to zero BEFORE you make changes to the stitch selector, most machines seem to like being treated this way, ie engaging cams inside the works.
Also, it is always a good idea to check what foot you have on before you start sewing a swing needle stitch just to make sure that you don't hit the foot with the needle. Some feet are designed for straight stitch only and have a little hole but obviously this is not going to work for a zigzag stitch.
I hope this is of help and that I have understood your problem.
Jun 11, 2011 | Necchi 3537 Mechanical Sewing Machine
Do not know how to set the machine for simple straight stitch.
I don't know your model but most machines have 2 common setting devices, namely a stitch width dial (how wide the needle swings) and a stitch length dial, how far apart the stitches are. So a normal straight stitch is "width" set to zero and "length" set to 2.5. If the machine has several different stitches then there may be a "stitch selector" too where you can choose the stitch style, ie zig-zag, 3 step zigzag, blind hem stitch etc.
You could try to locate a manual or threading diagram at various websites or visit sewing.about.com which gives good general information on threading and use.
Mar 01, 2011 | Singer 1725
I'm looking at the Pattern Selector Dial. 2 different stitches are shown for each selection A - H. 1 shown in blue 1 shown in green. Does each pattern have 2 options?along the rt side of the machine also...
i have same machine, you know i found that to be odd too. heres what you do, click it to the letter you like the style, then start sewing on a swatch at the very shortest stitch. then start increasing the stitch width more and more, up to 4 and see how it difers. i think thats where you will see the difference. i haven't played too much with mine yet, but listening to you is encouraging me to play on a swatch with all the difffernt styles you can stitch.
Jun 17, 2010 | New Home 2014LE Mechanical Sewing Machine
What settings do I use for straight stitching on my machine
-Turn the stitch selection dial to the straight stitch (usually the first one, looks like this ----------------)
-Set the lenght dial to anywhere from about 1.5 to 3. The bigger the number, the longer the stitch
-Your width dial will also control where the needle sews (on the left side or the foot, right, center....)
Hope that helps,
Chris
PS,
Always thread the machine with the pressure foot up, or else you will get looping of thread on the bottom of the fabric..
Jun 06, 2010 | Brother XL-5130 Mechanical Sewing Machine
Sewing Machines Logo
94 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
