Question about GPS
Takes a long time to get signal - GPS
    Sergeant:
  • 250 Answers
Hello annmarie2875,
In order for your GPS to calculate its own location, it needs to receive data reports from four or more GPS satellites. This process is normally pretty fast and will typically take approximately two minutes. However, this assumes that the GPS is used outdoors and has a clear view of the sky.
Obstructions such as tall buildings, trees and local terrain such as mountains and hills can affect your receiver's ability to "see" the sky. If you are using the GPS inside of a vehicle without an external antenna the GPS may also have a hard time acquiring satellites depending on where it is mounted. Ideally you want the GPS to be installed in the lowest possible point inside of the vehicle that has a clear view of the windshield and side windows.
A GPS receiver without a clear view of the sky can take a long time to get a fix on its own location. Additionally, the process can also take additional time if the GPS has been powered off for an extended period of time or if you have traveled a long distance (greater then 500 miles) since it was last turned on.
Hope this helps!
Ken
"Go Ahead. Use Us."
Posted on Jul 10, 2008
Looses time after day light savings time
Clock shouldn't lose time if it is receiving time signal. Do you have the signal indicator showing?
If not suggest you take the batteries out and reset the clock, making sure that you do not set a time.
Apr 02, 2013 | SkyScan 86742 Digital Atomic Wall Clock
When turning on the TV, the on light is on, however it's not connecting to our cable system and the screen sits blank. We had the cable company come out to check the box and he informed us the box is...
The tv Tuner signal board it is dying,that why tv requiring to turn on and off a few times to get the tv incomming broadcasting signal work,to get a picture.The tv Tuner signal board, that the board that take in the incomming broadcasting signal cable and other external devices plugin to it like a DVD players and games systems.Can u take things aparts and putting it back togther again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for to do the replacement.
Jan 27, 2011 | LG 47LG50 47 in. LCD HDTV
My 2008 Ford Edge cannot seem to hold the Sirius signal. It works intermittently. For no known reason I lose the signal. (No Signal) I have called Sirius and they have sent an activation signal and it...
I had a similar problem. Tune your sirius to 184, leaving the radio and the key on with the drivers door open. Let set for 15 minutes. Before you do this procedure, call sirius to tell them to send a boost to your radio. This should take care of your problem. Good luck :)
Nov 18, 2010 | Ford Edge Cars & Trucks
I have a JVC G40 DVD home theater system and when I play DVD's the voice and picture don't match up. Specifically, Peoples lips move and then a second later what they say is heard...how do I fix this?
When viewing on Digital TV:-
Sometimes Audio and Video signal can not be transmitted simultaneously due to additional process time for the video signal compared to that of the audio signal.
Often video signal takes more time than the audio signal to convert from analogue signal to digital signal in the Digital TV.
It may result in mismatch of the picture and sound.
In the TH-G30/40's HD AV Sync menu, you can adjust the audio signal delay for simultaneous AV signal transmission
1. Delay time can be varied in 10msec steps.(0 to 300ms)
2. Delay time is different between TV Brands.
So you need to adjust the delay time for correct lip-sync.
The adjustment is listed in the instruction book page12
Jun 26, 2010 | JVC TH-G30 Theater System
My phone not getting signal properly when a signal low area.some time even is signal available,cant take call to phone.
thats a hardware problem, your RF amplifier should be weak. it is responsible for amplifying and mentaining the signal on your phone. you should therefore take it to a service point so that they check it anf if possible replace it.
Regards
May 10, 2010 | Nokia 6300 Cellular Phone
Just flew from La to Miami and the gps thinks it is in La.It can't find a signal. Help
some times it takes real long time to find gps signal. can take up to half an hour. what will help is go online and take latest quick gps link file. after that it will be a lot faster in finding satts. good luck.
Feb 15, 2010 | Tomtom GO 720 GPS Receiver
Tomtom one XL
hi, it can take up to 15min to find the gps signal for the first time, also make sure you outside and away from any tall building then just wait and you should find it will come on.
it usually takes about 5min to find signal but the first time it can take up to 15min to find the signal.
you could also go through the menus on the tomtom and find the menu that says gps and click on this and see if it has found any signals from what i can remember it needs to pick up 3 satalites before it starts working properly.
Let me know how you get on or if you need further assistance ok
Jan 13, 2010 | Tomtom ONE XL GPS
My Panasonic Strada CN GP50N takes ages to receive a GPS signal. Is there a fix for that?
if it gets the signal there is no problem with the GPS, and yes it can take allot of time to aquire the signal, a common complaint.
Sep 14, 2009 | GPS
GPS takes a long time to receive satellite signal.
You probably are just in a bad location where satellites are not reachable. All these units work from the same satellites and recieve them the same so it wouldn't matter what brand you have. I highly doubt that the powerlines and cell towers are effecting the transmission.
May 19, 2009 | Navigon 2200T GPS Receiver
Nokia 1100 no net work
HI,
This happens,when we use our Nokia 1100 for a long time.When we put the phone in keypad locked mode,the cellphone cannot refresh it's state,but the signal comes to your phone.When we again take our phone and start working,it gets refreshed and shows signal.
The actual problem is,When we take our phone and start working and at that time also if the signal is not provided,we have to search it manually to get our home network.
"I TRIED WITH MY PHONE NOKIA 1100"
Mar 17, 2009 | Nokia 1100
GPS Logo
131 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
