Question about HP OfficeJet 6110 All-In-One InkJet Printer
Right cartridge error
"Right cartridge incorrect". I have tried to clear this several times, today I bought brand new cartridges (both black and color); problem continues. Please help!
  • 2 more comments
  • davidhellr Aug 27, 2008
    The spring tension wire looks ok. But the message continues to appear.
  • kikimo Nov 02, 2008
    I have a HP officejet 6110xi all-in-one. It is saying right cartridge incorrect! Its also making an unusual jammed clicking sound when i boot it up and won't stop until I shut it off. It won't even fax. Nothing. I've only used for faxing maybe 20 times at most since I purchased it brand new at office depot.  I'm frustrated and am not about to waste my money on a new cartridge! BAD HP!
  • davidhellr May 11, 2010
    Correction - my model 6110
    Thanks for the suggestion. I tried it on my model 6100 but couldn't find any silver disc battery on the left hand side. Could it be somewhere else on this model?
Well, it does have an internal battery, but not on the left hand side. I've just stripped the whole unit down, removed the flatbed scanner, taken the sides and back off and got to the main circut board on the right hand side. it has an in built battery component which is basicaly 2 small watch batteries placed on top of each other and wired into the board. I have disconnect this component and put it all back together. After all that, its not made any difference and i'm still getting the same error.. time to sick it in the bin and buy a new one i think....
Posted on Nov 05, 2008
The 6100 series does not have an internal battery back up.
Posted on Oct 15, 2008
  • 138 Answers
Flex ribbon cable at the rear of the housing that the cartidge fits into is probably punctured. It happens a lot with this model. Remove the offending cartridge and look at the electronic ribbon in the rear where it contacts with the cartridge contacts. There is a spring tension wire in the housing that holds the cartridge snug that breaks loose and punctures the flex ribbon rendering the printer useless as there are no part available to repair this HP defect. It is a well known defect / poor design flaw in this machine.
Posted on Aug 03, 2008
  • parkerguy Sep 05, 2008
    Here's another trick for you to try. Sounds like the printer may have the error locked in non-volitale memory and is unable to get past it.
    Open the print as if you were going to change the cartridges. Unplug the machine. With the printer top up, carefully separate the hinge stop support on the left. Its the big plastic peice that prevents the top from opening further. Open the machine a little wider so you can look inside on the left side. You'll see a silver disk, the battery. Carefully remove the battery and wait about a minute before putting back in the same as it was. Pay attention that is goes in the same way as one side is positive and the other negative. Re-assemble the dislodged hinge stop. Power up the machine again. This may erase some of you settings (date, time, etc..) but should clear the error. If the error is still present you probably have a bad board.
    Let me know what you find. I had this today on another model and that's how I resolved it.
    Cheers. Hope that helps.
  • 28 Answers
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
795
Posted on Feb 28, 2009
Black Cartrige Missing
Did you use a brandname ink cartridge - or is it a knock-off brand? If it is a brand name - then the cartridge is most likely defective. If it is a knock-off brand - some printers do not recognize the electronic in the cartridge and therefore don't see it as one being installed.
This may also help
Dell 922 AIO Black Ink Cartridge Missing Message
May 02, 2017 | Dell AllinOne Multifunctional (v515w)...
What does 'Print Cartridge in right stall not supported' mean?
It means you have a faulty or incorrect cartridge installed on the right side position. It could also mean the contacts are dirty or misaligned. Remove the cartridge, clean with rubbing alcohol and reinstall.
This is not a unknown error particularly if you are using cartridges other than the HP brand. Other people will tell you it is fine to use off brand cartridges or refilled cartridges. For myself, I have never had luck doing that - on the other hand, I have never been disappointed using the more expensive cartridges recommended by the manufacturer across several brands including Epson, Canon, Compaq and HP.
Try cleaning the contacts and ink jets. You may have to replace the cartridge. If that is the case, I would return the faulty cartridge and get a store credit.
Just a few thoughts for you to consider. Thank you for using FixYa.com today.
Mar 03, 2011 | HP PSC 2355 All-In-One InkJet Printer
Hi, I have a Lexmark X7170 Multi-function printer/copier/scanner and it is showing an error message "left cartridge incorrect". I have not charged the cartridges and I have tried to re-align it. Any ideas?
it means your left cartiridge got some problem, might be it got short and you have to replace that.
try this remove your left cartiridge and then try to print if it work then its clear that your aother cartiridge is gone and you need to change it.
Oct 04, 2009 | Lexmark X7170 All-In-One InkJet Printer
Error message stating empty cartridge but I bought it new today
sometimes it does happen. please carefully try it several times and try to doing it in different manner.
you can try wiping out dirt and other things that can prevent the print cartridge from functioning ..
you can even disconnect the printer cable from the pc while trying to fix the cartridge, and checking the cartridge installed light to know if it's right.
thanks for your question..
May 20, 2009 | HP Photosmart 8250 InkJet Printer
I changed out the cartridge and the error comees back saying to check cartridge on right. I've done it several times and can't see thing wrong with what I done.
I would try a brand new HP black ink cartridge. Those ink cartridges are not made to be refilled according to HP. If you were to call HP and tell them you had a refilled cartridge they would stop the service call right there and tell you to try a genuine HP cartridge.
Nov 12, 2008 | HP Office Equipment & Supplies
If it says to check the right cartridge (Black), replace it with a brand new one or one you know is good.
Walgreens will test and refill your cartridge for ~$10.00 (black).
I have heard of new OEM HP cartridges being bad.
The printer checks the cartridge level sensor and the electrical stuff.
Apr 21, 2008 | HP PSC 2110 Color Printer
Bought today a hP7200 All-inOne Series. Set up and received the following: Error message "Incorrect Ink Cartridge: The following ink cartridges cannot be used after device initializaed and must be...
hi friend
try remove your printer cardige & rinstall it if u have not remove your printer cardige nosel raper so remove tape of the nosel try to install & print
Apr 13, 2008 | Office Equipment & Supplies
Dell All-in-one 924 error: "right cartridge is incorrect"
Hi ,
if you are getting the error msg 12203 , pperform the following steps,
remove both the cartridges from the printer and unplug the power adapter ( black box) from the back panel of the printer, clean the cartridges using a damp cloth .
initially put only the black cartridge and then turn on the system , it will give you the error msg right cartridge missing, you can ignore it and try copying a document .
remove the black cartridge and put the color one in, and then try printing.
during the printing with any of the cartridge inside the printer if it gives out the error msg 1203 then that cartridge has to be replaced...
Mar 05, 2008 | Dell 924 All-in-One InkJet Printer
Cartridge error 50c
I removed the color cartridge and left the black one. it worked.
(I have Lexmark X6100 Series)
Jan 17, 2007 | Lexmark X5150 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
1,131 people viewed this question
Seeker5211
Seeker5211
