Question about Franklin Computers & Internet
I changed the battery but it's still not working.
Changed battery cables now subwoofer isn't working in my 1997 ford expedition
Check the fuse for the power wire for the amp. Up somewhere by the battery in line of a red cable leading to the battery post.
Apr 10, 2013 | Cars & Trucks
Changed batteries, now won't control power
It is possible you are using the wrong type of battery. A lot of electronics require you to use either Lithium-Ion or less powerful ones. I had this happen once by putting in batteries that were the right size, but were meant for more powerful devices. If you have a cheap set of the right size batteries laying around that are a different type, try those.
Dec 10, 2012 | Hitachi Clu-577tsi Remote Control
I changed my car battery, now my 2008 Nissan Altima key fob won't work
There is a special procedure involved in keying your fob to your car once the battery has been changed. You must lock and open the door with your key. Turn the ignition to "on"(not start) then push the fob's open and close button, then shut off ignition. This procedure is done everything the key battery is changed. Hope this can help you!
Motorcycle Diagnostic Scanner
Oct 31, 2012 | Cars & Trucks
My Vizio HDTV32 remote control is not working, I changed batteries and doesn't work.
Check its battery contacts for any dust or rust. Clean the contacts first and then check.
Oct 25, 2012 | Vizio New Original VO320E Remote Control
2004 Hyundai Tiburon radio won't work after car battery change
Probably has a security code. It's in the owner's manual or you'll have to take it to the dealer.
GL,
td
Oct 08, 2012 | 2004 Hyundai Tiburon
What's your problem? changed batteries now controller wont work
Are you sure you have the batteries in correctly? This is a common mistake so please take a minute and verify it.
Jul 03, 2012 | Fujitsu 18R1 Air Conditioner
Remote quit working for litex ceiling fan
after changing the batteries make sure you didn't change the remote code. If you didn't there should be a reset button inside the battery compartment, it may just look like a small hole. Just use a toothpick and insert it into the hole and lightly depress the reset switch.Replace the battery cover and try using the remote again.
Apr 13, 2012 | Casablanca Fan Dryers
Instrument cluster works intermediately. put another cluster in and changed starter switch and put on new cable ends on battery and still doesn't always work. What's the problem?
just a thought but does your dash have a dimmer switch?as you've changed the cluster and its still not right it could be that.
Jan 29, 2012 | 1998 Jeep Wrangler
It's "frozen". won't change from the screen its
Try to reset it by taking out the batteries and leaving to sit for a minute or so, if that doesn't work take out the small battery as well and leave it sit, if you're still stuck you can call ti-cares (800-842-2737) they're generally very helpful.
Aug 05, 2011 | Texas Instruments TI89 Titanium Scientific...
Computers & Internet Logo
23 people viewed this question
Top Franklin Computers & Internet Experts
Andrew Taylor
Andrew Taylor
obsteiner
 steve
steve
Are you a Franklin Computer and Internet Expert? Answer questions, earn points and help others
