Question about NEC Lands Phones
Electra Elite 192 KSU B64-U10 with B48-U10 KSU expansion. The audio input jack for music on hold is broken on the B64 base. Can we use the audio jack on the B48 expansion ?
4 Suggested Answers
SOURCE: VOICE MAIL NOT WORKING
Is it the type with a hard-drive mounted on the card?
If so, pull the card out of the system, let it sit for at least 15 minutes, then plug it back in. You might even try putting it in a refrigerator (just don't get it wet).
If it still doesn't come back online, it's time for a service call.
I hope you have a maintenance contract, though.
Posted on May 10, 2008
  • 63 Answers
SOURCE: Caller ID for NEC Electra Professional Level I System (KSU)
only if your key system has caller id cards installed.
Posted on Feb 07, 2009
  • 821 Answers
SOURCE: I have a NEC Electra Elite 1PK (B64-U30) phone
Hello,there is no way you can load the "on hold" messages from an audio CD into your system.would appreciate you visit your manual,if you don't have it around you,you can visit the sites below,
http://www.chickasawtel.com/pdf/manuals/elitemultilineug.pdf
http://www.neccare.com/cng/docs.nsf/Lib3?OpenView&Start=1&Count=100&Expand=6.13#6.13
take care.
Posted on Dec 12, 2010
How do i change the hold music
It depends on the system type. some are built in and done through programming. others are connected viz an rca jack on side of the cpu cabinet. post what type of system you have.
Aug 11, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
How to change DTH-32D Station Name
The station name is in program 4-18, but that requires getting into system programming, which is not recommended unless you know what your doing in there. This info will not be found in a user guide.
Feb 13, 2014 | NEC Electra Elite DTH-32D-1 1-Line Corded...
How do i change the extention number or port number when i move my Nec Electra Elite 192 phones to different wall phone jacks?
Look for the Elite Attendant User Guide
Also call your vendor for the password
SET RELOCATION MODE
Set/Cancel using the Access Code:
1. Press the
Feature
key.
2. Dial Set Relocation Mode code
84
Oct 16, 2013 | NEC Electra Elite DTU 16D-2 Corded Phone
NEC Electra Elite IPK B64-U20 KSU
I have a PRI and am asking the same question. I do know that you do have to go into programming to set this up. You also have to have a COIB card installed for this to work for standard Direct Inward Dial lines.
Apr 18, 2013 | NEC Electra Professional ETW-16DC-2
Appears that the 3.5MM input jack (for my ipod) is loose/broken. How to replace it?
to do that you'd actually have to disassemble the unit. ( start by removeing scews on the bottom ) and dropping out the pc boards that hold the jack or are in the way of the pcb with the jack on it. at which you'd just have to un-solder old jack and install replacement and reassemble and your done. you cann call american audio to find distributers of their parts.
Sep 05, 2011 | American Audio CK 800 MP3 CD PLAYERS SOUND...
Want to change hold music how do i do it
Panasonic hold music comes from an external source (if it's programmed properly) that connects to the EXT MUSIC port of the KSU. A 7730 phone is an analog device, most likely plugged into a TA series box in the back room. Depending on how it's mounted, the jacks are under the cover on the top or the right side of the box. There will be 11 modular jacks on the base cabinet (3 lines 8 exts) a page port and the music port (both 1/8" jacks).
Wherever that cable goes is your music source.
Carl
Feb 24, 2011 | Panasonic KX-T7730 Corded Phone
The voicemail light is fully lit(NOT FLASHING)it's not going away
First off we need to know what color it is.
Green-Dial "0" from the problem phone and that should clear it.
Red-Dial "Feature 99 Feature". If that does not work.
Leave a message in that users mailbox. From that users phone check and delete that message.
If neither of these operations work then you may have a bad port which means you may need a new station card. The part is an ESI(8)-U10-ETU, ESIB(8)-U10-ETU or an ESIE(8)-U10-ETU. The U10 might be different.
Let me know how these options work.
Nov 17, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Elantra elite 192 on hold music through rca jack
in your system programming it gives the option for internal or external music source
Apr 08, 2009 | NEC Electra Professional ETW-16DC-2
Office NEC phone to be used at Home
This phone is a proprietory digital phone that only works with a KSU. You would need an IPK or Elite phone system to make it work. You would also need to program it. This is a business office system and that phone will not work unless it is plugged into the system.
Feb 05, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Cannot load the music Data base.
Music Database refers to the information you see on the screen (i.e. Artist, Album, etc.) The device needs some free space in order to create this list.
The device is either too full, or the database is corrupt.
First, try connecting to your PC and deleting about 10 to 15 tracks. Restart the device and see if that helps.
If not, Try formatting the device thru My Computer>Device name (U10)>Right Click and select format.(this will erase everything on the device)
Best of Luck.
Nov 03, 2007 | iRiver U10 Digital Media Player
Lands Phones Logo
61 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
