Question about Panasonic DVD-LS5 Portable DVD Player with Screen
HO2 error code at screen
Hello I have a Panasonic DVD-LS5 dvd player and an Code:H02 pops out. What can i do?
  • 4 more comments
  • Anonymous Jul 25, 2008
    Player tries to resd disc and gives error code HO2
  • Jenn Adcock Nov 12, 2008
    Disc Read Error H02
  • Anonymous Nov 16, 2008
    code H02 pops up
  • Anonymous Jan 07, 2009
    h02 pops up. cog cleaning to no avail.
    H02 pops up , spindle servo cleaning to no avail, disc does not start turning.
  • Anonymous Apr 18, 2009
    When i insert a DVD into my DVD-LS5 it reads it then pops up with a thing sayin CODE:HO2. Help!!!!!!!!
In line with the other Panansonic DVD players, the error seems to relate to the internal drive machanism getting stuck.
To fix you just need to carefully take the back off (disconnect power source first!), locate the drive cogs for the lens machanism and give the a couple of turns. Also a blast from a air can will help get rid of any dust build up. Pop the back cover back on and you should be working.
Looking at the other Panasonic threads on the site, this may happen on a regular basis especially as the unit gets older (and the crud builds up).
Posted on Jan 04, 2009
I am new here i have the LS5 with the error code:H02
Is there any solution to this problem? Other than replacing a piece that will malfunction with very little use.
Posted on Oct 08, 2008
Panasonic Model No. DMR-ES35V DVD Recorder error message H02
check it out this link, maybe can help you https://www.ifixit.com/Guide/Repairing+a+Panasonic+SA-HT810V+with+the+H02-H07+error/2708
Try to clean reading head from vhs player with isopropilic alcohol, maybe is dirt and give this error.
Good luck !
Dec 03, 2017 | Panasonic Dmr-es35vs DVD Recorder / Vcr...
Whate causes Error H03 on a PANASONIC DVD-LS5?
the is not able to read the disk that's why you get that error message.the cause of error reading disk are busted dvd lens and the spindle motor it is the motor that holding the disk and spins .first try to replace the motor you can buy that in an electronics supply store next is try to replace the lens
Jul 17, 2010 | Panasonic DVD-LS5 Portable DVD Player with...
H02
The HO2 message means the disc is not spinning,it's not about the lens
or the laser.It is easy to take the lid off.Once you do that,plug it in,open the tray with the remote,put in a DVD,close the tray and then give the white plastic wheel on the top a gentle little nudge to get the disc spinning.
Jan 30, 2010 | Panasonic DVD-LS50 Portable DVD Player
Technics sc-dv290
i once had a panasonic dvd player which displayed the same code H02 and used the same drive mechanism as your player. this turned out to be a worn spindle motor and once replaced, all worked fine. you may well have the same fault. hope this helps?
Oct 26, 2008 | Technics SC-DV290 System
DVD-LS5 portable
The spindle motor is defective.
Mar 21, 2008 | Panasonic DVD-LS50 Portable DVD Player
Panasonic DVD-RP56 Error H02
I read about removing the cover and spinning the motor by hand. It was suggested without power. I found that I had to have the unit powered up when I hand-spun the motor, then everything worked perfectly... we'll see for how long.
Feb 10, 2008 | Panasonic DVD-RP56 DVD Player
HO3
See my post on this http://www.fixya.com/support/t160505-hd03_error
Jul 28, 2007 | Panasonic DVD-LS5 Portable DVD Player with...
Panasonic DVD-LS5 Portable DVD Player with Screen Logo
930 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
