Question about Baumatic Washing Machines
Hi, I have a Baumatic Washing Machine (not sure of the model) and cannot find the filter. The machine gives off an awful smell which I am trying to fix
  • 1,462 Answers
You should find the filter but that is not what is causing the smell. common causes of smell are:
using liquid detergent - this smells like drains if used for a long period and leaves a horrid sludge in the tub. put on a boil wash with no clothers and use powder detergent
plumbed in under the sink and there is also a waste disposal unit. these pong!
no water barrier between the drain of the washer and the house drains
Posted on Jul 11, 2008
What does e33 mean on a baumatic washing machine
not saying this is whats wrong with it i just found this on the internet............hi, you need to empty the filter, ours does the same all too often. The filter is located bottom right of the machine at floor level, which is rather daft for an integrated applicance; we have to remove a whole length of plinth to empty ours. Be warned, a lot of gunge and water will come out so have towels at the ready, especially if you have a laminated floor. Turn the white slot with a a 10p piece......and empty. Not the most pleasant of jobs, but effective. Good luck!
Dec 11, 2016 | Baumatic Washing Machines
Zanussi aquafall smells awful
try 2...3 cups of raw bleach on final rince no clothes
Feb 22, 2015 | Zanussi Washing Machines
Hi, I have a baumatic BWMI 1206.1 washing machine. Once a cycle is started it never completes, I have to manually set to spin. Do you have any idea what could be wrong?
I'm not a washing machine repairman, but this sounds suspiciously like a worn-out or defective timer. Only guessing here, but perhaps (USD) $50 in parts plus the cost of the service call. This model seems to have a fairly good reputation and considering the cost of washing machines, I'd probably be inclined to have it professionally serviced. It doesn't sound like something you can fix yourself.
Also, most newer washers will not spin if the load of wet clothing is not balanced (evenly distributed) - of course you have likely checked this. Good luck
Jan 04, 2015 | Baumatic Washing Machines
Hi, filter grip on my hotpoint bwd129 has snapped off trying to open it. Any ideas how I can now get it off? The machine was not spinning properly & started to smell awful. Thanks
You where headed in the right direction-something is stuck and is burning up the belt-check appaliance pro on line for filter lid-then drill it and drive a striaght blade screw driver into it cheers Denny
Oct 15, 2013 | Hotpoint Ultima WF860 Front Load Washer
Bad smell in washing machine
Try using this cleaner on the washer. It works great!!
Jun 26, 2013 | Washing Machines
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Nov 13, 2010 | Washing Machines
Washer smells bad - musty
smell are normally due to 3 culprits
low temp wash , liquid soap , moisture
affresh washer cleaner may be worth a try
May 07, 2010 | LG WM0642H Front Load
Hi, I have a hoover front loading washing machine and inside the drum seal there was a lot of mildew as I accidentally left some damp tea cloths inside the drum and the machine wasn't used for 2 weeks....
Run your washer with 2 cups of bleach, maximum hot water. After it starts agitating for a minute, stop the washer & let it remain for 2 hours. Then continue the wash.
Apr 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Baumatic MEGA WDSS washing machine
go onto type baumatic megawdss washing machine, if this does not bring anything up scroll down until you see it in the listings. type in the code it asks for (this will be supplied underneath, its just to stop cumputers auto logging) and then download then manual. good luck
Jul 02, 2008 | Baumatic MEGAWDSS Front Load Washer /...
Washing Machines Logo
118 people viewed this question
Top Baumatic Washing Machines Experts
Einar Axel...
Einar Axel...
Level 1 Expert
Are you a Baumatic Washing Machine Expert? Answer questions, earn points and help others
