2003 Nissan Murano Logo
Posted on Jan 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
While driving there is a sound coming from the front end, it started soft , but as time went on it became loud. i thought it was the alingnment but it must be somting with the shaft that is conected to the wheel
Anonymous
Level 3:
  • Master 3,400 Answers
  • Posted on Jan 06, 2011
Anonymous
Master
Level 3:
Answers
3400
Questions
Helped
985987
Points
10767
Sounds like one of your CV joints is bad. There are CV joints (constant velocity) on drive axels, that have a rubber boot over them. If boot has torn and grease leaks out they start to rattle and get consistently louder. Have a reputable shop or dealer address it.
Loud thumping from under drivers side that started with a squeal.
16 costly car noises - Bankrate.com
www.bankrate.com/finance/money.../16-costly-car-noises-1.asp...
BankrateYou should not ignore certain thumping, banging, clicking and squealing sounds. These sounds often rear their heads or intensify whenever the driver takes ... Hissing or sizzling under the hood: Heard when the engine is first shut off, .... my rear right wheel makes a loud bang when switching from park to drive/reverse.
Sounds coming from drivers side front wheel - AnandTech Forums
forums.anandtech.com > Social > The Garage
AnandTech
Dec 1, 2009 - 21 posts - ‎10 authors
Sounds coming from drivers side front wheel The Garage. ... slightly left, I get a slight metalish-squealing sound coming from the drivers side front wheel area. ... but before I start the wild and expensive goose chase of bringing it to mechanics I ..... Those twoloud clunks when turning hard right give it away.
Ford Explorer Questions - Thumping from front end - CarGurus
www.cargurus.com > Questions > Ford > Explorer
CarGurusDec 22, 2009 - Thumping from front end - I have a hard thumping noise coming from ... without problem then I'll take a turn or something and it will start. ... I just recentlystarted having a rubbing and thumping and squeaking noise in the right front sidewhen driving ... Thumping sound coming from under the truck 4 answers.
Car Noises: Consumer Reports - Consumer Reports Online
www.consumerreports.org/cro/...noises/.../index.htm
Consumer Reports
Loud knocking noise from front right axle
YOU replaced the driveshaft ... or did you pay somebody else to replace it? Are you sure it was actually replaced?
1helpful
Hi i just put petrol in my subaru impreza 97 sport model as usual,and i started the car and i heard a loud bang noise coming from the exhaust the car made a loud ticking noise from the engine like a...
Sounds like your timing belt went bad.....HAVE IT CHECKED NOW>>>AND DO NOT DRIVE IT ANYMORE AS YOU MAY CAUSE FURTHER DAMAGE TO YOUR ENGINE.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
3answers
Loud roaring noise
jack up front of car get hold of tyre an see if u get any play if u do u may get away with nipping them up a bit
Front differential making a winding noise and ends in a loud thump.
sounds like you need your transfer case looked at and repaired.....that the only thing i can think of...hope it helps :)
1997 Dodge Stratus, unknown roar
Try replacing the front end wheel baring(s) If it is a roar that you can hear resonating from the windows, this is most likely it.
1helpful
Clunking and grinding noise
My 2003 F150 Supercrew would not engage in 4x4, it ended up being the shifting fork in the front end, cost me $200.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
