Question about Maxtor Hard Drive
Help me please
I have a hdd 80gb but use 2.5gb
  • 129 Answers
Please give more details and I will try to help
Posted on Jul 20, 2008
I have a 250gb seagate sata but when i put my 80gb IDE hdd it only detects in booting and in bios but after that if i open my computer i cant see my 80gb IDE Hdd and even in device manager my hard disk was...
there was wrong in the set up of jumper in your 80gb hdd. Look closely to the 80gb harddrive, in between the ide cable terminal and the power supply connector you will see 8pin terminals paired together and a jumper use to short the paired terminals. It is most likely that the jumper was configure to detect your hdd as master. If the ide cable you use for the 80gb hdd was also use for the dvd/cdrom drive then it will conflict with it if both jumper setting was set to master. See the description of jumper settings in the sticker of the hdd. Position the jumper to slave.
Reboot your system again and see if the 80gb finally appear in your system. When system boot upon detection of hdd, the primary master should be 250gb while your primary/secondary slave will be read your 80gb hard disk.
Jan 24, 2011 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
I need conect HDD 80Gb
Bios has almost nothing to do withthe HDD. You can connect it without any problem.
Oct 06, 2009 | Packard Bell DR724 Motherboard
Ihad a ACER Aspire 5052AWXMi, AMD Turion MK38,
yes you can upto 2GB and 160GB HDD
bkas your laptop having DDR ram, 80GB is ATA HDD,
Jun 22, 2009 | Computers & Internet
Can i transfer files from my 40gb ps3 to a 80gb ps3?
yeah you can by getting an external HDD. transfer the files from the 40GB to the external HDD and then plug it into the 80GB. and then just copy all the files from the external HDD to the 80GB PS3.
(yeah takes time but its the only solution since they don't allow the consoles to connect together.)
Jan 26, 2009 | Sony Playstation 3 (PS3) Console
Acer laptop please enter hdd error code password
Have a look at this site
http://www.petri.co.il/forgot_administrator_password.htm
Dec 20, 2008 | Acer Aspire 5500 5570-2609 Laptop
No booting
The problem is Operating systems are co-dependent on hardware.
If the motherboards, processors, ram, video adapters, etc don't match you would not be able to swap hard drives and expect to boot.
You could try pressing F8 on boot and try to access safemode.
If it does boot into safemode immediately it will want to reactivate windows.(because of all the hardware changes.
If it still can't boot, you may want to put the 80 gig in as slave to the 40gig and ghost the 40 gg hard drive over to the 80.
If you don't want to lose your data on the 80 gig then reboot with an xppro cd and reinstall windows in the same partition overlaying the installation on top of existing windows directory.
the new windows will have to be activated but all data will still be there.
Apr 15, 2008 | HP PSC 2210 All-In-One InkJet Printer
'Library Full' Error when transferring files to Zen.
the zen uses other areas for data storage and stuff.
best to reformat and not use so many folders.
Oct 21, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
SATA 80GB Seagate HDD
When your 80GB SATA Seagate HDD complains of bad sectors while booting, this is a sign of a failing hard drive. Today's hard drives will actually self-correct a certain amount of bad sectors before you get any kind of error message. If you are getting "bad sector" errors, this is because the drive has so many problems that it can no longer self-repair. You asked if this may have happened because you have formatted the drive many times. No, bad sectors was not caused by formatting. Your drive did not become "dead slow" because of the formatting. It became slow because your cpu now has to do much more processing to "work around" the bad sectors on the drive. You also asked if you could recover your hard drive to normal state. Please understand that once a drive shows bad sectors, it will not be long before the drive fails completely, at which point you will no longer be able to access anything at all on the drive. No, this drive cannot be recovered. Instead, you should save all the data you can from this drive, and you should do this as soon as possible, before it fails altogether.
Mar 27, 2007 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Maxtor Hard Drive Logo
27 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
