Question about HP Photosmart 2610 All-In-One InkJet Printer
HP 2700 serie all-in-one printer
Dear All,
I have this 2600/2700 HP printer that before a friend install windows vista it I could received and send fax. Now when I tried to install the drivers it say that it is not compatible with Windows Vista.
Is there a way to use with Windows vista? or I have to re-install XP for instance?
I would be grateful if you kindly provide your wise advice.
Regards,
JMC
My hp all in one 2700 will not sent a fax my grand son had his hand on my machine it now says that image on fax send report is set to off . how do i set it to on
Posted on Feb 26, 2009
  • 50 Answers
Go to hp website or driverguide.com and see if there is a vista driver for you printer
Posted on Jul 12, 2008
How to put printer back online
Try the steps listed here. It is a pretty solid troubleshooting guide for a printer showing as offline.
Sep 05, 2012 | HP Office Equipment & Supplies
Replaced old laptop with new HP-dv8t running Win 7 pro. Downloaded and installed HP Photosmart 2600 software for 64 bits. HP Solution Center says printer is not connected but I can print, scan. Under...
windows 7 install software for any printer automatically
i use hp 2100 and hp 1608 printers with windows 7 without installing their software
if your os is not recognizing the printer than you need to download theupdated software compatible with windows 7 of your printer
Feb 05, 2010 | Computers & Internet
Lost CD for lexmark 2600.Can it be installed without CD?
It can be installed with out the CD. If you are running windows VISTA, they have a pretty large driver bank. If you are running XP, you'll however need to download the drivers...
Link http://www.liutilities.com/device-driver/lexmark-2600-series/
Trust this sort you out.
Aug 13, 2009 | Lexmark X2600 InkJet Printer
HP Photosmart 2600/2700 series all-in-one printer problem
Check the expiration date on the cartridge, you may just need a new one. The date is printed on the side of the cartridge. They also just go bad sometimes.
Aug 11, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
HP Deskjet 3740 Series
You have to go www.hp.com select your region and product then you have to choose OS and now you can printer's driver for free for life.
Your problem will solve.
Aug 04, 2009 | HP DeskJet 3740 InkJet Printer
Hp4300 series disc won't work with my new hp window vista computer my printer is a 4315v
Please perform the steps given below and check if yuo are able to fax
1. Open a MS Word Document.
2. Click File -> Send to -> Recipient using a fax modem.
3. Follow the instructions given in the fax wizard. Ensure that you select the HP all-in-one as the fax program.
Now check whether you are able to send the fax.
OR
Try setting up the Fax once again
=== Fax Setup wizard ===
- Double-click on the HP Solution Center to open it.
- Go to Settings --> Fax Settings & Setup --> Fax Setup Wizard.
Complete the fax setup wizard and then, try to fax
Vishwanath V U
May 19, 2009 | HP Officejet 4315v All-In-One InkJet...
I HAVE A HP PHOTOSMART 2600/2700 SERIES ALL-IN-ONE WHEN USING THE SCAN PRINT IT ONLY PRINTS IS LIGHT BLUE
my scanner stop working on the HP Photosmart 2600/2700 and I can't find the disc to reinstall. I don't want to pay again for the disc
May 02, 2008 | HP Office Equipment & Supplies
Hp 2700 series all in one printer scanning issues
Hi .
Let me first explain that the scanning softwareis seperately loaded into the computer which is called as Digital Imaging. Try the step below:
1. try scanning from scanners and cameras - 2 errors might pop up if it does not scan - an error occurred communiating with the scanning device / no HP device detected.
2. start - programs - locate for a software loaded called HP Solution Centre / HP Director.Open the software if loaed and try to scan from there. If its not loaded then insert th installation cd and click on Install more software - full.
3. In HP solution Centre / Director click setting - scan settings - scan to ..... setup - see that both the columns of front panel and available destination list should be having some icons into it (you can add and delete from any column as desired - but none should be empty)
Click the link below to ssist you with relevant troubleshooting -
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=40990&lc=en&cc=us&dlc=en&product=420428&lang=en
If none of the above work then try uninstalling and re-installing the printer software all over again
Apr 13, 2008 | HP Photosmart 2710 All-In-One InkJet...
Using JETCET Print with OKI C5200n Printer
The OKI 5200 is a 'GDI' or Windows only printer and does not support PCL or PostScript languages.
Most if not all of the printers listed support either PCL or PS or an inkjet based language.
I'm afraid you will not be able to print the the 5200 without it's driver loaded on the PDA.
If the 5200 supported PCL you would be able to choose any of the
Color HP Deskjets.
Oct 15, 2007 | OKI C5200n Laser Printer
HP Photosmart 2610 All-In-One InkJet Printer Logo
252 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
