Question about Nextar Q3 GPS Receiver
Nextar I KEEP GETTING FATAL APPLICATION ERROR! ITRAVEL ALL THE TIME,I NEED THIS PROBLEM FIXED! IT WILL PULL UP THE STATE BUT WILL NOT LET ME PUT IN A ADRESS
Chris,
I have the EXACT same problem and am off 'warranty'...I have had Nextar replace my GPS unit twice now. Same thing. Argh! If you get any luck with a repair, pl let me know!
Posted on Jul 11, 2008
When i try to use the navigator it comes up with a gray box that says fatal application error application adeona.odysseycore has performed an illegal operation and will be shut down. if the problem...
This indicates that the unit suffered internal hard drive failure. Unfortunately support is not available at this time as both the nextar website www.nextargps.com is down and their customer service phone number does not work as well. You will need to get a new GPS unit,
Sep 24, 2011 | Nextar 43NT GPS Receiver
Need answer for fatal error
Look for the reset button. And then reset. And as it does not help connect to your computer and upgrade software
Nov 30, 2009 | Nextar X3-03 Car GPS Receiver
Gps freezes , wont load up,and fatal application error comes up
Your getting fatal error's ? Your going to need to have this services if it freezes! There is not a easy fix for this one..
May 24, 2009 | Nextar X3B GPS Navigation System
Nextar S3 Application error in Navigate
You need the contents of the \ResidentFlash directory. You'll need to rename the MobileNavigator folder and the four gpspara files (0,1,2 and 3) then load the new folder and files from a device that is working. You will then copy your old \ResidentFlash\MobileNavigator\UserData folder from your backup to the new folder to regain any favorites you might have created. You should then be good to go. I use ActiveSync to talk to the S3. I'm not sure how else you might attach to it.
I have the ResidentFlash files but I have no place to post them. The files zip to about 5.3 MB.
Feb 27, 2009 | Nextar S3 Car GPS Receiver
I have poblem with my gps
i have a nextar w3g, and this gps is running with windows CE, is possible the problem to be a virus or some othe errors you can find in every other windows sistems.
Aug 30, 2008 | Nextar X3B GPS Navigation System
Intellinav.exe application error
Did you try the switch on the back of the GPS? Turn off on the front, turn the switch on the back off, then on. This has worked for me numerous times.
Jan 06, 2008 | Nextar Q3 GPS Receiver
HELP!! I keep getting Fatal Application Error. Application entellinav.exe has performed an illegal operation and will be shut down. If this problem persists, contact the program vendor. Program: Intellinav.exe
Exception: OxC0000005
Address: 00125D64
Oct 11, 2007 | Nextar Q3 GPS Receiver
"Fatal Application Error"
This problem may occur if the user allows the batteries to discharge to a state where the MobilePro must shut itself down. This state may cause the system storage memory to become unstable requiring a "hard" reset after the system has been fully charged again. Failure to perform the hard reset may result in data loss at a later time. The user manual states that if you receive a message indicating that the batteries are low, immediately connect the AC adapter to the device. The solution is to perform a "hard" reset after fully charging the internal batteries, and then install the service packs, software updates and user software.
Sep 14, 2005 | NEC MobilePro 750
Nextar Q3 GPS Receiver Logo
87 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
