Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Noise from tv
Last nite when we turned on the tv there was a medium pitch/whinning noise that caused us to turn up the tv. Upon turning off the tv the noise lasted 3-5 sec like a motor winding down. I checked the 2 small cooling fans and they seemed ok. It seems to be coming from the mirror area in front of the dlp lamp.
  • Pharmmd Sep 30, 2008
    I'm sorry I hadn't gotten back to you; I have already installed a new color wheel and the problem was solved.
    Problem Solver:
  • 6 Answers
I had the same problem with a 5065. I purchased and installed a new color wheel and that solved the noise problem. The color wheel has a bearing that gets "dry", and when it fails it does sound like a fan bearing.
Posted on Sep 28, 2008
Cause of whinning noise when trying to start xg350 motor does not turn over. Not a clicking sound but a high pitched whinning sound.
1) Most likely.
Your starter is an electric motor, with a gear on one end.
Mounted on that same end is a part called a "Bendix" or an "overrunning clutch".
When that just mentioned part fails, the starter will not engage the flywheel, and you will get the noise of which you spoke.
2) Less likely.
If your timing belt fails, he engine will turn over at a high rate of speed, but it will not start.
God bless your efforts.
Jan 19, 2018 | Cars & Trucks
When turning on samsung hln467w, lamp light blinks, screen stays dark, can hear audio from tv show, but then a high pitched sound begins for a few seconds. The tv turns on and off for a few cycles with the...
The tv have a colors wheel,have a whinning high pitch sound,mean colors wheel is warping not spinning right any more.The colors wheel is dead,must be replaced.The tv have high pitch sound,shutdown the projection lamp.The projection lamp might be dead or not?Not yet determine dead or just shutdown by the nonfunction of the colors wheel.
Aug 05, 2010 | Samsung HLN467W 46" Rear Projection HDTV
HAVE 2004 JEEP GRAND CHEROKEE,HAS LOW WHINING NOISE FROM LEFT FRONT. CHECKED BRAKES AND ROTORS AND ALL IS OKAY. DRIVES NORMAL AND DOES NOT SEEM TO BE BEARINGS. sTARTS AT ABOUT 20 MPH AND STOPS AT 50 MPH.OR...
the whinning noise is definalty a signiture of the bearing, and they do on occasion start making the noise long before other systoms of a bad bearing appear. There is really nothing else in the suspension that moves in a manner to cause the whinning pitched sound, other than the axel, but there signature has allways been a clicking around turns, so id definatly look cloesr at the bearings......good luck
Mar 21, 2010 | Jeep Grand Cherokee Cars & Trucks
Rubbing/grinding noise
Usually the strut bearing will make this noise upon turning a corner and hitting a rut or pot hole when turning. A wheel bearing will make a low pitched whinning sound constantly
Jan 16, 2010 | 1998 Ford Ranger SuperCab
Loud whinning, high pitch noise coming from TV when turned on.
The color wheel is likely bad and needs to be replaced.
Check this link it is for a samsung TV but the same principals apply
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Oct 17, 2009 | RCA R52WM24 52" HDTV Projection Television
Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Jan 06, 2009 | Samsung DLP HL-P5663W 56" TV
High pitched noise
I am about to post a in depth guide about how to fix this problem. It's because a capacitor inside the TV has blown which causes the buzzing high pitched noise. It's really easy to fix however and only costs about £1 / $2 to sort out.
You can read a similar guide here http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen but I will shortly be uploading a guide on the buzzing problem!
Dec 22, 2008 | Polaroid FLM-3732 Television
Trouble turning on tv. High pitched noise/click.
The mainboard might have some loose components, or cold solder , or may be the filter capacitors are becoming faulty. Yes it is worth repairing, bring it to the repair shop. Cheers.
Nov 25, 2008 | RCA Televison & Video
High Pitch Noise
there has been a few cases of a coil in the cuircit whinning. and there is a simple fix...applying some silicone onto the coil to dampen it. the coil is ll037 on deflectin board. location m2 a black compnent with coil of copper wire wrap around it. thats my initale thought. it may be more. since you still have a picture.. any questions email me at willie@fordtv.com
Dec 10, 2007 | RCA D52W19 52" Rear Projection Television
High pitch noise
what you are hearing is the mechanical vibrating of coils & or transformers in the tv. 1st and easyest is to hot glue the parts that is making the noise down. if that does not work, removing & reinstalling the part is next. the last is replacement. the most likely parts causing is the 1. horizontal linearity coil, 2. the run or switch mode transformer, or 3. the flyback transformer. good luck.
Jan 09, 2007 | Zenith C27F33 27" TV
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
183 people viewed this question
Henry  Thomas
Henry Thomas
