Acer Aspire 5735 Notebook Logo
Anonymous Posted on Jan 06, 2011
My notebook screen is almost dark when check it diagnose that backlight is defective. I just to ask if how the whole payment of repair and should i go. The model of my notebook is acer aspire one
Computer Links
Level 3:
  • Acer Master 2,386 Answers
  • Posted on Jan 06, 2011
Computer Links
Acer Master
Level 3:
Answers
2386
Questions
Helped
718477
Points
7718
Hello
The CFL (cathode florescent light) of Acer Aspire One is 8.9" which will cost around $10 and same will be the repairing cost, you will be expend around $20-25 total.
if it has warranty then go and claim its warranty.
i recommend to repair the system from nearest Acer Service Center if you have.
Hope this helps if so do rate the solution Good Luck
  • Computer Links Jan 06, 2011
    Oh sorry, it has LED not CFL which may cost little higher i guess
The screen for my note book is just dark.
In the screen of laptops , there is a part who is called , backlight who gives light to the screen . When this part is defective, The screen went dark , Than mean you have to change tha backlight of your laptop. Do you how?
Chechttp://www.fonerbooks.com/laptop_5.htmk this link:
My screen is dark
You could have a defective LCD screen, If the laptop appears to be running and the hard disk is spinning but the screen is dark then, to determine if you have a LCD screen or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
8helpful
My notebook (Fujitsu Lifebook S6000 series) screen back light just died. How do I fix it and what type of backlight do I need to get?
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
2helpful
Dim display ... no backlight
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
1helpful
Lcd screen not working properly
you need do following steps:
1) to make sure there is messages showing on the dark LCD screen. even nothing backlighs.
2) to make sure the inverter is defective, change other parts (same model) to test it,reference: http://www.fonerbooks.com/laptop_8.htm
3) if still dark with new inverter, you have to change CCFL lamp at back of LCD panel. reference from:
4) also you could change a LCD panel if the CCFL lamp damage which you can not do fix.
hope help you fix it. any question please ask me.
Problem with dark LCD screen and accessing the the LCD ribbon that I think is loose
You could have a defective screen - a defective inverter or a CCFL lamp.
My acer aspire 4320 have no light in the display
  • Picture flickering with dim display.
1helpful
Friend's Laptop Screen has become too dark to work with
3helpful
Acer screen looks dark?
1helpful
Dark monitor screen with hidden display in the dark.
You most likely have a defective CCFL backlight, it may have the following symptom:
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
