Question about Optics
Meade etx-105ec Hello, the major problem wiht the scope is that the focus whell does not work in manual or automatic mode. It was not working well, kind of stiff, but now the adjusting knob just backs out of the housing tube and when you look though the eye piece nothing can be viewed at all! I phone Meade and they said they no longer service this unit and it is past it's service life?
    Genius:
  • 1,027 Answers
You could try: P. CLAY SHERROD
ARKANSAS SKY OBSERVATORY
#73 Tanyard Springs Road, Petit Jean Mountain
MORRILTON, ARKANSAS 72110
www.arksky.org
who offers supercharging and repair services.
drclay@tcworks.net
Posted on Jul 13, 2008
Meade ETX-90EC . i cant see through the telescope at all and the focus doesn't work at all. their are sounds if pieces "clanking" inside when it is adjusted into view
The flip mirror has fallen off inside the scope. This must be returned to Meade for repair. Here is their customer service phone number:
http://www.meade.com/support/index.html
Sep 12, 2011 | Meade ETX-90EC (325 x 90mm) Telescope
When I look through the lense everything is just black
Take the scope outside during the day time. Put the eyepiece with the largest number written on it into the TOP diagonal. There is a "flip" switch on the back that changes between the rear photo port to the TOP eyepiece port.
Flip it one way or the other until you can see light through the TOP eyepiece. Practice focusing on a distant object during the day time.
Here is the manual:
http://www.meade.com/manuals/TelescopeManuals/ETXtelescopes/ETX-90%20w-autostar%20man.pdf
Dec 15, 2010 | Meade ETX-90EC (325 x 90mm) Telescope
My focus knob does not work correctly, is this easy to fix?
There is a tiny set screw on the side of the knob. Make sure this is tight, and the knob is not just spinning around and around.
There is also a small rod inside -- that the focuser attaches to. If tightening the setscrew does not fix it, you will need to remove the focuser and see if it is detached from the rod. Make sure the scope is tilted BACK with the front of the scope UP a little or the mirror will slide to the front and possibly break.
This web site has lots of repair pictures--
http://www.weasner.com/etx/menu.html
Aug 09, 2010 | Meade ETX-125EC (500 x 127mm) Telescope
Need a focus knob for a MEADE ETX-70 TELESCOPE
You can try calling Meade here:
Apr 15, 2010 | Meade ETX-70 (240 x 70mm) Telescope
Need schematic for a Meade ETX-105EC telescope
Many schematics and instructions located at the Mighty ETX web site:
also check out this ETX "tune-up" web site:
http://www.weasner.com/etx/techtips/etxtu.htm
Good luck.
Dec 30, 2009 | Meade ETX-105EC (420 x 105mm) Telescope
I have a Meade ETX 60. The internal threaded rod that focuses the telescope is broken. Can I get a replacement ? I already have this taken apart and have removed the rod.
You can call Meade, they might sell you a rod??? Usually they want you to send the scope back to them for repair.
Nov 08, 2009 | Meade ETX-60 AT Telescope
Can't focus my meade etx-125. have turned focusing control more than 80x in both directions. Is there an stop on the focusing system. Originally had the electric focusing system on the scope couldn't focus...
yup there is a mechanical stop to prevent you from cracking the mirror by retracting or extending it too far.. once you break the pin off it needs to go to the factory for dis-assembly as they have to remove the primary to get to it and realign it my 105 did same thing....word of advise use a cable extender for focus not an electric focuser they fail to tell you that it can over run the built in stops making your scope useless...i may be mistaken but i believe the max turns is 25 or about for end to end focusing adjustment on the 125
Sep 28, 2009 | Meade ETX-125EC (500 x 127mm) Telescope
Can't focus
Unless you can find another "used broken" ETX of same model-- to get the focus off of-- your only recourse will be to send it back to Meade for repair--
Here is their customer service phone number-- and their manuals
http://www.meade.com/manuals/index.html
http://www.meade.com/support/contact.html Contact number
Feb 10, 2009 | Meade ETX-125EC (500 x 127mm) Telescope
Etx-105ec + autostar
Dear Roger,
I think moto gear is dameged.Please check or restart your unit.
Thanks.
May 19, 2008 | Meade Optics
MEADE TELESCOPE
With the power off, check the connectors are properly plugged in at both ends. Like a network cable, the clip bit should spring out when properly located. Then power on. Within a couple of seconds there should be a long bleep and the display will show a startup message
( A U T O S T A R and Version number).
If that doesn't happen, and the batteries are fresh (and inserted the right way round), try connecting the curly cable the other way round (apparently that sometimes fixes it - personally I reckon it may just give another chance to plug it in correctly). If the doesn't work, you may have a faulty cable or a faulty Autostar or a faulty control panel. Take it back to the reseller to sort it out!
Apr 18, 2007 | Meade ETX-105EC (420 x 105mm) Telescope
Optics Logo
78 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Are you an Optic Expert? Answer questions, earn points and help others
