Question about JVC AV-27D302 27" TV
JVC AV-31BMS clock stopped
Clock stopped functioning.
Volume display won't go away--nor will any other display, like time (which is stuck at original setting), channel, etc.
Must keep pressing "Display" every time I change volume, or Mute, to clear the displays.
Does the clock have a replaceable battery? Accessible?
(TV works fine otherwise, in my mid-80s not likely to replace it!)
Thanks
jvmx@comcast.net
  • jvmx Jul 10, 2008
    Sorry I was not clear. Two things simultaneously stopped working:
    1) The Volume bars will no longer go away after a few seconds like they used to; they stay on and clutter the screen indefinitely. This is my biggest complaint.
    2)The TV's Time/Date froze at the time/date set for it--will not advance. They can be reset to a different time/date but then will freeze at that setting.
    To make the volume bars go away after I change volume I must click Display.
    - When I click Display to erase the volume bars, the (frozen) time/date/timer box comes up so I must click Display again to get rid of that, then the (frozen, incorrect) current time alone comes up, so click again, then channel number shows, then click yet again (whew, 4 clicks) to finally get back to an uncluttered screen. I MUST GO THRU THIS ROUTINE EVERY TIME I CHANGE VOLUME OR MUTE !
    (-About the "clock:" I presumed there is a clock circuit in the TV that controls both of these functions and that maybe it has a removable battery like PCs have. Just a guess.)
    Brigadier General:
  • 6,966 Answers
Based on your description, two (2) possibilities:
1. The JVC has a feature called TV Guide+. If yes it has one and it is engaged/enabled, then the TV will download TV program information and the current time, hence the clock cannot be adjusted manually. Pls try to disable this feature;
2. The logic circuitry controlling your OSD (on screen display/menu) would need looking over. Often this would just require basic cleaning of the circuit board and the components with special focus on the processor IC. After dust removal, a spray of electronic contact cleaner would help. There are occasions that a limiting resistor or a filter capacitor in the +5VDC rail would require check/replacement.
In some instances, it could be simple a case of weak batteries on the remote.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 10, 2008
  • 2,071 Answers
When you are entering the service mode you can set the clock.
With TV powered ON press: [DISPLAY] and [VIDEO STATUS] on the remote at the
same time.
-or-
Press the [SLEEP TIMER] key and set the SLEEP TIMER for "0" MIN. While the
SLEEP TIMER information is still on screen, press the [DISPLAY] key and [VIDEO
STATUS] key of the remote control unit at the same time to enter the SERVICE
MENU.
Exit the service menu by twice pressing the [EXIT] key on the remote.
  • 6,487 Answers
It seems more like the protection circuit is being activated.
This activation is caused whenever there is a short circuit or high current fault anywhere within the set. It must be defeated by a tech in order to find out what is going on. Typical causes for this activation are: high voltage failures, shorted down deflection amplfiers, power supply or audio amplifier defects.
Judging from the age of the set you may wish to consider whether to repair or replace. A new 27 inch set of this caliber is around $159 and up. Repair costs may be as much or more than this.
Hope that helps.......
    Guru:
  • 1,894 Answers
Do you mean the time display??
or which clock?
please be clear
Jvc cd player model kd-g120,how do i set the time?
Press and hold 'SEL' press down arrow until CLOCK H is displayed rotate Volume knob to adjust press down arrow once to display CLOCK M rotate Volume knob to adjust press 'SEL' to finish. Reference pages 6 and 10 in this link to your JVC KD-G120 Instructions Manual.
http://resources.jvc.com/Resources/00/00/91/GET0330-001A.pdf
Nov 18, 2009 | JVC AM FM CD DET FACE CAR STEREO
The clock display came on and i can't get it off...
Most clock functions are accessed from MENU ... SETTINGS... TIMER CLOCK ... (Location)... ( Display Y N)
Some options may differ slightly between models But generally along those lines.
I like the clock and wish it would display but mine seems to have a mind of its own It displays somedays and not others, displays on analog and not on Digital on Wednesdays! havent found out why that is either!
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 14, 2009 | JVC AV-32D303 32" TV
Set clock on radio
Hello atesha23,
Below is the step-by-step procedure for setting the JVC clock. Please note that after you have entered the PSM mode, if you have not pressed a button for about 2 seconds, the radio will automatically exit the mode and return to normal operating mode. In that case, you must restart PSM by holding the "SEL" button until the display changes.
(1). Enter the PSM mode by pressing and holding the
SEL button until the display changes.
(2). Use the rocker switch left/right until "CLOCK
H" is displayed.
(3) Set the clock hours by turning the volume
control up/down.
(4) Press the rocker switch again until "CLOCK M"
is displayed.
(5) Set the clock minutes by turning the volume
control up/down.
(6) Press the SEL button to finish and EXIT.
Hope this helps.
Mar 31, 2009 | JVC KD-G140 Car CD Player
Cannot set clock on my JVC KD-G335
You need to hold the sel button down for a little while then it will change displays thats when you use youe right seek button until you hit the Clock H to change the clock hour or Clock M to change the minutes when you hit it you use your volume control button to change the time.
Jan 04, 2009 | JVC AM FM CD DET FACE CAR STEREO
The digital clock on my 30"JVC is showing in the bottom of screen
The menu screen does not function the display. Without the original remote or a universal remote that does not have a display button, try unplugging the television for at least 2 minutes or more and plug the tv back in. This should reset the tv display. If the universal remote has a display button, depress the display button until you get the desired display results. Reference the user guide below for the display button.
neww.gif JVC AV-36D503 36" TV - User Guide (page #43)
Dec 20, 2008 | JVC AV-36P902 36" TV
On Screen Clock Display
Without the original remote or a universal remote that does not have a display button, try unplugging the television for at least 2 minutes and plug the tv back in. This should reset the tv display. If the universal remote has a display button, depress the display button until you get the desired display results.
Nov 28, 2008 | JVC AV-36D503 36" TV
Can't get rid of clock dispaly
Without the original remote or a universal remote that does not have a display button, try unplugging the television for at least 2 minutes and plug the tv back in. This should reset the tv. If the universal remote has a display button, depress the button until you get the desired display results.
Nov 05, 2008 | JVC AV-36D503 36" TV
Clock
Press and hold the 'select' button until a menu displays. Use track forward to cycle through the menu and the volume knob to cycle through options of each menu. You will find 'Clock H' and 'Clock M'...set accordingly.
Apr 13, 2008 | JVC KD-G310 CD Player
Clocked Stopped on bottom of screen
With a Comcast remote, press TV at the top of the remote. Next, press Info and a menu will appear with several options including Clock Stopped. Press Info again one or more times and the Clock Stopped message will be removed from your screen.
Oct 09, 2007 | JVC AV-27230 27" TV
How do I set the clock and preset stations.
I also had some problems to figure out how to set the time, but here is the sollution i came up with:
1. Press "Clock/Timer" until a clock and "on" starts to flash in the display.
2. Turn the "volume/caleido jog" to choose which function you want to set (alarm on/alarm off/time).
3. Press "clock/timer" again.
4. Change time with the volume wheel.
5. Press "clock/timer" when you are finished.
Apr 10, 2007 | JVC RC-QN2 Cassette/CD Boombox
JVC AV-27D302 27" TV Logo
142 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
