If the workplace is someone you work for then yo may have to go through your IT to allow this software, but if you are the Co. then your'e the boss, but it could still be to do with anti-virus and firewall preventing connection.
SOURCE: Username and password
You will probably need to reset your router to get access to it again with a known username and password. BEWARE THIS WILL PROBABLY RESET ALL CONFIGURATION INFORMATION AND YOU WILL BE REQUIRED TO COMPLETELY RECONFIGURE YOUR ROUTER INCLUDING POSSIBLY ISP SPECIFIC INFORMATION. If you cannot do this including knowledge of all the required answers and proceed anyway you may lose access to your internet connection until this is successfully done. Proceed beyond this point AT YOUR OWN RISK.
Follow the link below to determine the model of your router
Router Link
As your profile indicates you are from Australia -- there is a link at the top of the page for a DI-624+ that may also apply to you.
If this does not work or your model is not a DI-624 as indicated try the following Assuming you have a DLINK router
Go to www.dlink.com
Choose your country
Choose Support
attempt to access product information -- if your model does not appear there may be legacy products link on the page to choose
Download your user guide.
The following link may provide an emulator for your router to allow you to preview the configuration process (this does not configure your router. You may have noticed this emulators link earlier when accessing product information above, if you could not use the link.
Emulators Link
AGAIN PROCEEDING BEYOND HERE CAN RESULT IN THE LOSS OF ACCESS TO YOUR INTERNET SERVICE -- proceed with care.
Doing this will may require you to configure specific ISP required
entries into your router to restore internet access, I do not know what
those requirements are now. I may be able to research them if you
provide information about your internet service provider such as their
web site or help/support web site. Be aware that you will require all answers for this before doing it as you may not have internet access again after starting this until you successfully complete this. With all the previous warnings in mind you can consider the following step.
Using the instructions in the user guide you can probably reset your router and get access to the configuration.
SOURCE: Don't know the username to "http://192.168.0.1" router Level One.
try username blank if you didnt set any username.also password blank. or if you have set a pass use that. have you changed it from the default ?
only way to get in your router if you dont know your username and password is to reset it.. sorry.
SOURCE: When I enter "http://192.168.0.1" it's asking me username and pas
hi
for the username use administrator and ofcourse the password that u have set
cheers
pls rate if it was any help
SOURCE: I want to turn wireless option off
the default username and password on them is
username: admin
password: password
Testimonial: "this worked as soon as I tried it. Thanks for the help! "
SOURCE: username and password for dlink Im trying to set
If you are trying to access the router itself via it's IP address (192.168.X.1) where X is usually 0, 1 or 2...
The username and password should both be admin
if not, try no username with admin as the password, or try admin as the username with no password.
