Question about WYSE 00-085-07 85 Terminal Amber
Wyse 85 monitor
Monitor takes about a minute from power up to bring up the screen.What could it be?
5 Suggested Answers
RoryMRP
  • 111 Answers
SOURCE: the wyse 50 terminal does not work properly
Wyse 50/60/150/160 monitors were my specialty!
From what you were explaining it seems to me that you have a bad internal battery and it needs to be changed and a factory reset/ calibration needs to be performed.
I can repair wyse terminals at my facility if you like. The repair cost is not that high and we can also perform the regular repair and adjustments on all wyse monitors if needed.
Please contact me if you have any questions.
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Posted on Jul 01, 2009
  • 1684 Answers
SOURCE: hp f2105 monitor works for about 1 minute and then
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $45 plus shipping. If your problem is not the capacitors then it would be the backlights and that is much more difficult to replace.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 08, 2009
SOURCE: LG MONITOR WAS BLINKING WHEN THE POWER WAS ON, AFTER 5 MINUTES ITS BLINKS SLOWLY AND STARTING THE MONITOR
Change two electrolyt capasitor 1000u/16V to your power supply.
Posted on Feb 04, 2010
SOURCE: I HAVE A NEOVO E-19A MONITOR. ON BOOT UP SCREEN
http://www.devicemanuals.com/guide/LCD/AG%20Neovo/AG-Neovo-S-19A-LCD-Display-English-Owner's-Manual-T1RjMU9Uaz.html
dlc.sun.com/pdf/820-0119-10/820-0119-10.pdf
http://www.scribd.com/doc/3082274/AOC-LCD-Monitor-786LS-Service-Manual
Use these training manuals, to troubleshoot and sort your issue out.
Above is a user manual, and a service manual, in the service manual, are the troubleshooting steps to perform to isolate the problem, and hopefully repair.
Posted on May 25, 2010
Hyundai monitor on for 5 minutes and screen goes black
Have you ever opened up the monitor to clean the dust out,it could be your heating up and then letting it sit will bring it back.If your unsure how to do this ask a tech.
Apr 21, 2017 | Hyundai X224W
No screen after 5 minutes
The picture board on your monitor is bad, since it goes off after few minutes and the power led or button is on, it means the picture board of your monitor has developed fault.
I would advice you replace the picture board on the monitor, this should cost you between $65 - $85.
Take care.
Jul 06, 2010 | Soyo DYLM2286 Monitor
When I plug up the monitor and power it on, the gateway sign appears and then the monitor just shuts itself down again but the power light is still on what's wrong?
f7476e0.jpg597f7d2.jpgfdb9d8d.jpg1ad0e84.jpga405f1b.jpg6e6f6c3.jpg2be5895.jpgWhypaythem is correct....again. The bad capacitor is C862 on the inverter board ( power supply ). The bad capacitor is a 1000uf, 25volt.b970f86.jpg
Oct 15, 2009 | Gateway FPD2275W LCD Monitor
No display on moniter
Check the following if you don't see a green light on the monitor
1-Make sure Power cord of monitor is plugged to the wall outlet directly and the other end to the monitor (don't use a powerbar for this test)
2-Make sure monitor is turn on
If you see an amber light on:
1-Make sure the data cable is plugged-in snugly to the monitor and to the video card.
If after you have checked the previous steps you still have a blank screen:
1-Check the adjustments and color settings of monitor
2-Plug the monitor onto another computer to test it
If the monitor works onto another computer, check your video card.
May 03, 2009 | Computers & Internet
Monitor flickers with changing colors making it almost impossible to see anything, it started & stopped for a while then after maybe three weeks after it started again ! I tried disconnecting & changing...
I suggest upgrading the OS on these problem terminals to the latest on the wyse website. It might be an incompatibility with the monitor and terminal (might have been fixed in later builds), in which case you will need to log it with Wyse directly, as they will need to test this.
Chances are though you either have a faulty monitor cable, a faulty unit, or faulty monitor. Perhaps even a combination of more than one of these above problems. Try to rule out each bit of hardware before blaming anything in particular.
Try a few different monitor resolutions, colour depth and refresh rates too. Cant hurt :)
Mar 31, 2009 | WYSE Winterm S30 Network Terminal
The wyse 50 terminal does not work properly
Thanks
Rory Cardenas
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Mar 18, 2009 | WYSE 50 Terminal
Monitor takes a long time to wake up
replace 2 caps 1000uf each 16 volt
I purchased 5 of these babies (new) at the same time and 3 of them had this problem
Sep 25, 2008 | Sceptre X9G-NagaIV 19" LCD Monitor
Wyse 1200LE - error - out of frequency
The display settings are not valid with the monitor. Either you are using a new monitor or you have changed the settings. If you are using a new monitor, swap with the old monitor and configure the appropriate refresh rate for the new monitor.
If you have changed the settings you may need to either reset all default settings, or setup a parallel unit and use the same key strokes to change the display settings on the problem unit.
Cheers..
Apr 02, 2008 | WYSE Winterm S30 Network Terminal
No display in monitor
This may be the problem with the WYSE driver. Ensure that correct driver is intalled and colour profile is compitable. Syncmaster is auto detected by window based OS.the message "Sync out of range" comes due to improper out put video signal.
Jul 24, 2007 | WYSE Winterm 3235LE Network Terminal
Monitor shuts down after 20 minutes
Sounds like the monitor is overheating. The internal power supply maybe going bad. Ray
Jun 19, 2007 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
WYSE 00-085-07 85 Terminal Amber Logo
57 people viewed this question
Top WYSE Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
Tim Hunt
Tim Hunt
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
