Question about Back to Basics Smoothie Elite Work Top Blender
I have the tsk-9368ap blender model. Before I blend, I lock the blade in place on the bottom, while I am blending the blade comes loose, and whatever I am blending starts coming out of the bottom, I'm not sure if I might be missing a part? And if so where does it go?
  • kaelexis Jul 10, 2008
    The picture that is shown is not the correct blender
  • sheena1953 Aug 14, 2008
    I have the same problem. I tighten the bottom and when I blend it comes loose and the stuff comes out ...very irritating! Can you buy a new rubber seal?
  • 8,596 Answers
Kalexis - there is no such thing as support for the Durabrand TSK-9368AP - Wal-Mart decided that the products were so cheap that people would buy a new one if it broke. What I would do is take your blender into an Ace or True Value Hardware store, and have someone find a generic gasket that will fit your blender.
sheens1953 - the seal/gasket for the Smoothie Maker Elite can be found here:
http://www.focuselectrics.com/finditem.cfm?itemid=4308
-Tha Mp3 Doctor
Posted on Mar 25, 2009
2 Suggested Answers
SOURCE: Durabrand blender model number tsk-9368ap
You just bought a bad blender. Get a different model
Posted on Jul 25, 2008
How can I get a relacmenmt pitcher for my TSK-9368AP blender?
It is a Walmart item from China. Not good quality. Take it back and complain.
Some information here
http://www.complaintsboard.com/complaints/durabrand-blender-tsk-9368ap-c43152.html
Sep 21, 2015 | Blenders
My blendtec blender doesn't blend as well as it once did. The motor seems to be running fine, but I am not sure if the blades are spinning properly.
You have already found what is the problem the blades.
The blades after a lot of working hours with ice they have mainly three problems.
One the sharp adjes have created a lot of teeths and are not so sharp any more so the blending is not smooth anymore.
Second problem they have loose a title so they have move from corect place some milimeters and this change the wave motion and again the beleding is not so smooth as before.
Third the blades are secure on an axis which is located in two bearings which have een wearing out so the rotating motion of the blades again is not so smooth as before.
So if you are not able to fix the blades kit or to find someone in your area to do it profetionaly and cheap one good idea is to buy a new blades kid.
Good luck
Aug 17, 2010 | Blendtec ABC Work Top Blender
My blender won't blend. Everything turns but the blades.
I have no idea what might be turning, but likely you do not have the blades seated if the shafts don't turn... IF the shafts turn, the welds or swaging of the baldes to the shaft have probably come loose due to overloading.
Apr 07, 2010 | Bosch Blenders
Rubber washer for Model TSK-9368AP Blender
I just fixed mine with a rubber hose washer. I had to cut the washer in half because it was too thick, but it stopped the leak!
Mar 29, 2010 | Blenders
My jugs are leaking too at the bottom. If anybody finds the replacement jugs somewhere please let me know. I have a double smoothie maker model 5787. Thanks! email me at javstarz@hotmail.com
My blender would do that if I didn't screw the jar on firmly enough. Sometimes the action of the blades will even loosen the bottom from the jar during blending, so I always hold the jar handle while the blending is going on. That way if it starts to undo, I can twist it back tight. Before I learned that trick I had smoothies leaking out the bottom - what a mess! Also make sure you put the gasket/seal on in the right order. If it's in the wrong place it won't seal correctly.
Sep 06, 2009 | Blenders
Poor function of my Oster classic blender
Yeah, the blades probably need to be replaced. The replacement blade assemblies for most models can be ordered directly from Oster - their phone # is 1-800-334-0759 - you have to go through an elaborate menu tree to get to the right place.
Apr 03, 2009 | Oster 4093-8 Osterizer Classic Blender...
Waring Pro Blender is leaking and blade assembly is loose
I know this is an old, old post, but I could not find a solution anywhere, so hopefully this will help someone. We have a model 51BL25, similar to scottman55's blender, and it had the same problem. There are two separate nuts in the blade assembly. One holds the blade on, and the other holds the seal tight. When the latter gets loose, the blender shakes and leaks.
To fix it, first you have to remove the top nut holding the blade on. I had to get in there with pliers, but a ratchet with an extension would be perfect. This nut is right-handed ("normal"). Once that nut is loose, you can remove the nut and the blade. You will also want to remove the washer immediately under the blade (take note of which side goes up).
Now, you can pull the whole axle out by the wheel on bottom of the blender. This exposes a really thin, flat nut. In my case, this nut had come completely off, so nothing was really holding the seal together at all. Again, make sure you remember which direction the nut goes -- it is not quite symmetrical. That nut is what comes loose when the blender starts leaking. By the way, it is a left-handed nut, so it screws on counter-clockwise ("backwards"). Screw it in tight, then put the rest of the blade assembly back together, and your done. If you have the right tools, it should take only maybe 5 minutes.
Depending on your problem/model, this may or may not solve your problem. Hope it helps!
Jan 28, 2009 | Blenders
Jul 10, 2008 | Blenders
Blender performes poorly, if at all
Hi, cauliflour is not compact no water mix, I have suggestion , cut it 1/2" long make it fine put in blender mix w/small amount of water then start. shut off mix with wooden mixer and start again then okey.
Jan 14, 2008 | KitchenAid KSB5 Professional Stainless...
Stopped blending
Exact same problem.  Turned out the threaded shaft that holds the blades was broken so tightening the nut on the top doesn't really help.  Just ordered a new blade assembly from www.smallappliance.com.  Mine was the Waring 007314W Blender Cutting Assembly but there is also an older one for earlier models.  Don't know if it will work yet (assume it will), but cheaper than buying a new blender.
May 17, 2007 | Waring PBB 25 Professional Work Top...
Back to Basics Smoothie Elite Work Top Blender Logo
460 people viewed this question
Top Back to Basics Blenders Experts
Mike
Are you a Back to Basics Blender Expert? Answer questions, earn points and help others
