Question about E-Machines Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply
Powerbox my power in the house went bad and it made my power boxmess up and now it wont work.
  • 80 Answers
Hi im wesley. your power supply might be blown because of a powre surge or unstable electric current flow
Posted on Jul 11, 2008
We had a battery failure and sevaral times the car turned over real slow no we got a new battery in it the a/c compressor wont come on air was working before batt went bad
You may see some black Powerboxes under the hood, sometimes they have labels moulded into the plastic. The A/C relay may be bad, even causing a power drain and running down the old battery. Also, you say the A/C does not come ON, but your blower fan may be what is not coming ON and the A/C compressor may be working fine. This problem is caused by a bad blower resistor control.
Your A/C probably has a computer digital display screen. This type of control has a self-diagnostic Mode which can be keyed in with a combination of control button pushes. It can diagnose in less than 2 minutes, but you need corresponding Code dictionary to translate into Human language and you need to know where the defective parts are located. An A/C shop would know this.
Aug 25, 2013 | 1996 Lincoln Town Car
My tv wont turn on
Look for power outlet and ensure there is power. Check TV on other power outlets. Ensure required voltage is there on the power outlet. Even then, if you notice that the TV does not work, it might be attended to by a skilled and qualifies service technician.
Jul 28, 2012 | Sanyo Televison & Video
1996 chevy k1500 has no power to ecm, eng-i or ign-e fuse
Try Autozone.com for free wiring diagrams. Just register your truck and you can get Powerbox layouts too.
With several things not working, you may have a bad relay or larger Fusible link burned out.
Jul 08, 2012 | 1996 Chevrolet K1500
How to put a powerbox in
Powerbox??? What kind of powerbox? How to put it in what? Good luck finding that pic!
Mar 19, 2012 | Cars & Trucks
I have a 06 f150 5.4L the fuel sending unit went out so i had to change to pump and everything, the pickup ran fine before but wen i put the new pump in it will not work so i tried resetting the fuel pump...
Hello, There is a fuel pump Relay in the Powerbox under the hood. The system works this way. When you turn on the Ignition switch, it trips the Fuel pump Relay. The power is routed to the fuse from the Relay and then to the Inertia (safety) cutoff switch. Finally the power reaches the Fuel pump.
You need to test the fuse holder for power before it flows through the fuse. You should have the Ignition on, in order for the Fuel pump Relay to provide power to the fuse. Although the fuse may be good, it can not work without power.
On most Models, the horn Relay is the same part as the Relay on the Fuel pump. Just check your part numbers and swap out the two parts and see if it helps.
Jun 24, 2011 | 2006 Ford F-150
I do not get any electric power on the feul pump, i have tried to activate the emergency shut off valve but still no power. i have taken electrical messurment at the switch but there was no power either.
Hello, You should have a fuelpump Relay in the Powerbox under the hood. The power goes through this Relay, then it has a fuse in the fusebox inside the car, and the Inertia sensor is next and then the fuelpump. If you have no power going to the Inertia switch, then you may have a bad fuse or a bad Relay.
Check with Autozone, Oreillys, or Advance autoparts for the correct Relay. Ford uses the same part for several jobs and you need to replace the bad Relay. Sometimes you can just switch identical Relays to find the bad one. Autozone is pretty good for having diagrams. A bad fuse would mean something went bad either on the Relay side or the fuelpump side of the fuse.
May 03, 2011 | Ford Focus Cars & Trucks
Where does the trailer battery charging wire connect to on a 2000 silverado 2wd w/o trailer package hook in?
UNDER THE HOOD, REMOVE THE LID OFF THE POWER DISTRIBUTION BOX. THERE SHOULD BE TWO STUDS STICKING UP, PROBABLY TOWARD THE REAR. DISCONNECT THE NEG. BATTERY CABLE. YOU WILL NEED A 30 AMP AUTO RESET " STUD STYLE" BREAKER. WITH 2 HOLES FOR MOUNTING. MOUNT THE BREAKER ON THE FENDERWELL NEAR THE POWERBOX. USE 10 GAUGE BLACK WIRE. WITH WIRE TERMINALS. GO FROM THE POWERBOX, TO THE BREAKER & FROM THE OTHER SIDE OF THE BREAKER TO THE REAR OF THE TRUCK TO THE TRAILER RECEPTACLE. I WOULD PUT THE WIRE GOING TO THE REAR IN A PLASTIC WIRE LOOM PROTECTOR, AVAILABLE AT MOST PARTS HOUSES BEFORE INSTALLING UNDER TRUCK. FASTEN WIRE WITH NYLON WIRE TIES AWAY FROM ANY EXHAUST PIPES, CAT CONVERTERS, ANYTHING SHARP OR HOT. FASTEN SECURELY IN TRAILER RECEPTACLE, RECONNECT THE BATTERY.
Jan 10, 2011 | 2000 Chevrolet Silverado
1994 ford taurus 3.0L Car went dead and found a loss of fuel pressure removed tank and tested fuel pump on a known to be hot battery the fuel pump worked properly so replaced pump in tank and tested power...
There should be a fuelpump relay in the powerbox. The points inside are probably burnt or corroded. Try Autozone or Oreillys for the relay. They may have a diagram or a book for your model car. If not look underthe powerboxes for a matching relay.
Jun 05, 2010 | Ford Taurus Cars & Trucks
Everything works just wont load c.o.d 5 world at war.
it sounds like a bad disc drive if under warranty sony wil fix if not u can find someone who can do it
Dec 22, 2008 | Sony Playstation 3 (PS3) Console
Buzzing
the loud buzzing noise isnt the xbox its the powerbox the one tht you plug the power cord into b4 u plug it into the back of the xbox when the buzzing happened to me i just shook it and it went away
Nov 27, 2008 | Microsoft Xbox 360 Console
E-Machines Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply Logo
51 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
