Question about Kenmore 63942 Dryer
Kenmore Dryer - Model No. 110-85872401
I have a 2-year old Kenmore dyer. Just recently it began to work only intermittently. The console lights only come on intermittently with no apparent pattern. The inside light works even if the console lights don't.
Electrician checked input to house and plug - no problem there. Have had repair out twice - but of course machine works when he's here. Claims can't fix unless he can the machine isn't working. Portends a career of repair calls until that magic moment when machine is not working when repairman shows up. HELP?????
  • mictroe Jul 14, 2008
    led lights do not come on..when you want to start dryer,power is fine..put into diagnostic mode and a couple of push buttons do not respond according to chart,,dryer light comes on,and relays activate when in diagnostic mode with start button activated.control bd?
  • 943 Answers
Hi thanks for the question i would check the door switch open the door and at the top right you will see a small metal piece sticking out that sometimes bends and don't always make contact check that the appliance doc
Posted on Sep 25, 2008
Reset after power outage
Assuming this is a 220 volt dryer, are both sides of the breaker on? It should not blow only one side of the 220, but worth checking.
Jan 26, 2014 | Kenmore Dryers
Kenmore gas dyer, model 11170092991. Won't start. Control panels lights work. when "start" button is pressed nothing happens
If your dryer doesn't work or start please check the bellow link to troubleshoot your problem :-
Please get back to us if you have further query else please accept the suggestion.
Feb 02, 2011 | Kenmore Elite Oasis 7808 Gas Dryer
Dryer works bu not lighting the furnace.What do u think?
Two things come to mind when this happens. The duct work is totally plugged up or the spark ignitor is out of order.
Check the vent tubing by completely disconnecting it and cleaqn thoroughly clean. I see one once I took apart and filled a 15 gallong trash bag full of lint. The dyer was three years old and had a 10 foot vent tube. 4 feet of tubing is always recomended at the longest length used. If longer it needs to be cleaned evey few months for 100% efficiency
If the tubing is clean turn on the dryer and listen for the click the sopark ignitor makes to light up the burner. If no click is heard the ignitor is bad
Apr 09, 2010 | Kenmore 73952 Gas Dryer
Electric Dyer approximately 10-12 years old. Most likely needs a new heater coil, or could be frayed wires.
Can be serviced. But if you want a new one... that is up to you. But it may be cheaper to fix it as long as you hire someone honest
Mar 13, 2010 | Dryers
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
May 25, 2009 | Kenmore 63942 Dryer
Dryer timer not working on a kenmore dryer model 80 serious
HI, if this device isn't working, you will need to replace it. it cannot be repaired. it is designed to fail and when it fails, you will have to replace the entire timer control module.
This device control all aspects of the cycle you initiate.
May 23, 2009 | Kenmore Dryers
Brown marks from Kenmore dryer
do they look like burn marks??????
Mar 13, 2009 | Kenmore Dryers
Maytag dryer model LDE8410acw
Hi james,
How old is the dryer?
Sounds like a bad element!
Age determines if it's worth the investment !
Sep 18, 2008 | Maytag MDG9606 Dryer
Kenmore dryer model #11071804000
thay can go bad soon but ck the thermo fuse on the dryer its a white fuse on inside dryer that will fix it 98% time
Feb 25, 2008 | Kenmore 63942 Dryer
Kenmore 67082 "PF" power failure code
Check your circuit breaker. Reset it even if it doesn't look tripped. It is a dual switch and sometimes you can't tell if one of them is tripped. Then try it. When you reset the breakers leave them off for about 10 minutes before turning them back on.
Dec 24, 2007 | Kenmore 67082 Electric Dryer
Kenmore 63942 Dryer Logo
105 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
