Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHV6803UC Electrical Failure
A street repair led to an electric overload to our property. Many electronic devices were damaged, including the Bosch integrated Dishwasher - SHV6803UC. Does anyone know what part would have been fried by excess current to the unit?
Many Thanks.
  • 54 Answers
The module control would be your problem if nothing works...
Posted on Jul 28, 2008
How do you recharge batteries with the usb
yes you can or many places they sell wall/car adapters that charge USB devices you have to look around .
Jul 09, 2016 | Garmin Etrex 20 Gps
Bosch ptk 14
Did you check the thermal overload protection device, house circuit breakers, and electrical attachments.
Mar 15, 2014 | Dishwashers
Manual free
If you have not added any extra items using more current that what you had there will be no problem. Add up all the watts that you are using and see if the alternator is exceeding that demand. Make sure that every unit is properly fused to protect the wiring harness.
May 09, 2013 | 2006 Harley Davidson FLHX Street Glide
Bosch 4000 10" table saw
this saw does not have a breaker overload. Let it cool down and see if works, if not then you have an electrical issue that would need to be diagnosed.
Jul 10, 2011 | Bosch 4000 - 07 Electric Table Saws
Water heater cod e 9 c 1 no hot water david 775 626 2111
E9 is overheat sensor, and C1 is fan rotation too slow.
It sounds like the unit is shutting down to prevent overheating because fan is not working, but there could be additional causes including PC board failure, or electrical problem.
Before calling service technician, open following links for Bosch troubleshooting resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Bosch-C1-C6-C7_error_code_troubleshooting.pdf
Apr 14, 2011 | Bosch Water Heaters
Whats the function of each fuse
Each fuse protects the wire in its circuit from damage due to overload. As a secondary responsibility, the fuse protects the devices powered by the circuit from electrical damage.
On one side of the fuse, called the BUSS is all the power your car can deliver to any particular circuit, on the other side of the fuse (the circuit) is the more delicate wire and devices it powers including everything electrical with the exception of the starter which is normally not fused. Your windshield wipers, lights, radio, all signal lights, the computers controlling your car, the power windows and door locks, the heater fan, everything. Some cars use circuit breakers on light circuits and some cars use a thing called a fusible link which is a piece of wire that will melt if over heated.
I hope I have ansered your quesitons ... thank you for your visit today.
Jan 13, 2011 | 1996 Oldsmobile Cutlass Supreme Coupe
Refridgerator will not start
Good day,
If the failure occured on lines owned by the power company, then that is their problem. File a claim, and call a service company for repairs.
If not, the overload may be at fault, However, there are many other items including the main thermostat, defrost control and wiring through out the machine.
The items you have working are hot wired items.
They are powered up as soon as the machine is plugged in.
If the fans are running, your on the right track. If they will not run either, it would be in the areas i've'd described above.
The overload is one item, 2 others are the relay (either mechanical or solid state) and on some models, the start/run capacitor.
Dec 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Error F5E1 after self cleaning
Hi There
I have read the codes you are looking for,so I'm sending them to you and i hope this will help.
F5 E1 16 Door latch not operating Check that door switch is completely closed. Check latch, solenoid, and actuation switch for electrical or mechanical malfunction.Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Fail to trip at twice the rated amperage
If a circuit breaker is overloaded and doesn't trip it is defective. Also, remember never load share different circuits on a single breaker, this can cause circuit overload. Be Careful and God Bless
Sep 18, 2009 | Challenger 20 Amp 1 Pole C120 Circuit...
Electrical
Circuit breakers are designed to protect life and property. Do not use an appliance that overloads the breaker. If it is popping a 15 amp breaker try it on a 20 amp, if it does not trip the 20 amp breaker measure the amperage. If the actual amperage exceeds 16 (80%) of the overcurrent device or the device exceeds the Wattage stated on the device. Repair or replace it.
Dec 02, 2007 | Holmes Products HEH8001-U Heater
Bosch 24 in. SHU43 Built-in Dishwasher Logo
192 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
