Question about Motorola Mobility RAZR V3
Backlight stays on...
This just started yesterday. The backlight on the front of my Razor won't go off. I've reset it to 7 sec., 15 sec. and then completely off...still won't go off. Problem that it is causing is that my charge won't last as long because the light is always on. Anyone know what I can do?
    Problem Solver:
  • 15 Answers
I believe u should reset ur razr. it could help
Posted on Jul 10, 2008
I thought I asked this already but it does not show up. I have a 15" lcd tv that will only stay lighted for a few seconds on each channel then goes dark. I can kinda see a image on the dark screen. I...
the backlight is either going out or the capacitor for the backlight is bad to where its not storing enough power to run the backlight the start capacitor must be good but the run capacitor might be bad usually the backlight itself goes bad but not if it turns on for a few seconds it would have to be the capacitor.
Oct 04, 2013 | Philips Magnavox 15MF400T 15 in. LCD...
I have an Amanda Heat pump W/o heat with a White Rodgers Thermostat 1F89=211. i messed up an tried to program. It now flashes L with a 76 setting an I can't move the up an down...
Hi I looked up the book, L is a malfunction terminal but I've rarely seen it connected also it says something about the backlight display feature displaying (dL).....Best bet is gently pull the thermo front off the wall REMOVE the batterys for about 10-15 minutes and the thermo will at least restore (reset) the factory default settings & start over.
Jun 10, 2011 | Heating & Cooling
Monitor goes dark 2-3 sec after power up, green lite stays on
Look for shorted out transistors (four, c5706/5707) in the inverter backlight transformer driving circuits.
Jan 21, 2010 | Dell E153FP 15" LCD Monitor
Just as the others,stays on for a couple secs then go blank. If I power down and back on i ts on for a couple sec. Checked voltage on supply its 12.3 vdc
Point a flashlight at the screen when it shuts down and see if an image is still there. If so, it may be the backlight inverter. You can try to get the part, but most shops would charge you more than a replacement.
To verify, before you pitch it, try it with another monitor and see if the same thing occurs. Ran into a case where something downloaded reset the power-saving settings for the backlight.
Jan 08, 2010 | Fuji FP-988D 19" Flat Panel LCD Monitor
Satellite A25-S279 screen flickers and goes blank after 5-10 secs
are you getting image on your LCD while booting up in the bios and windows loading screen ?
if yes, then perform a windows installation.
Aug 24, 2009 | Computers & Internet
Backlight not lighting
Yeah - I know the problem though my "kid" is 51!
Select Menu > Settings > Display settings and then:
Backlight time—to set whether the backlights are switched
on for 15 seconds (Normal), for 30 seconds (Extended), or
not at all (Off). Even if Off is selected, the backlight stays on
for 15 seconds when the phone is switched on.
It's the last line that worries me, though: if your "kid" has caused the backlight to FAIL, then you're faced with no backlight, or a repair/replacement bill!
Kids, eh? Who'd have'em?!?!?!?
Apr 29, 2009 | Nokia 2310 Cellular Phone
The light on the back of my phone wont go off. it stays on when i plug it in and also any time i push ANY button it lights up
Check in the Display Settings of your handsets. There you can specify for how many Seconds you like to put ON your handset's LCD Backlight. You can customise it for 5 Sec, 10 Sec, 15 Sec, 30 Sec, 1 Minute, etc.
Apr 23, 2009 | Cell Phones
Dell monitor 15 inch the green light stays on but no picture
It's the backlight supply tripping out from backlight failure, but the thing still stays on. I got it to act right by switching to factory presets with some fast menu action once, but the general solution is going to involve tricking the backlight into staying on; you can look at the thing in bright ambient light to see that the display is still working, but of course without a backlight it's pretty much useless.
Since $100 buys a better and more efficient monitor, just replace it; otherwise of course you can either replace the backlight (or go for one of the projector mods) or convince its drive circuit to put up with it a bit longer. I spotted a bad capacitor but swapping that out hasn't gone well yet....
Mar 14, 2009 | Dell E153FP 15" LCD Monitor
Motorola RAZR V3 - Backlight
Try removing the battery for a few seconds then restart the phone. Other than that, it could be a defective switch on the phone that detects when it's closed. If it answers / hangsup when the opened or closed... the switch is good.
Geno
Mar 04, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
