Question about Kenmore 12502 Top Load Washer
Loud racket at end of spin cycle
We have a Kenmore top loading washer less than 5 years old that has developed an extremely loud banging/rattling sound that seems to be mostly at the END of the spin cycles as the tub is coming to a stop. It lasts 15-20 seconds but seems much longer because of the noise, which shakes the entire floor. At first we thought it was a imbalance problem, because the sound is much like a BADLY imbalanced load,like a rug was in there by itself, but it happens on small, delicate loads as well as normal larger cycles. Could it be the balance system itself? How do I best start looking? From top, removing wringer? Back? Look underneath? When the cover is opened during the event (agitator is stopped, tub still spinning) the noise sounds/feels like it's eminating from the side of the tub. Help!
  • nospam1956 Jul 11, 2008
    Drum is not empty, but the noise seems worse with smaller loads.
  • 190 Answers
Dear Customer,
I recommend you to kindly do the following routines before going to a service man..
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
    This should solve the problem..
    Please rate this Solution.. Thank You.. Good Luck..
  • Posted on Jul 11, 2008
      Genius:
    • 1,011 Answers
    Sir,
    The following is a simple problem that can cause this symptom, but it could also be something more serious. For safety reasons, the Kenmore top loading machines we have owned have a small switch to stop the spin when the lid or door is opened. Look at the bottom of your lid and try to find a small rod shaped projection and then note where that rod will go through a hole on the lip where the lid closes. Inside that hole on the lip is a small switch held in place by a couple of screws. If these screws get loose the switch can sag down and not get closed when you close the lid. If you are lucky you can just tighten the screws to fix it. The switch can also go bad. !! Be sure to unplug the machine before proceeding !! After unplugging the machine, work your fingers underneath the switch to hold it while you remove the screws, then pull the switch out where you can get to it (this is tricky, but usually can be done). Remove the wires from the switch and test it with a volt-ohmmeter. If it is bad, order and install a replacement. If this switch is not the problem you will have to dig deeper into things like whether the mechanism that engages the spin is working properly or if the timer is issuing the right signals.
    When you open the door you let in warm air to a cold refrigerator. When you close the door that air contracts creating a vacumn that draws air in through the drain.
    If you can get to the outlet pump at the bottom you will find the outlet pipe attached to the pump with a spring clamp. You will need a pair of pliers to release the spring then pull the pipe off and check for blockage by pushing a bent coat hanger up it until it exits at the sink end. If it's clear of debris then check confines of the pump for debris or malfunction.
    The link below has some good information on washing machine repair.
    http://www.appliancerepair.net/
    Thanks
    Good Luck
    "Don't forget to rate the solution"
    Posted on Jul 10, 2008
    • 4,472 Answers
    Either something is loose or the main bearing is broken. I would suggest if you would like having it serviced, but I would recommend replacement being that it is 5 years you may want a new unit that will come with a factory warrant.
    Let me know if you need any other information/assistance.
    Thanks,
    lee
      Genius:
    • 3,422 Answers
    HI,
    If the drum itself is empty, that indicates only one of two possibilities :
    One : something slipped between the drum and the drum wall (like a metal wire from a bra)
    Try removing the part. Start at the bottom of the machine by opening (and if necessary removing) the water pump. Rotate the drum and try to move the lose part to the mounting hole of the pump.
    If that fails open the rubber collar near the window. This last action is rather difficult, and requires luck and skills!
    Two : the main bearing of the drum has broken.
    As repair involves opening of almost the entire machine, it is difficult and expensive to repair : it's often cheaper and therefore adviced to replace the entire washing machine.
    Do not work alone on the machine. Always have assistence available.
    NEVER work on the machine unless the electric powercable is removed from it's socket and is visibly lying next to you !!! Make sure : working on a washing machine involves water : lethal in combination with electricity !!!
    Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
    LG WM2688H Front Load Washer Smoking power ... - Fixya
    www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
    LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
    LG 4280FR4048L Bearing - AppliancePartsPros.com
    www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
    Rating: 5 - ‎189 reviews - ‎$32.19
    Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
    LG WM2455HW washing machine problem - YouTube
    ? 10:29
    https://www.youtube.com/watch?v=__abhTwmi1I
    Sep 15, 2010 - Uploaded by djmcarter
    I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
    Jan 19, 2016 | LG WM2277H Front Load Washer
    My washer is very very loud during its spin cycle
    There are a number of things that can do this. For a top-load machine, an out-of balance load can get noisy. Many GE washers have bungee-cord type straps at the top of the tub to dampen out-of-balance gyrations. If these break, you get a lot of rattling. Other washers (some older Kenmore models for example) have a spring-and-bar arrangement under the tub. If this freezes up due to rust, or something breaks, your washer will bounce a bit. Older Maytag washers may dance around if the baseplate is worn out. In all washers, bad tub bearings can make a racket; you will often have leakage as well.
    Sep 09, 2014 | Washing Machines
    Loud racket when spinning at high rate f speed
    yes it is going. if you go here
    www.techray1.com and select the guru guy he will take you another window where you can select the part needed. also the repair manual is availble for your unit.
    Jun 22, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
    Washer spin cycle extreme vibration and loud bang when it stops
    check the vibration damper rods for breakage - especially the mounts.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Mar 17, 2009 | Kenmore Washing Machines
    Loud knocking noise at end of spin cycle
    To allow for unbalanced loads and reduce vibration in the floor of the house, the outer tub is suspended by various means. Some machines use a heavy rubber ring, others use spiral springs but either of those can, after a heavily unbalanced load, unhang themselves or in the case of the rubber suspension, the rubber tires and rips.
    If you remove the back panel (10-12 screws) and look inside while pushing the tub side-to-side, you should be able to find the suspension and inspect it with good light.
    Apr 17, 2008 | Kenmore 22622 Top Load Washer
    Frigidaire Front Load Washer Making loud racket in last spin cycle
    try pulling off lower acess panel. theres apump in rigth side corner . does it sound like theres something gaught in the squeeze the hose, try opening the door assy can you lift up on the inner basket. does it appear to have a bit of laterral movement???? how old is it???
    Mar 13, 2008 | Frigidaire GLTF1670A Front Load Washer
    Loud noise when spinning
    the only part that makes a loud noise is your bearings m8 other than that could be a bra wire stuck inbetween your drum and casing m8
    Aug 11, 2007 | Maytag Atlantis MAV6000 Top Load Washer
    Kenmore 12502 Top Load Washer Logo
    91 people viewed this question
    Ron Lankford
    Archaeology
    Archaeology
    2mikecurtis
