Question about Canon Powershot SD450 / IXUS 55 Digital Camera
Water damage I dropped my camera in a small puddle of water. When I try to take pictures in the light, I get a white picture on the LCD screen. However, when I try taking pictures indoors or in dark places, the pictures work. Please advise how I can fix this problem. I have a Canon Ixus 25. Whilst in a bag,a water bottle burst and the camera got wet. On returning home I removed the battery and memory card and left it to dry in the soft sun. I then found some silica gel sacs and placed one in the battery aperture. The battery opens the lens but the screen just shows a white blur. On looking at the lens it seems as though there is some moisture trapped behind. What can I do please? Your advice will be appreciated. Manfred Salamon
  • sunrise11111 Aug 20, 2008
    I have IXUS900TI canon it got wet in the rain. Now camera is working all right but only problem with the screen it is showing very dark picture some time difficult to see.
Let me suggest you don't leave a high tech piece of equipment in a bag with a water bottle (even if it isn't open).
Posted on Jul 30, 2008
White lines on image however when capturing on dark areas and on video mode, it produce a perfect image
Not clear when you have white lines. While looking on the screen or really on a image.
Lots of camera's produce lines on the LCD, when using the LCD to frame the picture. Special when there are small and sharp lights in the image. But the sensor is not capturing that while making the picture. It is a sort of smear on the screen.
Also, when you try to make a picture in bright lights, you can get flares, but those you can see on the screen and in the picture. To fight flares, most camera's and lenses come with sun hoods. Your camera does not have a hood, so try to avoid shining bright lights on the front of the lens.
Nov 05, 2013 | GE 14MP Digital Camera with 5X Optical...
I turned my camera on and the lcd screen is white and shows no image. I plugged it into my computer and the pictures are still intact, and the camera is able to take pictures, but I can not view them on...
Try restarting your camera a few times and see if that solves the problem. I would suggest saving all of your pictures and reset the camera if possible. Sony's quality of their cybershots are quite sub-par and common things like an LCD shorting out is quite frequent, so you may have to call the manufacturer to replace/repair your camera.
Mar 06, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
When I turn on my camera it just displays a white screen.. I can take pictures but can not see them until I go to download them onto my computer
This can be caused by either Water/Moisture damage or the LCD cable needs to be reseated
If you think it is water damage then not much you can do except for a replacement screen.. assuming thats the only damage. If you think it may have been dislodged you will need
to have an expert reseat the LCD cable.
Jan 24, 2011 | FUJIFILM FinePix Z70 Z71 Digital Camera
I have a FujiFilm S5000 and since 2 weeks the sensor seems not to be able to adjust when trying to take a picture in sunny condition. The screen shows white and pink colour with horizontal lines. I turn...
Actually it's not the sensor it's the LCD screen. I would say in the last two weeks the camera didn't change but the environment it is being used in has and is causing the camera to overheat.
Diagram
Temperature
Diagram
Keeping the camera within these perimeters should solve your problem.
Jan 18, 2011 | Fuji FinePix S5000 Digital Camera
White screen (no picture) when camera is turned on.
It is probably an issue with the LCD display panel of your camera. It may be just a LCD connector cable coming loose or the panel itself is damaged(Kodak cameras are notorious for this issue). Fortunately it is a relatively inexpensive repair. If the camera is under warranty make use of it to get it replaced for free. Note that the warranty is void if there has been a water lodge or if you take it apart yourself.
May 26, 2009 | Kodak EasyShare C330 Digital Camera
Water damage
try this :
This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
rate if useful please !
Jun 16, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Dropped camera- screen is white
OK. I think you should replaced damaged camera LCD. And you should take care of camera lens.
KAT
thu241@gmail.com
Myitkyina, Myanmar
Jan 08, 2008 | Sony Cyber-shot DSC-T10 Digital Camera
Dropped in water
just go to the place you bought it and ask to get it fixed
-amanda
Aug 26, 2007 | Olympus Stylus 600 Digital Camera
Open Questions:
Canon Powershot SD450 / IXUS 55 Digital Camera Logo
188 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
