If you look carefully you will see a pin hole on your disk drive built in to your apple computer.
The disk inside the disk drive might be stuck or the there can be some damage in the disk driver. Either ways you can insert a sharp pointed object like a needle or a pin in the pin hole. This will eject the drive.
If the disk drive does not eject, to avoid any further possible damage the laptop has to opened and the disk drive has to be removed and inspected. If the above solution solved your problem, You disk drive may start to function properly otherwise if there is no hole (since many disk drivers have no holes) or the insertion and poking of needle does not work the only recommended option is that you have to take it Repair shop or give it to a tech.
Good Luck!
f you're trying to eject an external disk:
Choose Apple menu > Log Out, and then log in again. Try to eject the disk again.
If you still can't eject the disk, choose Apple menu > Shut Down. Disconnect the disk from your computer, and then start up your computer again.
If you're trying to eject a CD or DVD:
Choose Apple menu > Log Out, and then log in again. Try to eject the disc again.
If you still can't eject the CD or DVD, choose Apple menu > Restart. While your computer restarts, hold down the mouse button or trackpad button until the disc is ejected.
If you're trying to eject a network disk:
Choose Apple menu > Log Out, and then log in again. The network disk should be gone.
The disk freed itself for some reason before I was going to take it to a computer person.
Thanks for your input
