My faxes are not printing. The error message says there is a paper mismatch and tells me to remove the transparency and press enter. Problem is, I'm not using transparencies, just normal paper. Problem started when I noticed a small, clear, rectangular plastic piece in my paper tray. I think this might be the problem, but I can't tell where to reinsert the piece. Help!
Sounds like your spot sensor is broken. It will give you this error if not working properly. It is attached to the right side of the cartridge carriage and emits a small blue light when paper is fed in to the machine. It looks at the paper and tells the machine the paper is there or in this case not there.
When I send something to print, I get an exclamation mark inside of a red circle and the printing...
(More)
When I send something to print, I get an exclamation mark inside of a red circle and the printing process halts - what do I do
HP G85. Lost small metal (aluminum?) clip and associated spring located near the ink reservoir port....
(More)
HP G85. Lost small metal (aluminum?) clip and associated spring located near the ink reservoir port. Causes severe loss of ink. Can they be purchased?
I have a HP G85 Officejet printer that has worked well for over 8 years. Only problem is that...
(More)
I have a HP G85 Officejet printer that has worked well for over 8 years. Only problem is that occasionally it will indicate "document failed to print" when I am trying to print something off the internet from my computer. The solution that works every time is to restart the computer and briefly turn off and back on the G85, it will then print out all the previously requested print requests from memory. Is there an easy fix for this?
can i upgrade memory in hp officejet g85, for some reason it has stopped printing pictures? It use...
(More)
can i upgrade memory in hp officejet g85, for some reason it has stopped printing pictures? It use to print great pictures & now it has quit. It prints about an inch of a picture & then spits our the paper. I am using vista 64, i have tried to print in kodak easyshare, photo gallery, hp print software & gimp? Any suggestions? **** I did just submit this same question, but forgot the g85? so see repeat question
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
