Proline LVD198W 19" flat screen TV with dvd player. dvd player not starting up when dvd drive is insted with dvd. looks like common fault.
  • 142 Answers
SOURCE: dvd player
SOME dvd players have a small hole in the front... just large enough for an opened up paper clip to fit into. If yours has this, unplug your machine and insert an unfolded paper clip into this hole and gently press the mechanical eject switch. If you don't have this feature, your only hope is to disassemble the bottom of your set and spin the eject motor by hand to remove your disk.
Posted on Mar 10, 2008
  • 4102 Answers
SOURCE: I have had my sanyo
Hi what channels are you watching is it just through an ariel if so then this might need moving or even enter setup in the telly and adjust the channel freq untill you get good picture
With the dvd player if your using scart leads then push them in properly then you will get picture and also if their is still no picture then press av on telly remote check lead in both ends ie telly and dvd push in hard this could be your problem
Posted on Apr 18, 2008
SOURCE: tv has built in dvd
Under warranty - called westinghouse
Posted on Jul 22, 2008
wings_it
  • 141 Answers
SOURCE: connect TV to dvd player
hdmi, S-video or jack are the most common cables delivered with the dvd, you can plug an amplifier between tv and dvd for a dolby system.
Turn on the DVD player, the TV and Set your TV on "AUX" or "Ext" with the remote.
Posted on Dec 23, 2008
  • 3 Answers
SOURCE: AKAI Wide Screen LCD TV/DVD Player Combo.#LCT3201AD
If you are electronically inclined, replace the three 1000uf 16v electrolytic capacitors in the power supply board located above the power switch. They are likely bulging out at the top and failed. They are the three in a row at the top - center of the board, located between the two black heat sinks. Make sure you get caps rated for 105c degrees! I recommend replacing them with 1000uf 25v caps. 35v caps will work but might be a tight fit as they are larger diameter.
Should cost you about $8 for the parts shipped. You can get them from partsexpress or digikey or any good local electronics store. Your local radio shack may have them but they won'y be 105c and thus may not last long.
Not handy, ask around, there is usually some electronic tweaker guy around that will install them for a few bucks.
This has solved the turns on / then off problem every time in the 3 I've done.
Posted on Jan 11, 2009
My friend took out the dvd player so the light stay on an when i tuurn it on it waits a sec then does red then green screen an goes to standby
The TV is indicating that a part of it is not working, like the dvd player that is missing. Modern electronics go through a set of tests and if a fault is found the stop working. Replace the dvd player, or get the set to a repair shop.
Apr 30, 2015 | Emerson LD190EM1 19 in. LCD TV/DVD Combo
Proline tv dvd
Just buy a GOOD QUALITY universal remote control, before you buy, please check if your device is listed on the list of the supported devices. Forged cheap universal controls, a good one starts around $20.00
Mar 07, 2014 | Televison & Video
Digihome dvd not working
If it's a burned DVD or a CD, it might just be incompatible. Not every disc will work in the kind of older drives Digihome uses.
Aug 29, 2012 | Digihome LCD TV
Our TV/DVD player (LTV-32w4 HDC) is just out of the 4 year extended warranty we bought. The TV works fine, but the DVD player will not start up. When a disc is inserted, it seems to be trying to start...
Hello
According to your complaint post, the fult is due to its DVD mechanism itself. It will be best to replace the DVD tray mechanism [ plastic made one]. You can bought it from most of the electronic spare part shops at your town. But the model fitted with Westinghouse will be very difficult to get. Anyway try to get it. The fault is with loading tray mechanism itself. OK.
Aug 23, 2011 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
My 19 in magnavox tv dvd combo makes a rattling noise after i put a dvd in and try to play it
Sounds like you have something in it or the gear drive is bad. Open the door and look inside with a light. If you do not see any loose objects then I think you have a bad drive gear which would not be feasible to repair given the price of a new 19 in tv and dvd player...
May 05, 2011 | Televison & Video
Proline dvd player manual
Contact Proline (Comet group) web site for manuals.
Dec 14, 2010 | Televison & Video
I have brought some DVDs and my TV DVD player will not play them
You won't be able to do this unless your DVD player specifically says it is a multi-region player. DvVD movies that are encoded in a different region use different encoding methods like PAL instead of NTSC.
Jun 20, 2009 | Panasonic Proline AG-DV2500
Code for total control4 - Proline TV
i have the same problem cant get a code for my durabrand dvd recorder
May 05, 2009 | Televison & Video
Proline LD 1702W T.V. Sound/Vision failure
Dear Team, many thanks for your call back re my Proline flat screen T.V.. ** the fault is still existing however after speaking to a couple of whizz bangs I have been pointed in the direction of dry or broken solder joints particularly in the power supply section. This I will look at tomorrow....Here's hoping anyway.
Mar 08, 2008 | Televison & Video
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
