Question about Microsoft Windows XP Media Center Edition 2005 for PC
XP Media Center: Tuner Hardware not found
After months of not using MCE on my XP machine I thought it was time to launch it. However, when I clicked My TV, I got a message saying: Tuner hardware is not working properly or is not installed. I have a hauppauge 150 and it is visible in the device manager.
So i reinstalled the tv card using drivers from Dells web site (my pc is a dell). But no luck. I removed all MCE updates and .NET 1 and then reinstalled it. I also removed windows media player 11. No luck either. I tried Hauppauges drivers: no luck then. I also removed all Haupauge drivers using their cleaning program. No luck.
I then reinstalled all drivers using this file i found on this page.
It gave me WinTV in which I could see all channels, so the hardware is not dead. Then I thought that MCE should be able to see the tuner. No way.
I downloaded the Microsoft Windows XP Video Decoder Checkup Utility to see if it is something with my mpeg decoder. All I could see there is that I have one MCE supported MPEG decoder, which I set as default. Still no luck.
Who can help me get MCE running again? What else should I try?
  • 2 more comments
  • mrplace Jul 11, 2008
    I have tried what you said, removed the card then restarted, scan for hardware changes. then i put the card back, and the hardware had been installed automatically.
    I cannot change the imaging and tuner device in MCE, havent seen that option.
  • j f Aug 10, 2008
    hay i have the same promble i have windows media center and outa no were when i woke up and put live t.v it was black and then it sed t.v tuner can not be found or is not installed need help wat should i do
  • Anonymous Feb 08, 2009
    I am the exact same problem.
    PVR-150 with winXP MCE 2005 SP3
    "Tuner not found" no matter what I do!
  • Anonymous Apr 08, 2009
    Wow! Why not post an actual solution instead of a ******* rant you douches. As for me, I am having the same issue. I have tried installing the stock drivers for my MSI Theatre 550 Pro tuner card, installing the media center update rollup 2, and checking to see if the media center services were both active and running as local, all to no avail. Also worth a look, try downloading the media center decoder utility as it can sometimes fix issues with decoders errors and tuner cards not being recognized. My experience with this issue has also lead me to the conclusion that almost ever time I deal with each computer has a different solution because of the difference in hardware installed. If I find a solution (hopefully today), I will post my findings.
Dump Microsoft schit.People are  just dirt to them.
Posted on Mar 24, 2009
I love this string of posts. It only fuels my hatred of this half-assed company. It's the biggest fraud ever perpetrated. This problem has existed for over a year and there is no solution. So I suppose that if my car develops some problem I am expected to not only do the physical repair but also do the full diagnosis to create a solution myself? ******** MICROSOFT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Oct 12, 2008
  • 2,427 Answers
Go into the drvice manager
right click and select scan for hardware changes
this should popup the tv tuner and automatically install the drivers..
If that fails
turn off the system
remove the tuner card
boot the system and using the device manager scan for hard ware changes
shut down
replace the tvtuner
restatr and in the device manager scan for hard ware changes again
Also in Mce insure you have the correct imaging device and tuner device selected, this will be located in the setup options
Posted on Jul 11, 2008
  • Rishi Roshan Ali Jul 12, 2008
    its located in windows media player
Media center does not work on my windows xp
You should reinstall it using the installation cd because there is no downloads on the net for this.
Feb 22, 2010 | Microsoft Windows XP Media Center Edition...
Xp media center says no ntsc tuner installed
Okay, Media center does not work with some Wintv HVR's yet it will work with the software it came with and sometimes media center will use the wintv software to make it work but its sketchy. If you want a more media center compatiable card look at www.microsoft.com website they have a list of media center compatable Tv tuner cards, Trust me I am having the same problem with my tuner card now and its not wintv its a RCA and its under windows 7 this is just the thing here not all card work with media center.
Thanks for using fixya.com please do click the accept button.
Nov 07, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Compatibility of vista os with hvr-1100
yes it is,
Supported OS: Windows XP Windows XP MCE Windows Vista Windows Vista MCE
Jun 22, 2009 | Hauppauge WinTV-GO PLUS PCI TV Tuner...
Tuner Not Found when launching Media Center
Try going into uninstall programs and find media center.
Highlight media center and click on repair.
See if this helps.
Your might also look in your device manager thats located in your control panel and see if there are any problems there.
May 20, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Media Center-"No tuner installed"
It sounds like the TV tuner card has failed, and will need to be replaced
Apr 14, 2009 | Dell Inspiron 6400 Notebook
Windows media center on start up freezes computer, why
When that happens you usually need to backup your data, and reinstall the system to fix Windows corrupted files.
Try first doing a system restore to the most recent date before you started having the problem. If system files are damaged this will not help.
The media center is part of the WMC operative system. You can also reinstall media center alone using add remove programs, then Add remove windows components. Often that does not work, and you need to use a Windows MCE setup disk to fix the problem.
Apr 10, 2009 | Microsoft Windows XP Media Center Edition...
TV Tuner Not Installed
use roll back driver see its work do you knew how to roll back
Aug 15, 2008 | Dell Dimension 2400 PC Desktop
Windows xp mce
Do you have tv tuners installed and setup properly? Media Center 2005 is just the software, the computer needs to have hardware tuners in it and hooked up to external antenna or cable.
Feb 15, 2008 | Philips TV Tuner Video Capture PCI Card -...
Firmware damaged by a virus
have u upgraded windows since the last time you installed ur original drivers>?
i would suggest that you create a file on the desktop get the newest drivers from the manufacture that is compatible with yuor os.the manually install theem, go to yyour device manager in the contol panel go to hardware if your hardware is there clik properties drivers ,then update them you might have to unistall the old 1's and their software 1st/If u need more detail get back to me
Jan 21, 2008 | Computers & Internet
No video in Live/Recorded TV
  • try installing the necessary video codecs required to playi.e., based on which format your tv tuner plays,also install the software once again from your tv tuner cd
Nov 05, 2007 | Microsoft Windows XP Media Center Edition...
Microsoft Windows XP Media Center Edition 2005 for PC Logo
5,482 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
