Question about Sony PlayStation Portable (PSP) Console
Psp cuts out after roughly 15 minnutes
Please help my psp will turn on and after 15 minutes it turns off do i need a new battery ??? if not what do i need to do
  • 3 Answers
Depends, if your psp is damn old that may be the problem, but otherwise i cant tell ya, because the battery starts to last lesser, more quickly if you are from those guys who dont wait until it goes out of batteries to charge it
Posted on Jul 11, 2008
Why when i switch on my psp he cannot read my memory card and he will not turn on?
Hi p_demain,
First you have to figure out what is causing the problem. Try the following steps.
1. Remove anything that is connected to the PSP, including the
Memory Stick, battery and any UMD games.
2. Plug the charger into both the wall and the PSP system, then wait for at least 30 seconds before turning the psp on.
--If the PSP turns on, your problem is not with your PSP, but with an accessory that was previously attached.If it does not turn on, your PSP is in need of a repair.
3. Next, unplug the power adapter from the PSP, and firmly place the battery into the PSP.
4. Plug in the Power Adapter once again, and wait at least 30 minutes for the PSP to begin charging, then try and power on the PSP system.
--If the PSP does not power on with the battery plugged in, but it did with just the charger, you need a new battery. If it powers on, do the next step.
5. Place the Memory Stick inside the PSP , and turn on the power. If the PSP does not turn on, but it turned on without the memory, you need a new memory stick.
If your PSP did not turn on during step 2, it needs to be repaired by a qualified technician. I hope everything works out for you. Good luck.
Jul 15, 2011 | Sony PlayStation Portable (PSP) Console
My PSP wont turn on when. I buy a new battery it
your psp is frying your battery. well the eeprom on the battery.
Sep 03, 2009 | Sony PlayStation Portable (PSP) Slim...
Joser
Ok, for the PANDORA BATTERY, you'll be needing
1. A cutter
2. Your PSP SLIM battery (of course)
3. Lead Pencil
the steps:
1. Take out your PSP battery, using the cutter, run the sides of your battery along the lines(where the battery has been joined) starting from the bottom until it opens...just be careful or you might mess the board of your battery.
2. Carefully Prop out the board of the battery
3. then, using the cutter still, carefully cut the golden line (indicated by the small blue circle in the pic)...maybe 15 to20 runs of the cutter will do (that's what i did at least). Just dnt press too hard or you might cut through the whole circuit board ok?
4. Then after cutting the gold line, you're through...just close the battery again and tape it up at the sides (i used packaging tape with mine, heheh...) and you're through with the pandora battery!
*NOTE: you'll know that you're successful making the battery when you put the battery in the PSP and the green LED light automatically turns on but there isn't any display on your PSP's screen. If it doesn't turn on automatically, just try to run a few cuts again on the line on the Batt's circuit board.
Turning the PANDORA Battery into NORMAL Battery:
Now, to turn the battery into normal battery again:
1. Open your modded SLIM battery
2. Using the Lead Pencil (i don't know if it works with other pencils too), remember the line that you've cut on the board of your battery? Run the pencil on the cut to re-connect that gold (or yellow) line.
3. You're done. Close your battery again and secure it (again) with tape...Finis!
Jul 31, 2008 | Sony PlayStation Portable (PSP) Console
Jose
Aw, ok...so, first up, to make the pandora memstick, check this thread
hxxp://www.pspmod.com/forums/psp-hardware-guides/23428-guide-making-pandoras-battery-new-method.html
just start with process 2
(Process #2: Creating the Magic Memory Stick with a bricked psp:(well, of course since your PSP is bricked))
after you've made the pandora memory stick, on to the pandora battery.
now, since your PSP isn't working and you don't have any OTHER PSP(specifically PHAT version) you'll be needing
to hard-mod your battery...how to do this? well, first you'll need a cutter, and of course your SLIM battery...the one that came with your PSP...
first up...you must open the battery...and you'll be doing this by using the cutter...carefully slice through the line at the sides of your SLIM battery...just be careful or you might mess it up inside...
then, after opening it, carefully prop out the circuit board of the battery...see this image
[IMG]http://i279.photobucket.com/albums/kk155/devileye001/enlarged.jpg[/IMG]
then still using the cutter, carefully cut the golden line (indicated by the small blue circle in the pic)...maybe 15 to20 runs of the cutter will do (that's what i did at least). Just dnt press too hard or you might cut through the whole circuit board ok? Then after cutting the gold line, you're through...just close the battery again and tape it up at the sides (i used packaging tape with mine, heheh...) and you're through with the pandora battery!
[IMG]http://i279.photobucket.com/albums/kk155/devileye001/markedforcut2.jpg[/IMG]
now, when you've done making youre magic memstick(or pandora memxtick) and pandora battery, just follow the steps on the link i indicated at the top where it says
"Running the files:
----------------"...and when finished, to make you're battery "normal" again, using a pencil, remember the line that you've cut before on the battery's circuit board? Just run your pencil through a few times to reconnect it and you're done. You should have your PSP running again...
Jul 29, 2008 | Sony PlayStation Portable (PSP) Console
Sony psp problem
Remove the battery for 15 minutes, connect the AC Adapter and install the battery again.
It that doesn't work, remove the battery again, wait 15 minutes, install it and plug the AC Adapter.
It's a weird problem but in my PSP i get around that way.
Feb 07, 2008 | Sony PlayStation Portable (PSP) Console
Psp
If the PSP works correctly when the power adapter is plugged in but not when just running on battery then yes, you need a new battery.
Also triple-check that your PSP's screen brightness is turned up all the way (hardware buttons along the bottom of the screen.)
Dec 18, 2007 | Sony PlayStation Portable (PSP) Console
PSP Won't turn on
Try this>
Start with the PSP turned off. Press and hold the R button when your turning on the power. Turn it off again, then back on. Sometimes this works. If not, your PSP is probably Bricked.
This means that you done something to interupt an upload or program in progress. The eeprom program is corrupted and the PSP will not boot up. The term Bricked, refers to your PSP being no better than a black Brick paper weight. I have heard of a repair for this called Pandoras Battery. I am not sure if the Pandoras battery really works to restore Bricked PSP's. It may be worth a try for you to take a chance on Pandoras Battery.
Nov 07, 2007 | Sony PlayStation Portable (PSP) Console
New psp wont turn on!
IT IS BRICKED use a pandora battery go here for more info: www.console-crazy.com
May 07, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
69 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
