Question about Car Audio & Video
LIghtning Audio B300.4 Protect Light
Had a power surge in my truck causing my amp to go into protect mode, can this be reset, or is it in need of servicing? Thanks.
  • Anonymous Jul 12, 2008
    my protection light keep flaching
  • bigman_4life Jul 12, 2008
    my protectonn light keep flashing i change the amp location but it still keep doing it.
  • 63 Answers
Protect mode should be reset if the negative of your amp is disconnected then reconnectewd. if it doesnt help, move your ground to a different location. if THIS doesnt help, consider a repair or a new amplifier.
Posted on Jul 13, 2008
When and How Should a Surge Protector Be Used on a Fixed Switch?
Common Causes of Lightning Strikes
  • Outdoor network cables or power cables are routed overhead.
  • A switch is deployed outdoors but is not properly grounded.
Damages of Lightning Strikes
  • If power cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn the power supplies.
  • If network cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn interfaces of the switch.
When a switch undergoes lightning strikes, overvoltage is induced by lightning on network cables and transmitted to interior of the chassis. The surge protection measures, such as lightning rod and chassis grounding cannot prevent the damage. Therefore, surge protectors or surge protection circuits are recommended.
Surge Protector Use Precautions Take the following precautions to protect a switch from lightning:
  • Ensure that the ground cable is connected to a ground bar or a ground point on the cabinet.
  • Avoid routing cables overhead in an outdoor environment. Bury cables underground or route them in steel tubes.
  • To protect network interfaces against lightning, use 8-line surge protectors (or Huawei certified 4-line surge protectors).
  • When installing a network interface surge protector, connect the IN end to terminals and the OUT end to network interfaces of the switch.
If a fixed switch is installed in a network box, follow these instructions:
  • Connect the ground cables of the switch and surge protectors to the ground bar in the network box.
  • The maximum length of a ground cable cannot exceed 40 cm, and a length of smaller than 15 cm is recommended.
  • If the network box is located outdoors and power cables are routed aerially over a long distance (more than 300 m) to the network box, it is recommended that you install a power supply surge protector in the network box. The decoupled power cable must be at least 3 m long
S2300 Switch Thunder link com
Dec 08, 2016 | Office Equipment & Supplies
Lightning Audio b2.3000.4 is in protect mode. i removed all speaks and conected the amp directly to the battery and it still stays in protect mode. what can i do to fix this problem?
  • Only a select few things can cause protect mode with the battery only connected.
  • An installation issue. Check the Power, Ground and Remote wires. Make sure non are shorting from one terminal to the other.
  • It is still overheated and has not had time to cool down from being in thermal protect mode.
  • The amp itself is touching metal. You always want something non conductive between the amp and where it is mounted, this includes the screws being used to anchor the amp. They should never touch the metal in the car either.
  • The final thing that can cause an amp to go into protect mode while only hooked to the battery is the amp itself is malfunctioning and or defective. You can try opening the amp and look for any black spots on the circuit board where an electrical component might have smoked up or blown and replace that part.
Regards, Tony
May 21, 2011 | Lightning Audio B2.300.4 Car Audio...
How do I reset from the amp protect mode Onkyo receiver TX-SR600?
How do I reset my amp / receiver from protect mode ?
May 07, 2010 | Onkyo TX-SR605 Receiver
I have a lightning audio amp a B4.320.4 and Protect Lght stays on
the amp probably got to hot and had a thermal shut down witch will have to be fixed by a professional.
Mar 06, 2010 | Lightning Audio Car Audio & Video
My amp is a kenwood kac-9152d it goes in to protection mode soon as you hook up the power
In protection mode do you mean the light comes on and it plays music and stuff? If that's the case, that's what the amp is supposed to do. Protect itself from a power surge
Feb 21, 2010 | Kenwood KAC-9102D Car Audio Amplifier
My amp is stuck on protect mode. what do i do? its a lightning audio. the green light is not on the only light is the red protect light
the amp will need to be repair because it has a fault that it is seeing internally. so not much you can do other than buy a new amp or get that one repair. probably cost effective to buy new. hope this help. good luck
Nov 03, 2009 | Lightning Audio B2.300.2 Car Audio...
Amp Not working!
If the amp goes into protect mode, it's likely due to shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
If the problems are not with the wiring, follow the link at the bottom of the page to the Amplifier Repair Primer page.
Let me know if you have any other questions.
Sep 20, 2008 | Power Acoustik TS620-2 Synchronized...
Lightning audio B300.4 amp protect light
The most likely reason for it to go into protect is shorted output transistors.
Jan 16, 2008 | Car Audio & Video
My amp wont go past protect mode
Disconnect all speaker wires and signal cables from the amp. If it powers up (no protect light), the wiring needs to be checked. If it still shuts down (goes into protect), the amp likely has blown output transistors.
Dec 01, 2006 | Lanzar Vibe 218 Car Audio Amplifier
Car Audio & Video Logo
569 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
