Ntoskrnl.com oxcooooo98 problems will not let me start pc help !!!!!
Help please
2 Suggested Answers
colliewob
  • 781 Answers
SOURCE: i can not get my
Best and quickest solution reinstall windows.you have a corrupt or missing O?S system file
Posted on Jul 10, 2008
I am the owner of a tascam 2488 and since day one I can't connect it to my pc. What can I do?
Symptoms
When you connect a Universal Serial Bus (USB) Microsoft Windows CE-based device to a computer that is running Microsoft Windows 2000, the computer may halt with a "Bugcheck code 0000000A" error message on a blue screen. If you restart your computer and try to reattach the device, the error message occurs again.
This error message occurs only on computers that are using the Microsoft Wceusbsh.sys driver and ActiveSync 3.1 to synchronize a Windows CE-based device with the host computer. This problem has been noticed on legacy-free computers only (computers with no COM ports or motherboard ISA bus slots).
The error code may be similar to:
Arguments ffffffdc 00000002 00000000 804177ed
ChildEBP RetAddr Args to Child
f2453c98 804177ed 80431944 ff676980 ffffffff ntoskrnl!_KiTrap0E+0x27c
f2453d1c 804176fe 80473378 80473364 ff676980 ntoskrnl!ExpScanGeneralLookasideList+0x1b
f2453d2c 8046028d 00000000 00000000 00000000 ntoskrnl!ExAdjustLookasideDepth+0x18
f2453da8 804524f6 00000000 00000000 00000000 ntoskrnl!KeBalanceSetManager+0xcc
f2453ddc 80465b62 804601c8 00000000 00000000 ntoskrnl!PspSystemThreadStartup+0x69
00000000 00000000 00000000 00000000 00000000 ntoskrnl!_KiThreadStartup+0x16Not all of the parameter values will be the same on all computers. Additionally, it would be unusual to see Wceusbsh.sys in the call stack. The fault should occur after (above, in the stack) the ExpScanGeneralLookasideList function.
Cause
This issue occurs because of a problem with the way kernel lookaside lists are handled by the Windows CE Wceusbsh.sys synchronization driver.
Status
Microsoft has confirmed that this is a problem in the Microsoft products that are listed at the beginning of this article.
Nov 02, 2017 | Tascam Audio Players & Recorders
Windows root system32 ntoskrnl.exe.
this might help you out...
http://www.computerhope.com/issues/ch000646.htm
Apr 02, 2010 | Microsoft Windows Vista Home Basic Edition...
Problem with a corrupt system32\stoskrnl.exe
check out the article given below to view the detailed information to troubleshoot the issue:
http://support.microsoft.com/kb/314477
Oct 17, 2009 | Toshiba Satellite A35-S159 Notebook
Windows won't start
The ntoskrnl file (NT operating system kernel file) is one of the main Windows file. You can repair this file by inserting the Windows CD install disk and boot up with this CD. Follow the instructions to Install Windows but ignore the first Repair instruction (unless you have a repair disk sually a floppy disk) continue until you get a 2nd repair request, then select this repair.
Windows install will then copy the main files and overright the corrupted ones. (your data and programs should remain intact).
If you still have problems you most likely have to install Windows again.
Best of luck, hope this works out for you, it is a pain having to install Windows again, sometimes it can't be helped.
May 17, 2009 | Compaq Presario 700 470024-192 Notebook
<Windows root>\system32\ntoskrnl.exe.
Do you have a Windows CD that came with your computer? If so do you know how to boot from it by inserting it into the drive and then pressing F12 just after you switch on your PC? If you can do this then you could try the "repair" option from Windows Setup, this might fix your missing PC problem.
I can not get my computer to boot up on the screen it says windows failed to start file : ntoskrnl status: OxcOOOOO98
Jul 10, 2008 | Computers & Internet
Blue screen - kmode exception not handled - ntoskrnl.exe
Did you install anything on your computer right before this happend to you??? Usually when this Dreaded Blue Screen comes up its a hardware issue, You may have installed Memory, USB, ECT... check that out and remove some of your memory first and see if that helps you out any. try also a F`12 or F8 start. see if that helps you out any, Get back to me if you have any other Questions Thanks Bear001
Jun 21, 2008 | IBM Think Centre A50 P4 (841923u) Network...
Windows failed to load because a required file is missing, or corrupt
Try to boot using the installation disk (vista) then do a stystem restore to the date the computer was working and without the SP1.
May 13, 2008 | Microsoft Windows Vista Ultimate Edition
Startup problem
From: http://www.computerhope.com/issues/ch000646.htm If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps. 1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue. 2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key. 3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console. 4. Select the operating system you wish to fix, and then enter the administrator password. 5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32 6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file. 7. Type exit to reboot the computer. If you only have a restore CD, this probably won't work. You should just start the restore all over again, if this is the case.
Jun 05, 2007 | Acer Aspire 5003WLMi Notebook
Computers & Internet Logo
218 people viewed this question
David Payne
David Payne
