Hi. I have a servis washing machine model M6705W and it tries to spin, but clothes still wet. Is there a filter that might be blocked, if so, where is it? OR What could be the problem? Thanks
    President:
  • 1,462 Answers
Filter is front rhs side at the bottom. unscrew and clean but water will come out.
Posted on Jul 11, 2008
Clothes still wet after spin
it is normal for clothes to be a bit wet after spin.approximately about 80 percent of your clothes will be dry after spin. you may hang your clothes to completely dry or place it inside a drier machine
Sep 03, 2015 | Maytag Bravos 3.8 Cu. Ft. Washer
Clothes still wet after cycle
you need to check
1 pump for things that should not be there
2 both hoses to the pump are not blocked
3 worst case change the pump it may be worn
Feb 07, 2014 | Zanussi Washing Machines
Washer doesn't spin out sometimes
you say it drain, but sometimes it won't spin,this could be your filter if it is blocked these new machines can sence it and won't let the machine spin easyest thing check your filter,you never know might be that simple
May 07, 2012 | Washing Machines
Epic washer doesn't spin fast. spins, but slowly. clothes coming out wet, very wet. it started after i washed a heavy wool sweater.
Check the filter, make sure rinse hold is not on, check the drain hose is not blocked, lastly check the brushes, remmember unplug first.
Sep 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Wd865 spinning problems
PUMP IS BLOCKED OR PIPE LEADING TO IT ROMOVE FRONT BOTTOM PANEL AND YOU SHOULD SEE A ROUND THING WITH A SCREW IN IT REMOVE SCREW TWIST AND PULL OUT REMOVE DEBRIS AND TRY AGAIN IF THIS DONT WORK LAY MACHINE ON ITS BACK REMOVE PIPE FROM PUMP AND CHECK IT NOT BLOCKED WITH ANYTHING ITS QUITE AN EASY JOB TO DO
Mar 04, 2009 | Hotpoint Ultima WF865 Front Load Washer
After washing clothes are still coming out wet
If its a washing machine there going to be wet arent they lol.
right if you mean that they are soaking wet after spinning it could be that the water is not draining away fully, have you checked the filter and cleaned that out, usually at the front of the machine on the bottom right. try draining that, or there could be a blockage in the waste pipe,
hope that this helps
Feb 28, 2009 | Hotpoint WMA30 Front Load Washer
Indesit WG820 no power in spin
For your model I hope you will find the filter, seen similar models. Disconnect the machine from the mains outlet. Below the door, there's a plastic cover full machine width. Just remove it and on the right you'll see the filter. Unscrew the filter counter clockwise, clean it, check the pump blades and inlet for some foreign objects and screw filter back on.
Jun 01, 2008 | Washing Machines
Load remains wet after full cycle (including spin @ 1400 rpm)
Hi Paul, Assuming it is pumping out ok, Unplug the machine tip it back at an angle, underneath you will see a black hose that is attached to the bottom of the drum, remove this, take out the ball and discard it and remove anything that may be in the filter, replace the hose and try the machine.
Nov 30, 2007 | Hotpoint WMA64 Front Load Washer
Washing Machines Logo
117 people viewed this question
Top Washing Machines Experts
