Question about IBM 6400 Matrix Printer
Wake up from energy saver mode
I purchased a used IBM 6400 to replace a blown up Genicom 4440. I set it up as a parallel printer with an HP Jetdirect card, and it's been working well. The problem is waking up from energy saver mode, it doesn't seem to want to do that. I set the mode for 60 minutes, but it's still frustrating. Is there any way to disable energy saver? I've gone through the manual, and my configuration settings, but can't seem to find one. Thanks!
Mike
  • 21 Answers
The menu where you set the time once you've scrolled though all the time options will give the option of disabling it.
Posted on Sep 16, 2008
Connecting the JetDirect 300x to my HP Designjet 450c
If you have a tower, rather get an internal parallel card.... works like a dream
Feb 24, 2016 | HP DesignJet 450c InkJet Printer
Why is light blinking on on-off button?
The blinking light indicates that the printer is on power saver mode. The Power Saver Mode saves energy by lowering power consumption during extended periods of inactivity. However, if you try to print from your computer when the printer is on power saver mode, the printer should automatically wake up and prints the job. You can also manually wake it up by just pressing and releasing the power button. Thanks.
Nov 19, 2010 | Lexmark X2470 All-In-One InkJet Printer
I have printer genicom 4440 xt and have not a driver i want a diver for this printer thank you
Just try using a generic print driver in windows. This driver will send standard ASCII code and the printr should allow you to print standard text. try it.
Apr 10, 2010 | Tally Genicom 4440 Printer
Genicom 4440 is 15 years old and is used to print invoices with bar codes. The bar codes are not passing USPS regs. They are curved and were not like that years ago. Can the print head be cleaned or...
Yes to both questions. This printer has 3 print modules. you can try swapping the right side for the left side module or vise versa and see if the problem changes. if it does then you should replace the bad module.
Jan 31, 2010 | Tally Genicom 4440 Printer
Is it possible to use a Canon inkjet printer (parallel interface) on the Jetdirect ex plus?
Yes. The Jetdirect ex plus supports nearly all parallel printers. Makes no difference who made the printer.
Oct 17, 2009 | HP JetDirect EX Plus Print Server
Switch to LPT1 from my computer
Go to start - settings - printers and faxes
Right click on your printer - click properties
At ports tab change from tcp-ip to LPT1
Click apply
Don't forget to connect your printer with parallel LPT cable
Jul 24, 2009 | IBM 6400 Matrix Printer
Wont print on line
You may need to have some driver installed on your PC, that can be downloaded from some IBM printer web site, such as this one:
http://www.infoprintsolutionscompany.com/internet/wwsites.nsf/vwWebPublished/supportdownloads_ww
IBM does not manufacture printers any more, they outsourced that to other places like Lexmark & ProPrinter, so we have to figure out which outsource place is relevant & what name they have for whatever corresponds to 6400 driver.
Sep 27, 2008 | IBM 6400 Matrix Printer
Laserjet 2300d hasstopped printing to a HP Jetdirect 170x suddenly
parallel cable connected?
omg this? "old centronix")
IEEE 1284 standard
parallel-zw1hxsxncju1x1hxxv3nm1gz-1-0.jpg RTM yet? check the manual carefully
http://h20565.www2.hp.com/hpsc/doc/public/display?sp4ts.oid=27317&docLocale=en_US&docId=emr_na-bpj06151
The HP JetDirect 300X provides connectivity to 10Base-T and
100Base-TX networks. The HP JetDirect 170X provides
connectivity to 10Base-T ne
tworks. The HP JetDirect EX Plus
provides connectivity to 10Base-T and 10Base2 networks.
HP JetDirect 170X (J3258B):
Bidirectional parallel port (IEEE 1284).
Network port (Ethernet): RJ-45 (10Base-T).
Test button (sends print server configuration page).??????????
2 LEDs on front indicate LAN activity/status
Mar 06, 2017 | HP Jetdirect 170x Print Server
OkiData Pacemark 3410
Resolution:
Using HP JetAdmin.
Select Device then Modify
Next until arriving at the Options screen.
Here is where we make the necessary changes to the parallel mode and handshaking
Click on the pull down arrow and change the parallel mode to Centronics and make sure handshaking is set to nACK and Busy then click Finish. Reboot the JetDirect box and cycle the power on the printer.
Feb 11, 2008 | OKI Pacemark 3410 Matrix Printer
Oki ML 320 Turbo/D IBM - JetDirect 170x Print Server prolems
Check the receive buffer on the Oki. I usually set it to the highest (88k or 128k). You might also check the print head gap if you are printing multi part invoices. If the print head is too close it may overheat and stop printing. If you have a different printer, swap it out and see if it prints correctly. It may be a problem with the JetDirect 170x, not the printer.
Nov 08, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
IBM 6400 Matrix Printer Logo
383 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
quennie732
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
