Question about HP DesignJet 1050c InkJet Printer
Wont print Jobs are held in Q and won't print. can ping. Shows printer offline
  • HP Expert
  • 141 Answers
Bad network card
Posted on Aug 22, 2008
How to set Konica Minolta copier online.
What model? Can you ping it? Does it show up in the control panel as available. have you reloaded the print drivers have you power off the machine then powered on. have you cleared all print jobs in the print que. Those it copy ok? Ethernet cable ok or using old serial? Can you print from a different computer. have loaded the IP address as static most copiers do not like DHPC where the server decide the IP address. Always use Static you tell the copier what IP address to use.
Sep 03, 2014 | Konica Minolta Office Equipment & Supplies
How to make Konica Minolta copier online?
What model? Can you ping it? Does it show up in the control panel as available. have you reloaded the print drivers have you power off the machine then powered on. have you cleared all print jobs in the print que. Those it copy ok? Ethernet cable ok or using old serial? Can you print from a different computer. have loaded the IP address as static most copiers do not like DHPC where the server decide the IP address. Always use Static you tell the copier what IP address to use. Mite also check to make sure you have the right drivers for the machine.
Sep 03, 2014 | Konica Minolta bizhub Office Equipment &...
When i print from hp deskjet D1560 it dose not print. It automatically shows offline when i print even though it is not offline. And it dose not print self test page also. pls give an instant...
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Aug 19, 2011 | Office Equipment & Supplies
Zebra 140XiII - cannot print via Ethernet cable - Windows status monitor shows status as offline. I Installed correct drivers? what is the secret for connectivity!? Greg
check if IP adress, subnet mask and the gateway are correct on the printer setings.
Try to ping the IP address from the START-Run...(write CMD) and write ping IP adress.???.???.???.???
check if had responce.
Sep 15, 2010 | Zebra 140Xi II Thermal Printer
Printer is offline and will not print. Restarting does not help.
When you double click the Printer and Faxes icon in the Control Panel you will see the printer that your computer is currently using. See.... if the printer image is clear it is online and ready to use, if its blurred then its in offline mode and cannot be use.
To correct offline printer.. some possible reasons is on the usb cable.. check if there is no open wire along the cable...Inserting the USB connector on the other usb slot of the cpu sometimes work just wait first until it is read.
If the printer is still blurred and offline after checking the usb connection, the 2nd thing to do is check the properties of the printer if it is set to offline mode. how? Double click your printer icon. It will display the print jobs window. Click on the Printer tab and uncheck on the "Use printer Offline". Cancel all pending print jobs, close the printer window and try again to print.
Aug 10, 2010 | Office Equipment & Supplies
Just moved. New laptop. Computer says 2 pending printing jobs but wont print. Message from printer: "ofline" Help
You may try the following suggestions:
  • While it says offline, right click the printer icon and cancel print jobs.
  • Right click the icon again, then 'Set Printer Online'.
  • Power cycle the printer. Just turn it off and then turn it back.
  • Reinstall the printer by running the 'Add Printer Wizard' and let it automatically find your printer to be reinstalled.
Nov 02, 2009 | HP Officejet 4110 All-In-One InkJet...
Dell 3100cn Printer
Hi Lillie,
No, the message for RAM disk has nothing to do with your issue. RAM disk is an option for that printer, but most users do not have that option, and if you accessed the menu for the 3100 on most of the machines in use you would receive that same error.
Although the printer itself shows " ready to print", this does not mean that your computer is communicating with the printer. In Fact, that message would show up even if you did not have it attached to any computer, as long as it was turned on and passed the self test.
More then likely the problem lies within the computer, NOT the printer.
To test the printers functionality, try printing a menu item, from the "reports" menu. Select either the printer settings, or the PCL Fonts report. When selected, the printer should print which ever report you selected.
One thing you may want to check is to see if there are any print jobs " locked up " in the print spooler on your computer, and also make sure that the printer is not set to "work offline".
To do this, open the control panel, go to your "printers" folder, then double click on your printer.
This will open up the printer information for that printer. If there are any jobs in the print queue, they will show up here.
if there are any print jobs stacked up, usually it is the top job that had a problem and is "stuck". This will prevent any job sent after that to be held, pending release of that one.
single click the top job and either restart the job, or delete it.
Also, make sure that the printer is not set to work offline by clicking on "printer" from the menu and ensure that work offline is not checked.
Good luck.
Oct 06, 2008 | Dell 3100cn Laser Printer
Printer offline
sure..
remove the print drivers from before.
go here for fresh ones
and check for your Vista SP1 upgrade.
Mar 28, 2008 | HP Officejet 5610 All-In-One InkJet...
Toshiba eStudio232
Make sure store to e-file is not picked on the print job page on the printer properties. Also make sure the paper size of what your trying to print is available in the machine( eg print job is A5 paper etc)
Oct 04, 2007 | Office Equipment & Supplies
HP photosmart C3180 stops printing
Posted by JACOB I understand that you are unable to print and when ever u try to print the jobs stuck in queue... When we right click on the icon if we see a option use printer online this shows that the printer is offline, if we see a option use printer offline in the list then this shows that the printer is online status. To resolve the issue we have to first clear the job in queue. Open the printer folder and then double click on the HP printer icon this will show the jobs in queue just right click on each job in queue and select cancel to clear the job in queue if there are still jobs in queue we have to performe the restart the print spooler steps by keeping the usb cable disconnected so that all the jobs are clear when the spooler is restarted. One the spooler is restarted just reconnect the usb cable and check if there are any jobs in queue. If there are no jobs in queue we can move ahead an set the print directly settings. Steps to set the print directly settings: Right click on the printer icon and select properties then click on the advance tab and under it select the option print directly to printer and click on apply and Ok to save the settings. Once done try to print to check with the issue. If the issue presists you can try to check with the port settings. Right click on the printer icon and select properties and then click on the ports tab and check if the virtual usb001 port is selected if not select it and click on apply and ok to save the settings if you don't see any usb port check if you have dot4 port in the port list select it and save the setting and try to print this should resolve the issue.. Once done try to print and if the issue presists you can try to refresh the usb ports. This will re-detect the usb drivers for printer and you will be able to print after restarting the computer.
Sep 16, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP DesignJet 1050c InkJet Printer Logo
351 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
