Question about Acer Aspire 3680 Laptop
I am trying to connect my PC to my TV. I have a Sharp HDTV and my PC is a Toshiba with windows XP. I have a componert video cable which is connected to the TV and PC. I have used Fn and F5 didn't work. also tryed F1 and f12. I have clicked on MENU on TV and then Setup and the book said click on input signal but it is blocked out. Not very good with thes things HELP[ MC]
  • 2 more comments
  • cherrypie310 Jul 14, 2008
    We had a familey member to stop buy. and he helped with the connecting, PC to TV. The converter we had didn't work, so he used a composite cable that will go from the S-video connecton on the PC to the s-video connector on the TV. on my unit its component video Input 3. Then set your TV on Input 3 . ON your PC hold down the Fn tab then press the f5 {which has a picture of a TV and PC] Tab you should get 3 large Icons press the F5 until you select[ highlight] PC/TV Icons. with both PC and TV on . You should have the picture from your PC on your TV. How about some sound? purchase a cable with headset adapter and plug in pins that will fit the audio recepticable on your TV. Plug the headset adapter into your PC headset recepticable and the pin plugs into the Input3 audio recepticable. you should then have picture and sound.My sound and picture are great.
    My TV is a Sharp LC- 60C52U 2007
    Thank you so much for your help
  • Anonymous Oct 05, 2008
    I'm trying to send my audio output from my desktop pc to my monitor/tv with an audio Y-cable, but never hear any sound.
    I've tried all the jacks on my sound card. My mother board is an MSI-7125
  • 476 Answers
What model of TV was it please,
Does your computer have tv out video card installed?
For video to tv you will need a vga to tv converter,this is an external device and will work on the computers vga output straight into a vga input and give you 1 x vga out,1 x rca out, 1 x s/video out,comes supplied all prebuilt with onboard graphics solution. no extra power required runs straight of vga output.
Once the computers video output is established then set the TV up to tune into the converters output signal.
HD TV can be set up to run thru rca and components and if model is late enough shuld come equip with serial vga input for computers.Other than that HDMI seems to be the better quality of picture over rca component.Cost verses dollar really and function.
Expensive Fix HDMI to HDMI
(it is posible to hdmi over cat5e)
Posted on Jul 13, 2008
Somehow getting access to the actual internet on my aquos sharp TVLC
The TV will connect to your wireless router but not other devices in your network. You can connect to a HDMI port with a cable to your PC and select that port on the TV.
Jul 27, 2016 | Sharp " AQUOS - 70"" Class - LED - 1080p -...
I would like to connect my toshiba tecra to my Sharp lc-46d62u TV to watch downloaded hd movies
Hi there if ur looking to connect ur PC to ur TV u must have one or two things an HDMI cable and an HDMI port on ur PC or a VGA cable and port on the TV and PC depending on the two it will be easy both ways however if preferred HDMI is the way to go due to audio is also carried over HDMI as well the video
Dec 27, 2010 | Toshiba TECRA M5 IC2D T5600 1.83GHZ, XP...
Can I hook up my Toshiba laptop to my Sharp Aqous TV, if so what connections do I need, ?S-video? I have an SGA connection on my laptop but not on the TV?
If this is the exact model Sharp Aquos television you have then you would have to have a laptop that has hdmi or dvi. You can try S Video on a laptop but the laptop's resolution would have to be so low that most laptops cannot accommodate this. You're right; this television does not have a VGA (RGB cable) input.
Nov 02, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Screen turns blue after Windows XP boot. It is
You cannot set your PC video resolution to 1920x1080 @60Hz?
Per user manual:
1. Set computer to a resolution supported by your HDTV (see Preset PC Resolutions). If your
computer supports it, we recommend 1920x1080 @60Hz.
2. Turn off the power to your HDTV and Computer.
3. Connect the VGA cable from your computer to the RGB PC jack on your HDTV.
4. Connect the 1/8-inch audio cable from your computer to the RGB PC Audio jack on your HDTV.
This step is optional and only needed to transmit audio from the computer through the TV.
5. Turn on the power to your HDTV and computer.
6. Select RGB using the INPUT button on the remote control or side of your HDTV.
Note: Refer to your PC computer user manual for more information about the video output requirements.
Sep 07, 2010 | Vizio VM230XVT 23 in. TV
How do i connect my acer pc to my 42 in jvc hdtv
You have to purchase a good quality 3DFX video card to ba able to hook into TV
Jan 20, 2010 | Acer ASPIRE T180-UA381B DESKTOP PC
I have a Sharp LCD TV and a Toshiba Satelite laptop. I have never had any problems connecting my laptop to the tv using a vga cable. It isn't working anymore however. I checked the cables and...
I would check the video setting on your laptop. The resolution or refresh rate might have been changed and the LCD TV might not be able to process the signal. Try changing the laptop's resolution to the lowest setting(right-click on desktop and pick properties) and see if the TV produces a picture. Also verify the video output on the laptop is working by hooking it up to a computer monitor if available.
Jan 09, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
What type of cable for laptop to Tv?
In order to hook a laptop or any computer to a tv you have to have the right video card with the correct video connections like hdmi or s-video. If you don't have those connections then you can't hook a laptop to a tv.
May 05, 2009 | Sharp 19 in. LCD HDTV
Samsung hdtv to compaq pc
There should be a setting within the comp. Is it connected to the comp monitor and the tv? Perhaps from the comp to the tv with the monitor from the comp as well? Well if so, you may need a certain setting within the comp. Check under (on xp) display properties, and then under the settings tab. Please rate!
Apr 28, 2009 | HP Compaq nx6110 PC Laptop
Gateway PC to Sharp Aquos
You need to go into the display settings of your computer once the cable is connected and change it to a dual-monitor setup. I'm going to assume you have windows 98/xp, you can find the display settings in your control panel under the title of "display". it'll be under the last tab of the window called "settings".
Keep it in mind, in reality there are a ton of ways to run two monitors. Chances are the one that your going to find easily is to "extend" your desktop onto your tv, making them both run as one screen. Hopefully that doesn't happen to you (you'll probably find it extremely annoying). Also, some video players wont let you play videos on your TV because their worried that your going to copy the video onto vhs.
The display on your tv will be blurry with s-video, and you wont be able to read text easily (hd-tvs are different if your video card is new enough to use the hd-tvs features, and/or your hd-tv can run computer displays. You can purchase a computer monitor to hd-tv cable online or at computer stores) but videos and pictures will look good. And if you have problems and you accidentally switch your display to the tv and your monitor is off, turn off the computer and unplug the s-video, it should go back to normal although it may happen if you put the s-vid cable back into the pc.
If you have any questions, feel free to ask. I have lots of experience doing this.
Jan 15, 2008 | Computers & Internet
Acer Aspire 3680 Laptop Logo
513 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
