Question about RCA HD52W56 52" Rear Projection HDTV
Chassis # was ITC222. - RCA HD52W56 52" Rear Projection HDTV
  • Anarosa Jul 10, 2008
    We found the chassis number it was ITC222. Now what should we do?
  • RCA Master
  • 8,617 Answers
Okay the flyback is the HV transformer.I am enclosing a picture the flyback is circled in RED.chassis # - 62bec1a.jpg
Posted on Jul 10, 2008
  • Sonny Berry
    Sonny Berry Jul 10, 2008
    Resolder the component circled in red and the other components that are close to it.
The inputs on my RCA scenium dlp tv wont work.
It sounds like your talking about the ITC222 chassis series which is having a small signal board problem. Very common in the RCA ITC222 and ITC222A Chassis HDTV's
Jul 12, 2010 | RCA Televison & Video
The tv wont converge it doesnt even come up on the menu and there is a triple picture red blue green
That sounds like a RCA ITC222 chassis. If so theres a repair kit called ITC222 convergence option missing kit at the following link it has the components and instructions on how to do the repair.
http://www.tvrepairworld.com/
Jul 14, 2009 | Televison & Video
Keeps shuting off.
Hello bondaddy60, I believe this may be your problem since this is a common issue in this RCA ITC222 chassis, I posted this earlier and I beleive that it can help you, Hello This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board. I would also like to say that if possible you should get a qualified TV Technician to repair this set for you, due to the nature of this problem and the dangerous voltages present. I hope this helps, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 09, 2009 | RCA D52W19 52" Rear Projection Television
52" tv
It sounds like youre decsribing the ITC222 chassis HDTV rear projection. Look on the rear tag to see if its a ITC222 chassis and let me know and I can assist you with it.
May 18, 2009 | Televison & Video
RCA D52W20 won't come on
I hope this helps,
Shuttle83
Dec 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HDTV chassis # ITC222 will not come on.
most likely the Flyback 259296 and CP150 you can get replacements at the following link with free instalation instructions
http://servicemanuals.vstore.ca/
Nov 25, 2008 | RCA D52W19 52" Rear Projection Television
RCA R52WH74 (ITC222A Chassis)
no the board that has the FL231 on is the ITC222 deflection board. The other board is above the chassis in a seperate frame that runs across the set the convergence power supply is the board on the left above the board where the fL231 is. Yes the ITC222 and ITC222A are the same chassis. As for the service manual that site should have the service manual under the thomson category as the ITC 222 chassis is actually a thomson chassis made for RCA.
Sep 11, 2008 | RCA R52WH73 Projection Television
R52WM24
I will need you to look on the rear tag and let me know the chassis number as that model was produced with two different chassis numbers ITC222 and the ATC221 chassis was used, But the chassis number will be on the tag on the rear panel. Please reply to this same post and I will help you locate the power supply board.
Aug 13, 2008 | RCA R52WM24 52" HDTV Projection Television
Don't understand
Can you look on the rear of your set and give me the chassis number and I can explain as that model used three different chassis designs one was ITC222, then ATC221 and ATC321 it should be marked on the rear tag.
Jul 10, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA HD52W56 52" Rear Projection HDTV Logo
78 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
